NickFoley Posted March 28, 2018 Posted March 28, 2018 Hi Guys i searched the forums but could not find anything too similar. Any advice would be welcomed. Summarised version I am currently trying to install the OrangePiPC Debian Server image of Armbian on a custom H3 board emmc and getting a kernel error (Gave up waiting for root file system device. Common problems . Please see serial log at bottom for full information. TLDR VERSION Objective To install armbian directly onto the emmc. Board Information Board acquired from a manufactorir. It has USB_OTG, eth, Uarts, emmc and some other ports but NO SD card slot. Using OrangePiPC as it seems the most similar. How I am Installing 1) I mount the emmc directly to a Debian computer via using zador-blood-stained/fel-mass-storage. 2) I use etcher to burn the image to the emmc. 3) I plug in an external power supply and read the serial output (see log). 4) after the issue occurs it boot loops showing the same error. Suspected cause of Failure I suspect that because my hardware has differences to the OrangePiPc it is causing this issue and that i will probably need to build a custom image of armbian specifically for my board. If this is the case any information on how to proceed would be appreciated. Other information I have booted the OrangePiPc image using FEL boot. It boots up into Armbian and works correctly for around 10 minutes before experiencing a kernel panic. I have set up the development environment for compilation and am a developer so hopefully compiling a custom board/kernel/uboot should be doable for me. Thanks and sorry for the wall of text, Nick Serial Log Reveal hidden contents U-Boot SPL 2017.11-armbian (Jan 25 2018 - 07:56:32) DRAM: 512 MiB Failed to set core voltage! Can't set CPU frequency Trying to boot from MMC2 U-Boot 2017.11-armbian (Jan 25 2018 - 07:56:32 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi PC Plus DRAM: 512 MiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: phy interface0 eth0: ethernet@1c30000 starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 USB4: USB EHCI 1.00 USB5: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found scanning bus 4 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc1(part 0) is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3708 bytes read in 201 ms (17.6 KiB/s) ## Executing script at 43100000 U-boot loaded from eMMC or secondary SD Boot script loaded from mmc 152 bytes read in 163 ms (0 Bytes/s) MMC: no card present mmc_init: -123, time 2 ** Bad device mmc 0 ** 5070052 bytes read in 688 ms (7 MiB/s) 6968976 bytes read in 861 ms (7.7 MiB/s) Found mainline kernel configuration 32478 bytes read in 651 ms (47.9 KiB/s) 4179 bytes read in 1646 ms (2 KiB/s) Applying kernel provided DT fixup script (sun8i-h3-fixup.scr) ## Executing script at 44000000 ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 5069988 Bytes = 4.8 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 Loading Ramdisk to 49b2a000, end 49fffca4 ... OK reserving fdt memory region: addr=43000000 size=6e000 Loading Device Tree to 49ab9000, end 49b29fff ... OK Starting kernel ... Loading, please wait... starting version 232 Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. done. Gave up waiting for root file system device. Common problems: - Boot args (cat /proc/cmdline) - Check rootdelay= (did the system wait long enough?) - Missing modules (cat /proc/modules; ls /dev) ALERT! UUID=7f3d2ddb-0231-45dd-857c-81bc36aba60e does not exist. Dropping to a shell! Rebooting automatically due to panic= boot argument [ 48.173771] reboot: Restarting system U-Boot SPL 2017.11-armbian (Jan 25 2018 - 07:56:32) DRAM: 512 MiB Failed to set core voltage! Can't set CPU frequency Trying to boot from MMC2 U-Boot 2017.11-armbian (Jan 25 2018 - 07:56:32 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi PC Plus DRAM: 512 MiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 *** Warning - bad CRC, using default environment
Xalius Posted March 28, 2018 Posted March 28, 2018 The first thing to do is to compare the schematic of your board to the schematic of whatever board you take as a reference for the image and find out all the differences, then take that board's devicetree file for u-boot and for Linux and update it with all the differences. Most of the time it's power related things that are controlled in a different way and what GPIOs are used for various controls, different pin mux settings for busses that have multiple pinouts etc...
NickFoley Posted March 29, 2018 Author Posted March 29, 2018 Hi Xalius, thanks for the quick reply. I have started comparing both boards. However i do not have a particularly clear schematic of this custom board, so it is proving difficult. I have the base linux-image (and android image) that the manufacturer provided. Would i be able to use the uboot/kernel provided with it or be able to pull the devicetree information from it?
NickFoley Posted March 29, 2018 Author Posted March 29, 2018 Hi Xalius, I have started comparing the boards the best i can. I am looking at editing the OrangePiPcPlus.fex file found at https://github.com/armbian/build/blob/master/config/fex/orangepipcplus.fex. Just checking that this is the file containing the devicetree and the correct place to start editing? Thanks, Nick
Xalius Posted March 29, 2018 Posted March 29, 2018 On 3/29/2018 at 12:15 AM, NickFoley said: Hi Xalius, thanks for the quick reply. I have started comparing both boards. However i do not have a particularly clear schematic of this custom board, so it is proving difficult. I have the base linux-image (and android image) that the manufacturer provided. Would i be able to use the uboot/kernel provided with it or be able to pull the devicetree information from it? Expand Do you have the fex files (if BSP Linux/Android )for the custom board or the devicetree (if mainline Linux) file? You can extract the devicetree blob from your custom board's Linux image and use that maybe, what kernel is running on the custom board?
NickFoley Posted April 3, 2018 Author Posted April 3, 2018 On 3/29/2018 at 12:41 PM, Xalius said: Do you have the fex files (if BSP Linux/Android )for the custom board or the devicetree (if mainline Linux) file? You can extract the devicetree blob from your custom board's Linux image and use that maybe, what kernel is running on the custom board? Expand The kernel running on the mainline linux is 3.4.39. In the source of mainline linux i have found about 50 fex files. I have included a photo of the fex files below. In regards to the devicetree blob, I have found a bunch of dts files and two dtd files but no btd files. Not too sure what files to investigate.
