deb2016 Posted March 15, 2018 Posted March 15, 2018 Hello, I have a small fan (2-3cm diameter). Do you know if it is possible to plug it on the clearfogpro board ? On the mikrobus header, one can see GND, 5V, 3.3V slots. Can I plug the fan wires into these ? Thanks for your attention Regards
Heisath Posted March 15, 2018 Posted March 15, 2018 Yes you could use the Pins from the mikrobus header but make sure your fan does not draw to much power for the 5V regulator. If it is a 12V fan you could also run it directly on your input (if this is 12V). There are some headers near the power plug which can be used with a small adapter. I attached an image which highlights the connectors. Check https://wiki.solid-run.com/lib/exe/fetch.php?media=a38x:carrierboard:docs:clearfog-schematics-2.1.pdf for the schematics. The power regulators etc are on page 13... EDIT: looks like the power regulator for 5V is the RT2875A/B which can source up to 3A. Greetings
