Hello.
I install the 5.35 Version on a OrangePiPc+, all run in good condition.
I upgrade to the 5.38 without problem (kernel 3.x)
I upgrade the kernel to 4.x, so long as i didn't reboot, all is in function (with Ubuntu) and my USB Tevii 662 is recognized (and run with TVHeadend).
After reboot, no Ethernet and no USB, no possibility to login.
I tried all versions with kernel 4.x, even desktop, no function.
Anyone has a idea, how it will be run???
Thank's for any idea.
P.S. OrangePI PC Plus, 1 GB RAM, 8 GB SSD-OnChip, Tevii S662 S2 USB, TVHeadend.
Edited by JohnSheridan
Do you own a serial uart USB dongle? Makes debugging a way easier... :)
Did you start with a next image without kernel update (e.g. Debian_stretch_next_desktop)?
Please consider that next (4.x kernel) images are in testing and thing may not work as expected but ETH should work...
  ___                               ____  _   ____   ____
 / _ \ _ __ __ _ _ __   __ _  ___  |  _ \(_) |  _ \ / ___|    _
| | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | | |_) | |      _| |_
| |_| | | | (_| | | | | (_| |  __/ |  __/| | |  __/| |___  |_   _|
 \___/|_|  \__,_|_| |_|\__, |\___| |_|   |_| |_|    \____|   |_|
                       |___/
Welcome to ARMBIAN 5.38.180128 nightly Debian GNU/Linux 9 (stretch) 4.14.15-sunxi
System load:   0.89 0.31 0.11   Up time:       1 min
Memory usage:  19 % of 1000MB   IP:            192.168.x.xx
CPU temp:      32°C
Usage of /:    49% of 7.1G
[ 0 security updates available, 4 updates total: apt upgrade ]
Last check: 2018-02-19 18:17
[ General system configuration (beta): armbian-config ]
Last login: Mon Feb 19 18:17:18 2018 from 192.168.x.xx
opi@orangepipcplus:~$ sudo ifconfig
[sudo] password for opi:
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.x.xx  netmask 255.255.255.0  broadcast 192.168.x.xx
        inet6 fe80::81:26ff:fe6d:6dd7  prefixlen 64  scopeid 0x20<link>
        ether 02:81:26:6d:6d:d7  txqueuelen 1000  (Ethernet)
        RX packets 957  bytes 992736 (969.4 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 731  bytes 75557 (73.7 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 40
even after update, it still works...
Welcome to ARMBIAN 5.41.180208 nightly Debian GNU/Linux 9 (stretch) 4.14.18-sunxi
8 GB eMMC.. :P
