maybe someone can give me a hint... I have a running system now on 128GB eMMC card, and wanto to use GPIO.
I have /sys/class/gpio/ with export, and unexport files, and two gpiochip0 and gpiochip14 entries.
Unfortunately I can't export pins, as
export 231 > /sys/class/gpio/export
gives me a (as user and root)
bash: echo: write error: Invalid argument
Any help is appreciated.
EDIT: works now. It is somehow a bit complicated, as the "usual" numbers as known from 3.x kernels vanished. Debug output shows two "gpiochips", with a certain number of pins, which you have to correlate to the device tree enums for that "chips" - giving you finally the number you want.
Maybe I simply don't get the simplicity of that new concept...
So far, Michael