tkaiser Posted April 3, 2018 Posted April 3, 2018 I fear you should invest some time into learning the basics first. 3.4.39 is not mainline and does also not use device-tree. The best source of information you have is sys_config.fex (that's HW description the 'Allwinner style'). There you should especially pay attention to the dram section and there clockspeed. You can also check for this with a running 3.4.39 kernel doing this cat /sys/devices/platform/sunxi-ddrfreq/devfreq/sunxi-ddrfreq/cur_freq Our OS images for Orange Pi use mostly 624 MHz DRAM clockspeed which could be way too much for 'random H3 Android device' out there. To get an idea how fex files need to be (slightly) adjusted to become fully Armbian compliant look at the second commit here: https://github.com/armbian/build/commits/700c4011286dd52500979dc82501f5a782c7518f/config/fex/orangepi-r1.fex
NickFoley Posted April 4, 2018 Author Posted April 4, 2018 Hi tkaiser. I am reading what i can find and am learning more by the day. I checked my board's clock speed. It is 576 MHz, so quite a bit slower. I figured because it runs an H3 it should be capable of the same clock-speeds as any other H3. Thanks for the commit history link. So what i gather you are suggesting is that I get the orangepi.fex and compare it to my sys_config.fex (included below), much like what they did in the link. Then try and compile a new image with the altered fex and see how it goes. Hopefully i am not too far off the mark. Reveal hidden contents ;H3 dolphin-p2 board application ;H3 dolphin-p2 board application ;--------------------------------------------------------------------------------------------------------- ; 说明: 脚本中的字符串区分大小写,用户可以修改"="后面的数值,但是不要修改前面的字符串 ; 描述gpio的形式:Port:端口+组内序号<功能分配><内部电阻状态><驱动能力><输出电平状态> ;--------------------------------------------------------------------------------------------------------- ;--------------------------------------------------------------------------------------------------------- ; matchine: the name must less then 16 byte ;--------------------------------------------------------------------------------------------------------- [product] version = "100" machine = "dolphin_p2" ;--------------------------------------------------------------------------------------------------------- ; debug_mode: 是否开启串口打印模式,1:开启(建议使用), 0:关闭 ; eraseflag: 是否擦除量产, 1:擦除量产(极度建议使用), 0:不擦除量产 ; next_work: usb量产工具(PhoenixUSBpro)量产完成工作状态,2:重启, 3:关机(极度建议使用), 4:重复量产 ;--------------------------------------------------------------------------------------------------------- [platform] debug_mode = 1 eraseflag = 1 next_work = 3 ;---------------------------------------------------------------------------------- ;[target] system bootup configuration ;boot_clock = CPU boot frequency, Unit: MHz ;storage_type = boot medium, 0-nand, 1-card0, 2-card2, -1(defualt)auto scan ;---------------------------------------------------------------------------------- [target] boot_clock = 1008 storage_type = -1 burn_key = 1 ;--------------------------------------------------------------------------------- ; uboot key detect enable ; 当keyen_flag = 1 时,支持按键检测 ; 当keyen_flag = 0 时,不支持 ;--------------------------------------------------------------------------------- [key_detect_en] keyen_flag = 0 ;--------------------------------------------------------------------------------- ;"一键进烧写功能"的按键值配置,按住位于min~max范围内的按键都可以强制进烧写 ; fel_key_max用于配置按键的最大键值 ; fel_key_min用于配置按键的最小键值 ;--------------------------------------------------------------------------------- [fel_key] fel_key_max =07 fel_key_min =02 ;---------------------------------------------------------------------------------- ;card boot ;logical_start用于配置启动卡上mbr的位置相对于SD卡sector 0的偏移,单位为sector(512byte) ;sprite_gpio0用于配置卡量产时指示灯所用的gpio ;---------------------------------------------------------------------------------- ;------------------------------------------------------------------------------- ; sprite_work_delay : ; sprite_err_delay : ; sprite_gpio0 : 卡量产、一键recovery状态指示灯 ; next_work : 卡量产完成,工作状态(默认关机) ;------------------------------------------------------------------------------- [card_boot] logical_start = 40960 sprite_work_delay = 500 sprite_err_delay = 200 sprite_gpio0 = port:PA15<1><default><default><default> next_work = 3 ;--------------------------------------------------------------------------------- ; used : 1: used this config, 0: not ; start_type : 1: start system directly when power supply, 0: wait IR/KEY to power on ; irkey_used : 1: ir key used, 0: not ; pmukey_used: 1: physical button used, 0: not ; pmukey_num : the index of gpio, only support PL ; led_power : 1: light, 0: off, the control gpio is PL10 ; led_state : 1: light, 0: off, default is 0 ;--------------------------------------------------------------------------------- [box_start_os] used = 1 start_type = 1 irkey_used = 1 pmukey_used = 0 pmukey_num = 0 led_power = 0 led_state = 0 ;------------------------------------------------------------------------------- ; boot阶段上电初始化GPIO ; used :模块使能端 置1:开启模块 置0:关闭模块 ; gpiox :上电初始化gpio (名称自定,但不能重复,并且GPIO允许可以多个) ; PH06 : 系统显示LED GPIO ;------------------------------------------------------------------------------- [boot_init_gpio] used = 1 gpio0 = port:PL10<1><default><default><0> gpio1 = port:PA15<1><default><default><1> gpioint1 = port:PL00<1><0><default><default> gpiowifi_en = port:PL01<1><0><default><default> ;---------------------------------------------------------------------------------- ; used: 模块使能端 1:开启模块 0:关闭模块 ; mode: 模式选择 1:一键进入OTA升级 2:一键恢复(通过sysrecovery分区来恢复) 其他值:无效 ; recovery_key : 按键配置 (例如:recovery_key= port:PH16<0><default>) ;---------------------------------------------------------------------------------- [recovery_para] used = 1 mode = 2 recovery_key = port:PL04<0><default><default><default> ;--------------------------------------------------------------------------------------------------------- ; if 1 == standby_mode, then support super standby; ; else, support normal standby. ;--------------------------------------------------------------------------------------------------------- [pm_para] standby_mode = 1 [card0_boot_para] card_ctrl = 0 card_high_speed = 1 card_line = 4 sdc_d1 = port:PF00<2><1><2><default> sdc_d0 = port:PF01<2><1><2><default> sdc_clk = port:PF02<2><1><2><default> sdc_cmd = port:PF03<2><1><2><default> sdc_d3 = port:PF04<2><1><2><default> sdc_d2 = port:PF05<2><1><2><default> [card2_boot_para] card_ctrl = 2 