phintegrator Posted February 4, 2016 Posted February 4, 2016 Hi Igor, I am using nand-install script to boot my Cubieboard2 from nand. However I need some modification in uboot so I need to recompile it by myself. Can you share the sources and patches for this uboot that is running from nand? Thanks in advance.
Igor Posted February 4, 2016 Posted February 4, 2016 https://github.com/igorpecovnik/lib/blob/master/scripts/nand-sata-install/usr/lib/nand-sata-install/nand-sata-install.sh#L7-L9 I think the branch for A20 is: sunxi-nand
phintegrator Posted February 4, 2016 Author Posted February 4, 2016 Hi , Do you have any idea what the problem here? I try recompiling this with Cubietruck_config https://github.com/mmplayer/u-boot-sunxi/tree/sunxi-nand-a20 My build doesn't proceed, I'm stuck with this error. arm-linux-gnueabi-ld.bfd: BFD (GNU Binutils for Ubuntu) 2.24 assertion fail ../../bfd/elf32-arm.c:7696 arm-linux-gnueabi-ld.bfd: BFD (GNU Binutils for Ubuntu) 2.24 assertion fail ../../bfd/elf32-arm.c:7696 arm-linux-gnueabi-ld.bfd: BFD (GNU Binutils for Ubuntu) 2.24 assertion fail ../../bfd/elf32-arm.c:7696 arm-linux-gnueabi-ld.bfd: error: required section '.rel.plt' not found in the linker script arm-linux-gnueabi-ld.bfd: final link failed: Invalid operation make: *** [u-boot] Error 1 Hope anyone can help. Thanks.
