John Woodcock Posted March 24, 2018 Posted March 24, 2018 not sure this is the right place to post this got one of these really cheap last year $10nzd in a mall on clearance was wanting to know if there was any linux os out there i could install on this ?
TonyMac32 Posted March 24, 2018 Posted March 24, 2018 This would best be posted under "tv boxes", and I would recommend you find out what you can about the device (SoC, etc).
John Woodcock Posted March 25, 2018 Author Posted March 25, 2018 12 hours ago, TonyMac32 said: This would best be posted under "tv boxes", and I would recommend you find out what you can about the device (SoC, etc). do you mean the specs of the android stick like what cpuz would show?
TonyMac32 Posted March 25, 2018 Posted March 25, 2018 That would be helpful, there are hundreds of different sticks out there, the folks who keep the TV box threads going will need that. If it happens to be the same as some other stick someone has hacked, your task becomes much easier.Sent from my Pixel using Tapatalk
TonyMac32 Posted March 26, 2018 Posted March 26, 2018 It looks like DTB's for m201 exist in @balbes150's work. There will most likely be some more work needed on your side, so read through the thread carefully.
John Woodcock Posted March 26, 2018 Author Posted March 26, 2018 2 hours ago, TonyMac32 said: It looks like DTB's for m201 exist in @balbes150's work. There will most likely be some more work needed on your side, so read through the thread carefully. thx