card_high_speed = 1 card_line = 8 sdc_cmd = port:PC06<3><1><2><default> sdc_clk = port:PC05<3><1><2><default> sdc_d0 = port:PC08<3><1><2><default> sdc_d1 = port:PC09<3><1><2><default> sdc_d2 = port:PC10<3><1><2><default> sdc_d3 = port:PC11<3><1><2><default> sdc_d4 = port:PC12<3><1><2><default> sdc_d5 = port:PC13<3><1><2><default> sdc_d6 = port:PC14<3><1><2><default> sdc_d7 = port:PC15<3><1><2><default> sdc_2xmode = 1 sdc_ddrmode = 1 [twi_para] twi_port = 0 twi_scl = port:PA11<2><default><default><default> twi_sda = port:PA12<2><default><default><default> [uart_para] uart_debug_port = 0 uart_debug_tx = port:PA04<2><1><default><default> uart_debug_rx = port:PA05<2><1><default><default> [force_uart_para] force_uart_port = 0 force_uart_tx = port:PF02<3><1><default><default> force_uart_rx = port:PF04<3><1><default><default> [jtag_para] jtag_enable = 1 jtag_ms = port:PA00<3><default><default><default> jtag_ck = port:PA01<3><default><default><default> jtag_do = port:PA02<3><default><default><default> jtag_di = port:PA03<3><default><default><default> [clock] pll_video = 297 pll_ve = 402 pll_periph0 = 600 pll_gpu = 576 pll_periph1 = 600 pll_de = 864 ;***************************************************************************** ;sdram configuration ; ; dram_tpr7[31:31]=1, use gpio type to detect dram type and ; dram_tpr7[31:31]=0, not use gpio type to detect dram type. ; ; if set ddr type auto detect, use dram_tpr7 to set dram clk. ; for example: if dram_tpr13[13:13] = 1, it use ; dram_tpr7[29:20] to set lpddr2 clk, ; dram_tpr7[19:10] to set lpddr3 clk, ; dram_tpr7[9:0] to set ddr3 or ddr3l clk. ;***************************************************************************** [dram_para] dram_clk = 576 dram_type = 3 dram_zq = 0x3b3bfb dram_odt_en = 0x1 dram_para1 = 0x10E40000 dram_para2 = 0x0000 dram_mr0 = 0x1840 dram_mr1 = 0x40 dram_mr2 = 0x18 dram_mr3 = 0x2 dram_tpr0 = 0x0048A192 dram_tpr1 = 0x01C2418D dram_tpr2 = 0x00076051 dram_tpr3 = 0 dram_tpr4 = 0 dram_tpr5 = 0 dram_tpr6 = 100 dram_tpr7 = 0x13890240 dram_tpr8 = 0 dram_tpr9 = 0 dram_tpr10 = 0 dram_tpr11 = 0x6aaa0000 dram_tpr12 = 0x7979 dram_tpr13 = 0x1802800 ;---------------------------------------------------------------------------------- ;os life cycle para configuration ;---------------------------------------------------------------------------------- ;--------------------------------------------------------------------------------------------------------- ; wakeup_src_para: ; sometimes, u would like to add more wakeup src in standby mode, these para will be ; help; ; u need to make sure the standby mode support the wakeup src. Also, some hw ; condition must be guaranteed. ; including: ; cpu_en: power on or off. ; 1: mean power on ; 0: mean power off ; cpu_freq: indicating lowest freq. unit is Mhz; ; dram selfresh_en: selfresh or not. ; 1: enable enter selfresh ; 0: disable enter selfresh ; dram_pll: if not enter selfresh, indicating lowest freq. unit is Mhz; ; wakeup_src: to make the scenario work, the wakeup src is needed. ;--------------------------------------------------------------------------------------------------------- [wakeup_src_para] cpu_en = 0 cpu_freq = 48 ; (cpu:apb:ahb) pll_ratio = 0x111 dram_selfresh_en = 1 dram_freq = 36 wakeup_src0 = wakeup_src_bt = port:PL06<6><default><default><0> ;---------------------------------------------------------------------------------- ;i2c configuration ;---------------------------------------------------------------------------------- [twi0] twi_used = 1 twi_scl = port:PA11<2><default><default><default> twi_sda = port:PA12<2><default><default><default> [twi1] twi_used = 1 twi_scl = port:PA18<3><default><default><default> twi_sda = port:PA19<3><default><default><default> [twi2] twi_used = 0 twi_scl = port:PE12<3><default><default><default> twi_sda = port:PE13<3><default><default><default> ;---------------------------------------------------------------------------------- ;uart configuration ;uart_type --- 2 (2 wire), 4 (4 wire), 8 (8 wire, full function) ;---------------------------------------------------------------------------------- [uart0] uart_used = 1 uart_port = 0 uart_type = 2 uart_tx = port:PA04<2><1><default><default> uart_rx = port:PA05<2><1><default><default> [uart1] uart_used = 1 uart_port = 1 uart_type = 4 uart_tx = port:PG06<2><1><default><default> uart_rx = port:PG07<2><1><default><default> uart_rts = port:PG08<2><1><default><default> uart_cts = port:PG09<2><1><default><default> [uart2] uart_used = 0 uart_port = 2 uart_type = 4 uart_tx = port:PA00<2><1><default><default> uart_rx = port:PA01<2><1><default><default> uart_rts = port:PA02<2><1><default><default> uart_cts = port:PA03<2><1><default><default> [uart3] uart_used = 0 uart_port = 3 uart_type = 4 uart_tx = port:PA13<3><1><default><default> uart_rx = port:PA14<3><1><default><default> uart_rts = port:PA15<3><1><default><default> uart_cts = port:PA16<3><1><default><default> ;---------------------------------------------------------------------------------- ;SPI controller configuration ;---------------------------------------------------------------------------------- [spi0] spi_used = 0 spi_cs_bitmap = 1 spi_mosi = port:PC00<3><default><default><default> spi_miso = port:PC01<3><default><default><default> spi_sclk = port:PC02<3><default><default><default> spi_cs0 = port:PC03<3><1><default><default> [spi1] spi_used = 0 spi_cs_bitmap = 1 spi_cs0 = port:PA13<2><1><default><default> spi_sclk = port:PA14<2><default><default><default> spi_mosi = port:PA15<2><default><default><default> spi_miso = port:PA16<2><default><default><default> ;---------------------------------------------------------------------------------- ;SPI device configuration ;---------------------------------------------------------------------------------- [spi_devices] spi_dev_num = 1 [spi_board0] modalias = m25p32 max_speed_hz = 33000000 bus_num = 0 chip_select = 0 mode = 0 ;---------------------------------------------------------------------------------- ;userspace gpio interface for android ;---------------------------------------------------------------------------------- [gpio_para] gpio_used = 1 gpio_num = 2 gpio_pin_1 = port:PL10<1><default><default><0> gpio_pin_2 = port:PA15<1><default><default><1> [led_assign] normal_led = "gpio_pin_2" standby_led = "gpio_pin_1" ;---------------------------------------------------------------------------------- ;thermal configuration ;ths_trip_count : temperature trigger number ;ths_trip_0 : first temperature trigger ;ths_trip_1 : second temperature trigger ;ths_trip_2 : third temperature trigger, when upto this temperature, system shutdown ;ths_trip_0_min : first temperature trigger's min freq ;ths_trip_0_max : first temperature trigger's max freq ;ths_trip_1_min : second temperature trigger's min freq ;ths_trip_1_max : second temperature trigger's max freq ;---------------------------------------------------------------------------------- [ths_para] ths_used = 1 ths_trip1_count = 7 ths_trip1_0 = 80 ths_trip1_1 = 85 ths_trip1_2 = 90 ths_trip1_3 = 95 ths_trip1_4 = 100 ths_trip1_5 = 105 ths_trip1_6 = 115 ths_trip1_4 = 0 ths_trip1_5 = 0 ths_trip1_6 = 0 ths_trip1_7 = 0 ths_trip1_0_min = 0 ths_trip1_0_max = 0 ths_trip1_1_min = 1 ths_trip1_1_max = 1 ths_trip1_2_min = 1 ths_trip1_2_max = 1 ths_trip1_3_min = 2 ths_trip1_3_max = 2 ths_trip1_4_min = 2 ths_trip1_4_max = 2 ths_trip1_5_min = 3 ths_trip1_5_max = 4 ths_trip1_6_min = 4 ths_trip1_6_max = 4 ths_trip2_count = 1 ths_trip2_0 = 115 ;---------------------------------------------------------------------------------- ;cooler_table cooler_count <=32 ;---------------------------------------------------------------------------------- [cooler_table] cooler_count = 5 cooler0 = "1200000 4 4294967295 0" cooler1 = "1200000 3 4294967295 0" cooler2 = "1200000 2 4294967295 0" cooler3 = "1200000 1 4294967295 0" cooler4 = "504000 1 4294967295 0" [nand0_para] nand_support_2ch = 0 nand_cache_level = 1 nand0_used = 1 nand0_we = port:PC00<2><0><1><default> nand0_ale = port:PC01<2><0><1><default> nand0_cle = port:PC02<2><0><1><default> nand0_ce1 = port:PC03<2><1><1><default> nand0_ce0 = port:PC04<2><1><1><default> nand0_nre = port:PC05<2><0><1><default> nand0_rb0 = port:PC06<2><1><1><default> nand0_rb1 = port:PC07<2><1><1><default> nand0_d0 = port:PC08<2><0><1><default> nand0_d1 = port:PC09<2><0><1><default> nand0_d2 = port:PC10<2><0><1><default> nand0_d3 = port:PC11<2><0><1><default> nand0_d4 = port:PC12<2><0><1><default> nand0_d5 = port:PC13<2><0><1><default> nand0_d6 = port:PC14<2><0><1><default> nand0_d7 = port:PC15<2><0><1><default> nand0_ndqs = port:PC16<2><0><1><default> ;----------------------------------------------------------------- ;auto_hpd - 1:need hotplud for hdmi/tv; 0:don't hotplud for lcd ;output_type - 0:none; 1:lcd; 2:tv; 4:hdmi; 8:vga (as default config in homlet) ;hdmi_channel- the display channel for hdmi (as default config in homlet) ;cvbs_channel- the display channel for cvbs (as default config in homlet) ;hdmi_mode - as default config for output of hdmi in homlet ;cvbs_mode - as default config for output of tv in homlet. 11:PAL; 14:NTSC ;check the definition(of hdmi/cvbs_mode) of disp_tv_mode in sunxi_display2.h ;hdmi_mode_check - disable/enable the function of checking hdmi mode, 0 is disable, 1 is enable ;----------------------------------------------------------------- [boot_disp] advert_disp = 0 auto_hpd = 1 output_type = 2 hdmi_channel = 0 hdmi_mode = 4 cvbs_channel = 1 cvbs_mode = 11 output_full = 1 hdmi_mode_check = 1 ;---------------------------------------------------------------------------------- ;disp init configuration ; ;disp_mode (0:screen0<screen0,fb0>; 1:screen1<screen1,fb0>) ;screenx_output_type (0:none; 1:lcd; 3:hdmi;) ;screenx_output_mode (used for hdmi output, 0:480i 1:576i 2:480p 3:576p 4:720p50) ; (5:720p60 6:1080i50 7:1080i60 8:1080p24 9:1080p50 10:1080p60) ;fbx format (0:ARGB 1:ABGR 2:RGBA 3:BGRA 5:RGB565 8:RGB888 12:ARGB4444 16:ARGB1555 18:RGBA5551) ;fbx_width,fbx_height (framebuffer horizontal/vertical pixels, fix to output resolution while equal 0) ;lcdx_backlight (lcd init backlight,the range:[0,256],default:197 ;---------------------------------------------------------------------------------- [disp_init] disp_init_enable = 1 disp_mode = 0 screen0_output_type = 3 screen0_output_mode = 4 screen1_output_type = 3 screen1_output_mode = 4 fb0_format = 0 fb0_width = 1280 fb0_height = 720 fb1_format = 0 fb1_width = 0 fb1_height = 0 ;---------------------------------------------------------------------------------- ;hdmi configuration ;---------------------------------------------------------------------------------- [hdmi_para] hdmi_used = 1 hdmi_power = "vcc-hdmi-18" [tv_para] tv_used = 1 tv_dac_used = 1 tv_dac_src0 = 0 ;---------------------------------------------------------------------------------- ;pwm config ;---------------------------------------------------------------------------------- [pwm0_para] pwm_used = 0 pwm_positive = port:PA05<3><0><default><default> ;------------------------------------------------------------------------------; ; 10/100/100Mbps Ethernet MAC Controller Configure ; ;------------------------------------------------------------------------------; ; Options: ; ; gmac_used --- 0: not used, 1: external phy, 2: internal phy ; ; gmac_powerx -- A[:B] A: axp channel, B: voltage value ; : If set gamc_phy to use internal PHY, do not config port ; ;------------------------------------------------------------------------------; ; MII RMII MII RMII MII RMII ; ; PD00 * PD06 * * PD12 * * ; ; PD01 * PD07 * PD13 * * ; ; PD02 * * PD08 * PD14 * ; ; PD03 * * PD09 * * PD15 * ; ; PD04 * PD10 * * PD16 * * ; ; PD05 * PD11 * * PD17 * * ; ;------------------------------------------------------------------------------; [gmac0] gmac_used = 2 ;gmac_rxd3 = port:PD00<2><default><3><default> ;gmac_rxd2 = port:PD01<2><default><3><default> ;gmac_rxd1 = port:PD02<2><default><3><default> ;gmac_rxd0 = port:PD03<2><default><3><default> ;gmac_rxclk = port:PD04<2><default><3><default> ;gmac_rxdv = port:PD05<2><default><3><default> ;gmac_rxerr = port:PD06<2><default><3><default> ;gmac_txd3 = port:PD07<2><default><3><default> ;gmac_txd2 = port:PD08<2><default><3><default> ;gmac_txd1 = port:PD09<2><default><3><default> ;gmac_txd0 = port:PD10<2><default><3><default> ;gmac_crs = port:PD11<2><default><3><default> ;gmac_txclk = port:PD12<2><default><3><default> ;gmac_txen = port:PD13<2><default><3><default> ;gmac_txerr = port:PD14<2><default><3><default> ;gmac_col = port:PD15<2><default><3><default> ;gmac_mdc = port:PD16<2><default><3><default> ;gmac_mdio = port:PD17<2><default><3><default> gmac_power1 = ;-------------------------------------------------------------------------------- ;vip (video input port) configuration ;vip_used: 0:disable 1:enable ;vip_mode: 0:sample one interface to one buffer 1:sample