Hello:
I have an issue with one of my opi pc boards: When I connect it to hdmi tv and tv is not connected (switched on before booting the soc), I get just a red screen. Armbian is up and ready. I can log through ssh.
Tested in Armbian_5.38_orangepipc_Ubuntu_xenial_default_3.4.113_desktop and openelec (last version). Same problem in both.
I'm looking for mods in the .fex file (if there are any that applies to this case). So far I checked http://sunxi.org/Fex_Guide without luck.
Time ago, I had a similar problem with an raspberry pi. In this case it was solved with a parameter in the config.txt (hdmi_force_hotplug=1). With this, hdmi port in the rpi was on even in the case of disconnected TV. I can't find similar parameter in fex description.
Any clue? Any help would be welcome...
Thanks in advance.
RgB
