Paul Kendall Posted February 21, 2018 Posted February 21, 2018 I am building armbian with mainline kernel (4.14.19) on jessie for OrangePi Lite... Sometimes on booting my Pi Lite, the wifi does not work. I cannot create hotspot and connecting to existing networks will not work. A short time after booting I see the following messages in the dmesg log [ 102.077151] sunxi-mmc 1c10000.mmc: send stop command failed [ 102.077184] sunxi-mmc 1c10000.mmc: data error, sending stop command If I remove and reload the 8189fs module I will see the following error in the dmesg log [ 572.371452] rtl8189fs: probe of mmc1:0001:1 failed with error -110 If I don't see the mmc errors after startup (say 5 minutes) the wifi works fine. I can also remove and reload the kernel module as I please and create a hotspot or connect to an existing network. Has anyone else seen this problem or have any workarounds?
WarHawk_AVG Posted July 13, 2018 Posted July 13, 2018 What is the CPU temp running at when it drops out? armbianmonitor -m
