Hello!
I am using armbian on orangepi zero.
Currently SPI_CS line is LOW in default state and goes HIGH when selecting.
Does it possible to invert it's state to be HIGH in default state and to be pulled down during line selection?
I'm not sure anymore.. Long time ago since I lastly used SPI on legacy kernel... I think defining cs in the fexfile (bin2fex --> fex2bin) [spi0] according to this should work:
spi_cs0 = port:PA13<2><1><default><default>
But on your own, test it first with a multimeter before complaining about faults.. :)
spi0 {
		pins = "PC0", "PC1", "PC2", "PC3";
		function = "spio0";
		linux, phandle = <0x20>;
       	phandle = <0x20>;
spi1 {
          pins = "PA15", "PA16", "PA14", "PA13";
          function = "spi1";
          linux, phandle = <0x21>;
          phandle = <0x21>;
spi@01c68000 {
          compatible = "allwinner, sun8i-h3-spi";
          reg = <0x1c68000 0x1000>;
          interrupts = <0x0 0x41 0x4>;
          clocks = <0x6 0x1e 0x6 0x52>;
          clock-names = "ahb", "mod";
          dmas = <0x1f 0x17 0x1f 0x17>;
          dma-names = "default";
          pinctrl-names = "default";
          pinctrl-0 = <0x20>;
          resets = <0x6 0xf>;
          status = "disabled";
          #address-cells = 0x1;
          #size-cells = 0x0;
          linux,phandle = <0x5c>;
          phandle = <0x5c>;
          flash@0 {
          		#address-cells = <0x1>;
          		#size-cells = <0x1>;
          		compatible = "mxicy, mx25l1606e", "winbond, w25q1$
          		reg = <0x0>;
          		spi-max-frequency = <0x2625a00>;
          spi@01c69000 {
          		reg = <0x1c69000 0x1000>;
          		interrupts = <0x0 0x42 0x4>;
          		clocks = <0x6 0x1f 0x6 0x53>;
          		dmas = <0x1f 0x18 0x6 0x53>;
          		dma-names = "rx", "tx";
          		pinctrl-0 = <0x21>;
          		resets = <0x6 0x10>;
          		#size-cells = <0x0>;
          		linux, phandle = <0x5d>;
          		phandle = <0x5d>;
          spi0_pins = "/soc/pinctrl@01c20800/spi0";
          spi1_pins = "/soc/pinctrl@01c20800/spi1";
          spi0 = "/soc/spi@01c68000";
          spi1 = "/soc/spi@01c69000";
I use debian server mainline kernel. So there is dts instead of fex.
Here is what I found in dts.
What is the magic string that will invert CS default state?
Available DT settings for SPI busses and SPI slave devices are listed there:
https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable.git/tree/Documentation/devicetree/bindings/spi/spi-bus.txt
Those properties include a slave device property named "spi-cs-high". Though applying this property may need creating an additional DT overlay (i.e. if it needs to be applied to a spidev slave activated by an overlay).
Edit: Though this will work only if SPI drivers respect this flag, which they may not do.
I tried it.
Here is armbianEnv.txt file:
$ cat /boot/armbianEnv.txt
verbosity=1
logo=disabled
console=both
disp_mode=1920x1080p60
overlay_prefix=sun8i-h3
overlays=usbhost2 usbhost3 spi-spidev spi-add-cs1
rootdev=UUID=39059033-9dc5-4bc4-a4d2-61ef949d5b21
rootfstype=ext4
param_spidev_spi_bus=1
param_spidev_spi_cs=1
dtb to dts converting:
$ cd /boot/dtb/overlay
al@orangepizero:/boot/dtb/overlay$ cp sun8i-h3-spi-spidev.dtbo /home/al/
al@orangepizero:/boot/dtb/overlay$ cd /home/al/
al@orangepizero:~$ cp sun8i-h3-spi-spidev.dtbo sun8i-h3-spi-spidev.dtbo_def
pidev.dtboizero:~$ dtc -I dtb -O dts -o sun8i-h3-spi-spidev.dts ./sun8i-h3-spi-sp
Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /fragment@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /fragment@1/__overlay__/spidev has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /fragment@2 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /fragment@2/__overlay__/spidev has a reg or ranges property, but no unit name
dts file editing;
$ rm sun8i-h3-spi-spidev.dtbo
$ sudo rm /boot/dtb/overlay/sun8i-h3-spi-spidev.dtbo
$ ls /boot/dtb/overlay/ | grep spidev
$ nano sun8i-h3-spi-spidev.dts
/dts-v1/;
        compatible = "allwinner,sun8i-h3";
        fragment@0 {
                target-path = "/aliases";
                __overlay__ {
        fragment@1 {
                target = <0xffffffff>;
                __overlay__ {
                        spidev {
                                compatible = "spidev";
                                reg = <0x0>;
                                spi-max-frequency = <0xf4240>;
        fragment@2 {
                __overlay__ {
                        spidev {
                                status = "ok";
                  				spi-cs-high;
                                reg = <0x0>;
        __fixups__ {
                spi0 = "/fragment@1:target:0";
                spi1 = "/fragment@2:target:0";
Converting dts back to dtbo:
$ dtc -I dts -O dtb -o sun8i-h3-spi-spidev.dtbo ./sun8i-h3-spi-spidev.dts
$ sudo mv sun8i-h3-spi-spidev.dtbo /boot/dtb/overlay/sun8i-h3-spi-spidev.dtbo
$ sudo reboot
Unfortunately, oscilloscope shows me that CS pin still in "1" while CS active but I need it to be in "1" during passive state and pulled down to "0" during CS activating. How to invert it?IMG_20180216_000006.thumb.jpg.e92a23fdb647c250529c0c43cf30371c.jpg
Used distributive:
$ uname -a
Linux orangepizero 4.14.19-sunxi #2 SMP Thu Feb 15 20:54:47 MSK 2018 armv7l GNU/Linux
$ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description:    Debian GNU/Linux 9.3 (stretch)
Release:        9.3
Codename:       stretch
