Brieuc Posted March 27, 2018 Posted March 27, 2018 Hello everyone I'm posting here what I did to run Armbian on a 4G LTE EM90 box. The image I'm using is armbian_5.37_S9xx_Debian_stretch_3.14.29_icewm_20171226. I extracted the dtb.img from the rooted android, I had to remove the beginning of the file to make it work. If you don't cut the file until you reach 0xD0 0D FE ED, you will get a magic number error when decompiling and Armbian will not boot with your fresh DTB. WIFI : The wifi is not well initialized at startup. You must precise to modprobe the firmware to load to AP6330 WIFI + BT4.0 chip Create the file /etc/modprobe.d/options.conf and add the following line : options dhd firmware_path=/lib/firmware/brcm/brcmfmac4330-sdio.bin nvram_path=/lib/firmware/brcm/nvram_ap6330.txt then open the file /etc/modules and add the following lines : cfg80211 dhd I always have issues with DNS with Armbian, to solve this, i'm running these commands (with root privileges) echo "nameserver 8.8.8.8" > /etc/resolvconf/resolv.conf.d/base resolvconf -u Bluetooth : With the DTB, the device shows up with hciconfig but scanning and connecting doesn't work. One more time it's a firmware issue, loading the correct one using patchram solves this problem. Edit /etc/rc.local with the these lines : brcm_patchram_plus --patchram /lib/firmware/brcm/BCM40183B2.hcd --enable_hci --bd_addr 11:22:33:44:55:66 --no2bytes --tosleep 1000 /dev/ttyS1 su -c 'hciattach /dev/ttyS1 any' exit 0 I haven't found the way to retrieve factory Bluetooth mac address, running the patchram command without the bd_addr option assign a different mac address witch is not the factory one. I would be interested if you know how to retrieve this address. 4G LTE modem : The cellular modem works out of the box, you just have to put a sim card, install wvdial. I'm pasting a copy of my configuration file /etc/wvdial.conf for reference : [Dialer Defaults] Init1 = ATZ Init2 = ATQ0 V1 E1 S0=0 Init3 = AT+CGDCONT=1,"IP","yourapnhere" Stupid Mode = true ISDN = 0 Modem Type = Analog Modem Password = " " New PPPD = yes Username = " " Phone = *99# Modem = /dev/ttyUSB0 Baud = 9600 The DTB and the configuration files can be found on my github repo. I hope this information is helpful. 1
guidol Posted March 27, 2018 Posted March 27, 2018 3 hours ago, Brieuc said: I extracted the dtb.img from the rooted android, I had to remove the beginning of the file to make it work. If you don't cut the file until you reach 0xD0 0D FE ED, you will get a magic number error when decompiling and Armbian will not boot with your fresh DTB. Many Thanks for the informations. Do you know/have a URL where we could find instructions how to extract/cut the .dtb?
Brieuc Posted March 27, 2018 Author Posted March 27, 2018 The hardest part is to root your device, once it is rooted it's pretty straightforward : install a terminal emulator on android using an apk on the terminal type su dd if=/dev/dtb of=/storage/sdcard0/Download/dtb.img Retrieve the dtb.img file on a computer and open it with an hexadecimal editor find the D00DFEED string and remove everything that is before this string You should then have a valid dtb file.
