dudepron Posted February 9, 2016 Share Posted February 9, 2016 Just upgraded to the new Jessie image 4.4.1. Is there any concern with this bad CRC warning? Do I need to update the u-boot.img? If so, how. U-Boot SPL 2013.10-rc4 (Feb 03 2016 - 16:37:42)Boot Device: SD1spl: error reading image u-boot.img, err - -1Load image from RAW...U-Boot 2013.10-rc4 (Feb 03 2016 - 16:37:42)CPU: Freescale i.MX6Q rev1.5 at 792 MHzReset cause: PORBoard: MX6-CuBox-iDRAM: 2 GiBMMC: FSL_SDHC: 0*** Warning - bad CRC, using default environmentIn: serialOut: serialErr: serialNet: FEC [PRIME]Hit any key to stop autoboot: 0mmc0 is current device** File not found /boot.scr **** File not found /uEnv.txt **** File not found /zImage **** File not found /uImage **563 bytes read in 131 ms (3.9 KiB/s)Running bootscript from mmc ...## Executing script at 1080000033996 bytes read in 252 ms (130.9 KiB/s)4325272 bytes read in 342 ms (12.1 MiB/s)Kernel image @ 0x10800000 [ 0x000000 - 0x41ff98 ]## Flattened Device Tree blob at 18000000 Booting using the fdt blob at 0x18000000 Using Device Tree in place at 18000000, end 1800b4cbStarting kernel ...Uncompressing Linux... done, booting the kernel.Debian GNU/Linux 8 cubox-i ttymxc0cubox-i login Link to comment Share on other sites More sharing options...
Igor Posted February 9, 2016 Share Posted February 9, 2016 That's perfectly OK http://www.denx.de/wiki/view/DULG/WarningBadCRCUsingDefaultEnvironment Link to comment Share on other sites More sharing options...
dudepron Posted February 9, 2016 Author Share Posted February 9, 2016 Thanks for the quick response. 1 Link to comment Share on other sites More sharing options...
