biz172 Posted February 1, 2018 Share Posted February 1, 2018 I'm able to successfully boot-up into Armbian_5.37_S9xxx_Ubuntu_xenial_3.14.29 but got stuck instead at the root login due to the following issues... 1. Tried using usb keyboard - No response. 2. Tried SSH via WiFi or usb Ethernet - Failed to connect. I'm using 150balbes method of installing the image to SDCard. I also had input the required details on first run armbian.txt file. From documentation, I've understand that USB support in u-boot currently not enabled on all H3 boards. How to enable the usb support? TVBox : S-BOX Amlogic S905X TV Box Link to comment Share on other sites More sharing options...
balbes150 Posted February 1, 2018 Share Posted February 1, 2018 1. Try to pick the correct dtb file. It depends on the work wired network. 2. What did you change in the file "armbian.txt" ? 3. H3 has nothing to do with the TV boxes with S905X. Link to comment Share on other sites More sharing options...
biz172 Posted February 2, 2018 Author Share Posted February 2, 2018 Thanks for replying,balbes150. Appreciate that. As for the armbian.txt file, all i did was just input my SSID, enable wifi/ethernet etc. Anyway, did tried with several dtb files today. While the rest of dtb files hanged at the armlogic logo upon power on the box, i only managed to boot up from the generic dtb (gxbb_p201) till the armbian logon screen. Yet again, there's no response from the keyboard when trying to input the password. Any other way or method for me to get the usb ports working and detect the keyboard? Or could there be any other armbian image available that able to auto detect usb device? Link to comment Share on other sites More sharing options...
