I use orange Pi (Armbian_5.38) and would like to know how to us my hp Officejet 4500 G510g-m.
I tried pyinstane but get error :
Pillow-4.0.0-cp35-cp35m-manylinux1_i686.whl is not a supported wheel on this platform.
tried all files.
And also tried SANE and my printer is showed with this command: sane-find-scanner
but nothing with this one: scanimage -L
Thank you!
Edited by kamoba
Hello !
Did you try or verify that Hplip is installed ?
https://developers.hp.com/hp-linux-imaging-and-printing/models/officejet/officejet_4500_g510g-m
note 3 : "Scan supported means that PC initiated scan using a SANE compatible software application is supported over parallel, USB, or network (depending on I/O connection)"
note 9 : "Device supports digital sending, not standard scanning protocols. See this KB article for more info."
I hope it will help you !
Read you !
Actually, I tried to install it from the hp website and I had a lot of problems, so I managed a good installation with it:
apt-get install hplip
and now i can use sane to operate my scanner.
Thanks.
