I need to use an IRQ interruption with a button. I mean, I push a button, and then a code is executed.
Some information: The PIN is PH19, EINT19. and the board A20 SOM. Armbian SO, kernel 4.13
Firstly i configure the digital pin and IRQ from user space:
echo 243 > /sys/class/gpio/export
echo "in" > /sys/class/gpio/gpio243/direction
echo "falling" > /sys/class/gpio/gpio243/edge
Now, when I push the button, I can monitoring the IRQ and the counter related to
cat /proc/interrupts
But now, how can I run a program when the interruption event happens ?
I have seen this useful link
http://linux-sunxi.org/External_interrupts
How can i use it? I think there is very few information about this issue.
I executed a bash script with while true , and polling the digital pin, but the disadvantage is that it consumes a lot of cpu.
I hope you can help me. Thank you very much in advance
Regards
Thank you martinayotte for your answer.
However i have found an alternative solution in PHP language that works pretty well. It barely consumes CPU. The code is very simple. Anyway I will try the code in c language that you indicated in your previous post. I imagine that the internal functioning will be similar in both solutions.
If anyone is interested, check the following link:
https://github.com/PacktPublishing/GNU-Linux-Rapid-Embedded-Programming/blob/master/Chapter06/gpio-poll.php
Regards
