faylyn101 Posted March 26, 2018 Posted March 26, 2018 Hi, No matter I am using master or development branches, both were failed to build uboot/kernel by bl31 target. Spoiler $ ./compile.sh [ o.k. ] Using config file [ config-default.conf ] [ warn ] This script requires root privileges, trying to use sudo [ o.k. ] Using config file [ config-default.conf ] [ o.k. ] This script will try to update Already up-to-date. Branch master set up to track remote branch master from origin. Switched to a new branch 'master' [ o.k. ] Command line: setting LIB_TAG to [ development ] [ o.k. ] Preparing [ host ] [ o.k. ] Build host OS release [ xenial ] [ o.k. ] Syncing clock [ host ] ... [ o.k. ] Downloading sources [ o.k. ] Checking git sources [ u-boot v2017.11 ] [ .... ] Creating local copy [ .... ] Fetching updates remote: Counting objects: 13850, done. remote: Compressing objects: 100% (12501/12501), done. remote: Total 13850 (delta 2480), reused 5498 (delta 1100) Receiving objects: 100% (13850/13850), 17.34 MiB | 1.03 MiB/s, done. Resolving deltas: 100% (2480/2480), done. From git://git.denx.de/u-boot * tag v2017.11 -> FETCH_HEAD [ .... ] Checking out [ o.k. ] Checking git sources [ linux-sun50i-dev sunxi64-4.14.y ] [ .... ] Creating local copy [ .... ] Fetching updates remote: Counting objects: 65166, done. remote: Compressing objects: 100% (60561/60561), done. remote: Total 65166 (delta 5682), reused 24248 (delta 3618), pack-reused 0 Receiving objects: 100% (65166/65166), 173.09 MiB | 1.48 MiB/s, done. Resolving deltas: 100% (5682/5682), done. From https://github.com/Icenowy/linux * branch sunxi64-4.14.y -> FETCH_HEAD * [new branch] sunxi64-4.14.y -> origin/sunxi64-4.14.y [ .... ] Checking out [ o.k. ] Checking git sources [ arm-trusted-firmware-sunxi-mainline allwinner-stable ] [ .... ] Creating local copy [ .... ] Fetching updates fatal: Couldn't find remote ref allwinner-stable [ .... ] Checking out error: pathspec 'FETCH_HEAD' did not match any file(s) known to git. [ o.k. ] Checking git sources [ sunxi-tools master ] [ .... ] Creating local copy [ .... ] Fetching updates remote: Counting objects: 83, done. remote: Compressing objects: 100% (78/78), done. remote: Total 83 (delta 13), reused 33 (delta 4), pack-reused 0 Unpacking objects: 100% (83/83), done. From https://github.com/linux-sunxi/sunxi-tools * branch master -> FETCH_HEAD * [new branch] master -> origin/master [ .... ] Checking out [ o.k. ] Checking git sources [ rkbin-tools master ] [ .... ] Creating local copy [ .... ] Fetching updates remote: Counting objects: 233, done. remote: Compressing objects: 100% (183/183), done. remote: Total 233 (delta 58), reused 209 (delta 50), pack-reused 0 Receiving objects: 100% (233/233), 22.61 MiB | 2.57 MiB/s, done. Resolving deltas: 100% (58/58), done. From https://github.com/rockchip-linux/rkbin * branch master -> FETCH_HEAD * [new branch] master -> origin/master [ .... ] Checking out [ o.k. ] Checking git sources [ marvell-tools A3700_utils-armada-17.10 ] [ .... ] Creating local copy [ .... ] Fetching updates remote: Counting objects: 294, done. remote: Compressing objects: 100% (150/150), done. remote: Total 294 (delta 151), reused 229 (delta 140), pack-reused 0 Receiving objects: 100% (294/294), 5.80 MiB | 2.08 MiB/s, done. Resolving deltas: 100% (151/151), done. From https://github.com/MarvellEmbeddedProcessors/A3700-utils-marvell * branch A3700_utils-armada-17.10 -> FETCH_HEAD * [new branch] A3700_utils-armada-17.10 -> origin/A3700_utils-armada-17.10 [ .... ] Checking out [ o.k. ] Checking git sources [ odroidc2-blobs master ] [ .... ] Creating local copy [ .... ] Fetching updates remote: Counting objects: 13, done. remote: Compressing objects: 100% (13/13), done. remote: Total 13 (delta 0), reused 11 (delta 0), pack-reused 0 Unpacking objects: 100% (13/13), done. From https://github.com/armbian/odroidc2-blobs * branch master -> FETCH_HEAD * [new branch] master -> origin/master [ .... ] Checking out [ o.k. ] Compiling [ sunxi-tools ] Setting version information: 5c19710 [ o.k. ] Installing [ rkbin-tools ] [ o.k. ] Cleaning output/debs for [ pine64 dev ] [ o.k. ] Cleaning [ arm-trusted-firmware-sunxi-mainline/allwinner-stable ] [ o.k. ] Compiling ATF [ o.k. ] Compiler version [ aarch64-linux-gnu-gcc 6.4.1 ] [ o.k. ] Started patching process for [ atf sunxi64-pine64-dev ] [ o.k. ] Looking for user patches in [ userpatches/atf/atf-sunxi64 ] [ warn ] * [l][c] add-SRAM-mapping-for-SCPI.patch [ failed ] [ warn ] * [l][c] enable-a53-errata-workaround.patch [ failed ] [ warn ] * [l][c] enable-additional-regulators.patch [ failed ] [ warn ] * [l][c] set-rsb-to-nonsec.patch [ failed ] make: *** No rule to make target 'bl31'. Stop. [ error ] ERROR in function compile_atf [ compilation.sh:59 ] [ error ] ATF compilation failed [ o.k. ] Process terminated Any patch that I can cherry-pick and fix the above issue (specifically regarded to Linux 4.x?) Thanks for any quick clue here. Anthony
Igor Posted March 26, 2018 Posted March 26, 2018 Upstream ATF branch has been changed, the label only. Something must be wrong with your build script that it was not updated. This is the problem and it has been fixed in development branch:https://github.com/armbian/build/commit/fca2785aef4a8ba7f84c7ae91e5d40c95a5a4832