two interface to one buffer ;vip_dev_qty: The quantity of devices linked to capture bus ; ;vip_define_sensor_list: If you want use sensor detect function, please set vip_define_sensor_list = 1, and ; verify that file /system/etc/hawkview/sensor_list_cfg.ini is properly configured! ; ;vip_dev(x)_pos: sensor position, "rear" or "front", if vip_define_sensor_list = 1, ;vip_dev(x)_pos must be configured! ; ;vip_dev(x)_isp_used 0:not use isp 1:use isp ;vip_dev(x)_fmt: 0:yuv 1:bayer raw rgb ;vip_dev(x)_stby_mode: 0:not shut down power at standby 1:shut down power at standby ;vip_dev(x)_vflip: flip in vertical direction 0:disable 1:enable ;vip_dev(x)_hflip: flip in horizontal direction 0:disable 1:enable ;vip_dev(x)_iovdd: camera module io power handle string, pmu power supply ;vip_dev(x)_iovdd_vol: camera module io power voltage, pmu power supply ;vip_dev(x)_avdd: camera module analog power handle string, pmu power supply ;vip_dev(x)_avdd_vol: camera module analog power voltage, pmu power supply ;vip_dev(x)_dvdd: camera module core power handle string, pmu power supply ;vip_dev(x)_dvdd_vol: camera module core power voltage, pmu power supply ;vip_dev(x)_afvdd: camera module vcm power handle string, pmu power supply ;vip_dev(x)_afvdd_vol: camera module vcm power voltage, pmu power supply ;x indicates the index of the devices which are linked to the same capture bus ;fill voltage in uV, e.g. iovdd = 2.8V, vip_devx_iovdd_vol = 2800000 ;fill handle string as below: ;axp22_eldo3 ;axp22_dldo4 ;axp22_eldo2 ;fill handle string "" when not using any pmu power supply ;-------------------------------------------------------------------------------- [csi0] vip_used = 0 vip_mode = 0 vip_dev_qty = 1 vip_define_sensor_list = 0 vip_csi_pck = port:PE00<2><default><default><default> vip_csi_mck = port:PE01<2><default><default><default> vip_csi_hsync = port:PE02<2><default><default><default> vip_csi_vsync = port:PE03<2><default><default><default> vip_csi_d0 = port:PE04<2><default><default><default> vip_csi_d1 = port:PE05<2><default><default><default> vip_csi_d2 = port:PE06<2><default><default><default> vip_csi_d3 = port:PE07<2><default><default><default> vip_csi_d4 = port:PE08<2><default><default><default> vip_csi_d5 = port:PE09<2><default><default><default> vip_csi_d6 = port:PE10<2><default><default><default> vip_csi_d7 = port:PE11<2><default><default><default> vip_csi_sck = port:PE12<2><default><default><default> vip_csi_sda = port:PE13<2><default><default><default> vip_dev0_mname = "ov5640" vip_dev0_pos = "rear" vip_dev0_lane = 1 vip_dev0_twi_id = 0 vip_dev0_twi_addr = 0x78 vip_dev0_isp_used = 0 vip_dev0_fmt = 0 vip_dev0_stby_mode = 0 vip_dev0_vflip = 0 vip_dev0_hflip = 0 vip_dev0_iovdd = "" vip_dev0_iovdd_vol = 2800000 vip_dev0_avdd = "" vip_dev0_avdd_vol = 2800000 vip_dev0_dvdd = "" vip_dev0_dvdd_vol = 1500000 vip_dev0_afvdd = "" vip_dev0_afvdd_vol = 2800000 vip_dev0_power_en = vip_dev0_reset = vip_dev0_pwdn = vip_dev0_flash_en = vip_dev0_flash_mode = vip_dev0_af_pwdn = vip_dev0_act_used = 0 vip_dev0_act_name = "ad5820_act" vip_dev0_act_slave = 0x18 vip_dev1_mname = "" vip_dev1_pos = "front" vip_dev1_lane = 1 vip_dev1_twi_id = 0 vip_dev1_twi_addr = vip_dev1_isp_used = 0 vip_dev1_fmt = 1 vip_dev1_stby_mode = 0 vip_dev1_vflip = 0 vip_dev1_hflip = 0 vip_dev1_iovdd = "" vip_dev1_iovdd_vol = 2800000 vip_dev1_avdd = "" vip_dev1_avdd_vol = 2800000 vip_dev1_dvdd = "" vip_dev1_dvdd_vol = 1500000 vip_dev1_afvdd = "" vip_dev1_afvdd_vol = 2800000 vip_dev1_power_en = vip_dev1_reset = vip_dev1_pwdn = vip_dev1_flash_en = vip_dev1_flash_mode = vip_dev1_af_pwdn = ;-------------------------------------------------------------------------------- ;tv configuration ; ;-------------------------------------------------------------------------------- [tvout_para] tvout_used = tvout_channel_num = tv_en = [tvin_para] tvin_used = tvin_channel_num = ;---------------------------------------------------------------------------------- ;DE-Interlace configuration ;---------------------------------------------------------------------------------- [di_para] di_used = 1 ;-------------------------------------------------------------------------------- ; SDMMC PINS MAPPING | ; ------------------------------------------------------------------------------| ; Config Guide | ; sdc_used: 1-enable card, 0-disable card | ; sdc_detmode: card detect mode | ; 1-detect card by gpio polling | ; 2-detect card by gpio irq(must use IO with irq function) | ; 3-no detect, always in for boot card | ; 4-manually insert and remove by /proc/driver/sunxi-mmc.x/insert| ; sdc_buswidth: card bus width, 1-1bit, 4-4bit, 8-8bit | ; sdc_use_wp: 1-with write protect IO, 0-no write protect IO | ; sdc_isio: for sdio card | ; sdc_regulator: power control.if card supports UHS-I/DDR and HS200 timing for| ; SD3.0 or eMMC4.5, regulator must be configured. the value is | ; the ldo name of AXP221, eg: sdc_regulator = "axp22_eldo2" | ; other: GPIO Mapping configuration | ; ------------------------------------------------------------------------------| ; Note: | ; 1 if detmode=2, sdc_det's config=6 | ; else if detmode=1, sdc_det's config=0 | ; else sdc_det IO is not necessary | ; 2 if the customer wants to support UHS-I and HS200 features, he must provide| ; an independent power supply for the card. This is only used in platforms | ; that supports SD3.0 cards and eMMC4.4+ flashes | ;-------------------------------------------------------------------------------- [mmc0_para] sdc_used = 1 sdc_detmode = 1 sdc_buswidth = 4 sdc_clk = port:PF02<2><1><2><default> sdc_cmd = port:PF03<2><1><2><default> sdc_d0 = port:PF01<2><1><2><default> sdc_d1 = port:PF00<2><1><2><default> sdc_d2 = port:PF05<2><1><2><default> sdc_d3 = port:PF04<2><1><2><default> sdc_det = port:PF06<0><1><2><default> sdc_use_wp = 0 sdc_wp = sdc_isio = 0 sdc_regulator = "none" sdc_power_supply = "none" [mmc1_para] sdc_used = 1 sdc_detmode = 4 sdc_buswidth = 4 sdc_clk = port:PG00<2><1><2><default> sdc_cmd = port:PG01<2><1><2><default> sdc_d0 = port:PG02<2><1><2><default> sdc_d1 = port:PG03<2><1><2><default> sdc_d2 = port:PG04<2><1><2><default> sdc_d3 = port:PG05<2><1><2><default> sdc_det = sdc_use_wp = 0 sdc_wp = sdc_isio = 1 sdc_regulator = "none" sdc_power_supply = "none" sdc_2xmode = 1 sdc_ddrmode = 1 [mmc2_para] sdc_used = 0 sdc_detmode = 3 sdc_buswidth = 8 sdc_clk = port:PC05<3><1><2><default> sdc_cmd = port:PC06<3><1><2><default> sdc_d0 = port:PC08<3><1><2><default> sdc_d1 = port:PC09<3><1><2><default> sdc_d2 = port:PC10<3><1><2><default> sdc_d3 = port:PC11<3><1><2><default> sdc_d4 = port:PC12<3><1><2><default> sdc_d5 = port:PC13<3><1><2><default> sdc_d6 = port:PC14<3><1><2><default> sdc_d7 = port:PC15<3><1><2><default> emmc_rst = port:PC16<3><1><2><default> sdc_det = sdc_use_wp = 0 sdc_wp = sdc_isio = 0 sdc_regulator = "none" sdc_power_supply = "none" sdc_2xmode = 1 sdc_ddrmode = 1 ; ------------------------------------------------------------------------------| ; sim card configuration ;-------------------------------------------------------------------------------- [smc_para] smc_used = smc_rst = port:PA09<2><default><default><default> smc_vppen = port:PA20<3><default><default><default> smc_vppp = port:PA21<3><default><default><default> smc_det = port:PA10<2><default><default><default> smc_vccen = port:PA06<2><default><default><default> smc_sck = port:PA07<2><default><default><default> smc_sda = port:PA08<2><default><default><default> ;-------------------------------- ;[usbc0]:控制器0的配置。 ;usb_used:USB使能标志。置1,表示系统中USB模块可用,置0,则表示系统USB禁用。 ;usb_port_type:USB端口的使用情况。 0:device only;1:host only;2:OTG ;usb_detect_type:USB端口的检查方式。0:不做检测;1:vbus/id检查;2:id/dpdm检查 ;usb_id_gpio:USB ID pin脚配置。具体请参考gpio配置说明。 ;usb_det_vbus_gpio:USB DET_VBUS pin脚配置。具体请参考gpio配置说明。 ;usb_drv_vbus_gpio:USB DRY_VBUS pin脚配置。具体请参考gpio配置说明。 ;usb_det_vbus_gpio: "axp_ctrl",表示axp 提供 ;usb_restrict_gpio usb限流控制pin ;usb_restric_flag: usb限流标置 ;-------------------------------- ;-------------------------------- ;--- USB0控制标志 ;-------------------------------- [usbc0] usb_used = 1 usb_port_type = 1 usb_detect_type = 0 usb_id_gpio = usb_det_vbus_gpio = usb_drv_vbus_gpio = port:PL02<1><0><default><0> usb_host_init_state = 1 usb_restrict_gpio = usb_restric_flag = 0 usb_restric_voltage = 3550000 usb_restric_capacity= 5 usb_regulator_io = "nocare" usb_regulator_vol = 0 usb_not_suspend = 0 ;-------------------------------- ;--- USB1控制标志 ;-------------------------------- [usbc1] usb_used = 1 usb_drv_vbus_gpio = port:PL03<1><0><default><0> usb_restrict_gpio = usb_host_init_state = 1 usb_restric_flag = 0 usb_regulator_io = "nocare" usb_regulator_vol = 0 usb_not_suspend = 0 ;-------------------------------- ;--- USB2控制标志 ;-------------------------------- [usbc2] usb_used = 0 usb_drv_vbus_gpio = usb_restrict_gpio = usb_host_init_state = 1 usb_restric_flag = 0 usb_regulator_io = "nocare" usb_regulator_vol = 0 usb_not_suspend = 0 ;-------------------------------- ;--- USB3控制标志 ;-------------------------------- [usbc3] usb_used = 1 usb_drv_vbus_gpio = usb_restrict_gpio = usb_host_init_state = 0 usb_restric_flag = 0 usb_regulator_io = "nocare" usb_regulator_vol = 0 usb_not_suspend = 0 ;-------------------------------- ;--- USB Device ;-------------------------------- [usb_feature] vendor_id = 0x18D1 mass_storage_id = 0x0001 adb_id = 0x0002 manufacturer_name = "USB Developer" product_name = "Android" serial_number = "20080411" [msc_feature] vendor_name = "USB 2.0" product_name = "USB Flash Driver" release = 100 luns = 3 [serial_feature] serial_unique = 0 ;-------------------------------------------------------------------------------- ;wifi/bt/fm/gps/nfc modules configuration ;module_power0: axp used by module, "axp22_dldo1" - use dldo1, not use keep it empty ;module_power0_vol: power0 voltage, mv; ;module_select_pin0: select rtl8723bs or rtl8703as;module_select_pin1: select ap6181 or ap6210; ;chip_en: enable chip io ;lpo_use_apclk: ""- not use, "losc_out"- a23/33/H3, "ac10032k1"、"ac10032k2"、"ac10032k3"- a80 ;-------------------------------------------------------------------------------- [module_para] module_power0 = port:PL07<1><default><default><0> module_power0_vol = 1 module_power1 = module_power1_vol = module_power2 = module_power2_vol = module_power3 = module_power3_vol = module_select_pin0 = port:PD10<0><default><default><0> module_select_pin1 = port:PD11<0><default><default><0> chip_en = lpo_use_apclk = "losc_out" ;-------------------------------------------------------------------------------- ;wifi configuration ;wifi_sdc_id: 0- SDC0, 1- SDC1, 2- SDC2, 3- SDC3 ;wifi_usbc_id: 0- USB0, 1- USB1, 2- USB2 ;wifi_usbc_type: 1- EHCI(speed 2.0), 2- OHCI(speed 1.0) ;wl_reg_on: wifi function enable pin ;wl_host_wake: wlan device wake-up host pin ;wl_host_wake_invert: whether wl_host_wake use inverter between ap and module ; 0: not used, 1: used ;-------------------------------------------------------------------------------- [wifi_para] wifi_used = 1 wifi_sdc_id = 1 wifi_usbc_id = 3 wifi_usbc_type = 1 wl_reg_on = port:PL00<1><default><default><0> wl_host_wake = port:PA11<0><default><default><0> wl_host_wake_invert = 0 ;-------------------------------------------------------------------------------- ;bluetooth configuration ;bt_used: 0- no used, 1- used ;bt_uard_id: 0- uart0, 1- uart1, 2- uart2 ;bt_uart_baud: uart baud rate, unit: bps ;bt_rst_n: bt function enable io ;bt_wake: host wake-up bluetooth device ;bt_host_wake: bt device wake-up host ;bt_host_wake_invert: whether bt_host_wake use inverter between ap and module ; 0: not used, 1: used ;-------------------------------------------------------------------------------- [bt_para] bt_used = 1 bt_uart_id = 1 bt_uart_baud = 1500000 ;bt_rst_n = port:PL01<1><default><default><0> bt_wake = port:PA12<1><default><default><0> bt_host_wake = port:PL06<0><default><default><0> bt_host_wake_invert = 0 ;-------------------------------------------------------------------------------- ;daudio_master:1: SND_SOC_DAIFMT_CBM_CFM(codec clk & FRM master) use ; 2: SND_SOC_DAIFMT_CBS_CFM(codec clk slave & FRM master) not use ; 3: SND_SOC_DAIFMT_CBM_CFS(codec clk master & frame slave) not use ; 4: SND_SOC_DAIFMT_CBS_CFS(codec clk & FRM slave) use ;daudio_select:0 is pcm.1 is i2s ;audio_format: 1:SND_SOC_DAIFMT_I2S(standard i2s format). use ; 2:SND_SOC_DAIFMT_RIGHT_J(right justfied format). ; 3:SND_SOC_DAIFMT_LEFT_J(left justfied format) ; 4:SND_SOC_DAIFMT_DSP_A(pcm. MSB is available on 2nd BCLK rising edge after LRC rising edge). use ; 5:SND_SOC_DAIFMT_DSP_B(pcm. MSB is available on 1nd BCLK rising edge after LRC rising edge) ;signal_inversion:1:SND_SOC_DAIFMT_NB_NF(normal bit clock + frame) use ; 2:SND_SOC_DAIFMT_NB_IF(normal BCLK + inv FRM) ; 3:SND_SOC_DAIFMT_IB_NF(invert BCLK + nor FRM) use ; 4:SND_SOC_DAIFMT_IB_IF(invert BCLK + FRM) ;over_sample_rate: support 128fs/192fs/256fs/384fs/512fs/768fs ;sample_resolution :16bits/20bits/24bits ;word_select_size :16bits/20bits/24bits/32bits ;pcm_sync_period :16/32/64/128/256 ;msb_lsb_first :0: msb first; 1: lsb first ;sign_extend :0: zero pending; 1: sign extend ;slot_index :slot index: 0: the 1st slot - 3: the 4th slot ;slot_width :8 bit width / 16 bit width ;frame_width :0: long frame = 2 clock width; 1: short frame ;tx_data_mode :0: 16bit linear PCM; 1: 8bit linear PCM; 2: 8bit u-law; 3: 8bit a-law ;rx_data_mode :0: 16bit linear PCM; 1: 8bit linear PCM; 2: 8bit u-law; 3: 8bit a-law ;-------------------------------------------------------------------------------- [pcm0] daudio_used = 0 daudio_master = 4 daudio_select = 1 audio_format = 1 signal_inversion = 1 mclk_fs = 128 sample_resolution = 16 slot_width_select = 32 ;pcm_sync_period = 256 pcm_lrck_period = 32 pcm_lrckr_period = 1 msb_lsb_first = 0 sign_extend = 0 slot_index = 0 slot_width = 32 frame_width = 0 tx_data_mode = 0 rx_data_mode = 0 i2s_mclk = port:PA18<2><1><default><default> i2s_bclk = port:PA19<2><1><default><default> i2s_dout0 = port:PA20<2><1><default><default> i2s_din = port:PA21<2><1><default><default> [pcm1] daudio_used = 0 daudio_master = 4 daudio_select = 1 audio_format = 1 signal_inversion = 1 mclk_fs = 128 sample_resolution = 16 slot_width_select = 32 ;pcm_sync_period = 256 pcm_lrck_period = 32 pcm_lrckr_period = 1 msb_lsb_first = 0 sign_extend = 0 slot_index = 0 slot_width = 32 frame_width = 0 tx_data_mode = 0 rx_data_mode = 0 i2s_mclk = port:PG10<2><1><default><default> i2s_bclk = port:PG11<2><1><default><default> i2s_dout0 = port:PG12<2><1><default><default> i2s_din = port:PG13<2><1><default><default> [audio0] audio_used = 1 lineout_vol = 0x1f cap_vol = 0x5 audio_hp_ldo = none adcagc_used = 0 adcdrc_used = 0 dacdrc_used = 0 adchpf_used = 0 dachpf_used = 0 audio_pa_ctrl = port:PA16<1><default><default><0> [spdif0] spdif_used = 1 spdif_dout = port:PA17<2><1><default><default> [audiohub] hub_used = 0 codec_used = 1 spdif_used = 1 hdmi_used = 1 ;---------------------------------------------------------------------------------- ;ir rx --- infra remote configuration ;---------------------------------------------------------------------------------- [s_cir0] ir_used = 1 ir_rx = port:PL11<2><1><default><default> ir_power_key_code0 = 0x57 ir_addr_code0 = 0x9f00 ir_power_key_code1 = 0x1a ir_addr_code1 = 0xfb04 ir_power_key_code2 = 0x14 ir_addr_code2 = 0x7F80 ir_power_key_code3 = 0x15 ir_addr_code3 = 0x7F80 ir_power_key_code4 = 0x0b ir_addr_code4 = 0xF708 ir_power_key_code5 = 0x03 ir_addr_code5 = 0x00EF ir_power_key_code6 = 0x9f ir_addr_code6 = 0x4CB3 ir_power_key_code7 = 0x0a ir_addr_code7 = 0x7748 ir_power_key_code8 = 0x45 ir_addr_code8 = 0xbd02 ir_power_key_code9 = 0x4d ir_addr_code9 = 0xde21 ir_power_key_code10 = 0x18 ir_addr_code10 = 0xfe01 ir_power_key_code11 = 0x57 ir_addr_code11 = 0xff00 ir_power_key_code12 = 0x4d ir_addr_code12 = 0xff40 ir_power_key_code13 = 0x88 ir_addr_code13 = 0xdd22 ;---------------------------------------------------------------------------------- ;ir tx--- infra remote configuration ;---------------------------------------------------------------------------------- [cir] ir_used = 0 ir_tx = port:PH07<2><default><default><default> ;---------------------------------------------------------------------------------- ; dvfs voltage-frequency table configuration ; ; pmuic_type:0:none, 1:gpio, 2:i2c ; pmu_gpio0: gpio config. ; pmu_levelx: 0~9999: voltage(mV), 10000~90000:gpio0 state. voltage form high to low. ; ; extremity_freq(Hz): cpu extremity frequency when run benckmark or demo apk ; 1536MHz@1500mV with radiator, 1296MHz@1340mV without radiator ; max_freq: cpu maximum frequency, based on Hz, can not be more than 1200MHz ; min_freq: cpu minimum frequency, based on Hz, can not be less than 60MHz ; ; LV_count: count of LV_freq/LV_volt, must be < 16 ; ; LV1: core vdd is 1.50v if cpu frequency is (1296Mhz, 1536Mhz] ; LV2: core vdd is 1.34v if cpu frequency is (1200Mhz, 1296Mhz] ; LV3: core vdd is 1.32v if cpu frequency is (1008Mhz, 1200Mhz] ; LV4: core vdd is 1.20v if cpu frequency is (816Mhz, 1008Mhz] ; LV5: core vdd is 1.10v if cpu frequency is (648Mhz, 816Mhz] ; LV6: core vdd is 1.04v if cpu frequency is (0Mhz, 648Mhz] ; LV7: core vdd is 1.04v if cpu frequency is (0Mhz, 648Mhz] ; LV8: core vdd is 1.04v if cpu frequency is (0Mhz, 648Mhz] ; ;---------------------------------------------------------------------------------- [dvfs_table] pmuic_type = 0 pmu_gpio0 = port:PL06<1><1><2><1> pmu_level0 = 11300 pmu_level1 = 01100 ;extremity_freq = 1344000000 max_freq = 1008000000 min_freq = 480000000 boot_freq = 1008000000 LV_count = 8 LV1_freq = 1200000000 LV1_volt = 1300 LV2_freq = 1008000000 LV2_volt = 1200 LV3_freq = 0 LV3_volt = 1100 LV4_freq = 0 LV4_volt = 1100 LV5_freq = 0 LV5_volt = 1100 LV6_freq = 0 LV6_volt = 1100 LV7_freq = 0 LV7_volt = 1100 LV8_freq = 0 LV8_volt = 1100 [gpu_dvfs_table] G_LV_count = 3 G_LV0_freq = 312000000 G_LV0_volt = 1200000 G_LV1_freq = 384000000 G_LV1_volt = 1200000 G_LV2_freq = 456000000 G_LV2_volt = 1200000 ;---------------------------------------------------------------------------------- ;special gpio config for Board Vendor ID ;vid_used -- if board need distinguished by gpio,set '1';if not,set '0' ;vid_count -- the count of vendor id bits ;vid_bit_[0..3] -- gpio config for each bit of board vendor id ;example: vendor id hex format :{0x 0 0 1 0 } ; | | | | ; [vid_bit_3] [vid_bit_2] [vid_bit_1] [vid_bit_0] ;---------------------------------------------------------------------------------- [board_vendor] vid_used = 1 vid_count = 6 vid_bit_0 = port:PD16<0><1><default><default> vid_bit_1 = port:PD15<0><1><default><default> vid_bit_2 = port:PD14<0><1><default><default> vid_bit_3 = port:PD13<0><1><default><default> vid_bit_4 = port:PD12<0><1><default><default> vid_bit_5 = port:PD17<0><1><default><default> ;---------------------------------------------------------------------------------- ;virtual device ;virtual device for pinctrl testing ;device have pin PA1 PA2 ;---------------------------------------------------------------------------------- [Vdevice] Vdevice_used = 0 Vdevice_0 = port:PH10<5><1><2><default> Vdevice_1 = port:PH11<5><1><2><default> ;---------------------------------------------------------------------------------- ;s_uart0 config parameters ;s_uart_used --s_uart0 whether used for arisc debugging ;---------------------------------------------------------------------------------- [s_uart0] s_uart_used = 0 s_uart_tx = port:PL02<2><default><default><default> s_uart_rx = port:PL03<2><default><default><default> ;---------------------------------------------------------------------------------- ;s_rsb0 config parameters ;s_rsb_used --s_rsb0 whether used for arisc ;---------------------------------------------------------------------------------- [s_rsb0] s_rsb_used = 0 s_rsb_sck = port:PL00<2><1><2><default> s_rsb_sda = port:PL01<2><1><2><default> ;---------------------------------------------------------------------------------- ;s_jtag0 config parameters ;s_jtag0_used --s_jtag0 whether used for arisc ; ;---------------------------------------------------------------------------------- [s_jtag0] s_jtag_used = 0 s_jtag_tms = port:PL04<2><1><2><default> s_jtag_tck = port:PL05<2><1><2><default> s_jtag_tdo = port:PL06<2><1><2><default> s_jtag_tdi = port:PL07<2><1><2><default> ;---------------------------------------------------------------------------------- ;s_powchk cpus power check ;s_powchk_used --power check whether used for arisc in super standby ; bit31:enable power updat, bit1:wakeup when power state exception ; bit0:wakeup when power consumption exception ;s_power_reg the expected regs stand for power on/off state ;s_system_power the limit maxmum power consumption when super standby (unit: mw) ; ;---------------------------------------------------------------------------------- [s_powchk] s_powchk_used = 0x80000000 s_power_reg = 0x00000000 s_system_power = 50 ;---------------------------------------------------------------------------------- ;scr configuration ;---------------------------------------------------------------------------------- [sim0] scr_used = 1 scr_vccen = port:PA06<2><default><default><default> scr_slk = port:PA07<2><default><default><default> scr_sda = port:PA08<2><default><default><default> scr_rst = port:PA09<2><default><default><default> scr_det = port:PA10<2><default><default><default> ;-------------------------------------------------------------------------------- ;tsc configuration ;-------------------------------------------------------------------------------- [ts0] tsc_used = 1 tsc_clk = port:PE00<3><default><default><default> tsc_err = port:PE01<3><default><default><default> tsc_sync = port:PE02<3><default><default><default> tsc_dvld = port:PE03<3><default><default><default> tsc_d0 = port:PE04<3><default><default><default> tsc_d1 = port:PE05<3><default><default><default> tsc_d2 = port:PE06<3><default><default><default> tsc_d3 = port:PE07<3><default><default><default> tsc_d4 = port:PE08<3><default><default><default> tsc_d5 = port:PE09<3><default><default><default> tsc_d6 = port:PE10<3><default><default><default> tsc_d7 = port:PE11<3><default><default><default> ;-------------------------------------------------------------------------------- ;gpio key ;-------------------------------------------------------------------------------- [gpio_power_key] key_used = 0 key_io = port:PL04<6><default><default><0> ;---------------------------------------------------------------------------------- ; key para ; ; key_used --0:not used, 1:used ; key_cnt --how many key button attach to keyadc. ; key*_vol --the threshold of input voltage of key. ; ; For example: if key2_vol < $(keyadc value) < key3_vol, then key3 be reported. ;---------------------------------------------------------------------------------- [key_para] key_used = 0 key_cnt = 5 key1_vol = 222 key2_vol = 444 key3_vol = 666 key4_vol = 857 key5_vol = 2000 ;---------------------------------------------------------------------------------- ;display seven segment para ;---------------------------------------------------------------------------------- [d7s_para] d7s_used = 0 din_gpio = port:PD00<1><default><default><1> clk_gpio = port:PD01<1><default><default><1> stb_gpio = port:PD02<1><default><default><1>
tkaiser Posted April 4, 2018 Posted April 4, 2018 On 4/4/2018 at 8:50 AM, NickFoley said: I figured because it runs an H3 it should be capable of the same clock-speeds as any other H3 Expand Nope. Use crappy components on a board and this affects DRAM as well as CPU clockspeeds. Mentioning 'crappy'. It's like that: dram_clk = 576 pmuic_type = 0 max_freq = 1008000000 If these values are correct (who knows? Maybe the vendor just took someone else's work?) you might better choose an image for Sunvell R69 which is based on somewhat identical crappy hardware (no voltage regulation and unreliable DRAM). With any of the Orange Pi images that are made for better hardware (allowing to clock both CPU and DRAM higher) kernel panics are the best you can get.
NickFoley Posted April 5, 2018 Author Posted April 5, 2018 Bummer that it either has crappy components or uses incorrect values. Thanks for the reference to the Sunvel R69, i am building an image for it now and doing some reading. Regardless of picking an image for an Orange Pi or something like the Sunvell R69 the steps i need to do is as follows Compare their fex file with the sys_config.fex file from my board and copy over the differences. Meaning making the R69.fex match my sys_config.fex. Build the image for the R69 (with my changes). Flash it to the emmc. Hopefully then i will be able to actually boot past the kernel into Armbian. Correct me if i am missing some steps or over simplifying things. I appreciate the help
tkaiser Posted April 5, 2018 Posted April 5, 2018 The Sunvell R69 stuff should work out of the box (maybe leds and other secondary peripherals need adjustments). I built images some time ago available through web.archive.org -- simply search the forum. If the R69 stuff works you can also use bin2fex or fex2bin to adjust fex stuff (again: search the forum) where it's needed. But this way you remain on the smelly 3.4 kernel. For mainline Linux you would need to adopt a device-tree file (same idea: start with the R69 and adopt changes via dtc tool contained in device-tree-compiler package).
NickFoley Posted April 5, 2018 Author Posted April 5, 2018 Update: I flashed on Sunvell-r69 with legacy kernel 3.4.113 and it has booted up and seems to be running nicely (No change to fex files). I tried using the mainline kernel and it had the same issue. Will try building for Orange pi with the legacy kernel also to see if that could be the cause of the issue. EDIT: just saw your reply. Thanks for your help. I will have a play and let you know how i go. Thanks, Nick
