Hy,
I have a Tinkerboard with armbian ( debian jessie).
When I put behind my fiber router, and i do a speed test i have :
With iperf3 ==> download : 980M and upload : 240M
with speedtest-cli ==> More or less Results.
I wanted to conenct my Asus's card behind the ONT(Optical Termination Boxes) i can connect with pppoe or dhcp.
And in pppoe or dhcp my speed test show this :
With iperf3 ==> download : 110M and upload : 80M
I have tested with anorther Board, bananapi mé with Bananian and i have the same Results if   I put behind my fiber router so :
Someone can help me :)
Hello domoticity;
Odd. Have you checked the actual negotiated speed of your interface card (in the Tinkerboard)?
Looks like it is running in 100 Mbps instead. Check out my result:
[root@tinkerboard ~]# ethtool eth0
Settings for eth0:
	Supported ports: [ TP AUI BNC MII FIBRE ]
	Supported link modes:   10baseT/Half 10baseT/Full
	                        100baseT/Half 100baseT/Full
	                        1000baseT/Half 1000baseT/Full
	Supported pause frame use: No
	Supports auto-negotiation: Yes
	Advertised link modes:  10baseT/Half 10baseT/Full
	Advertised pause frame use: No
	Advertised auto-negotiation: Yes
	Link partner advertised link modes:  10baseT/Half 10baseT/Full
	Link partner advertised pause frame use: No
	Link partner advertised auto-negotiation: Yes
	Speed: 1000Mb/s <======================== HERE
	Duplex: Full
	Port: MII
	PHYAD: 0
	Transceiver: external
	Auto-negotiation: on
	Supports Wake-on: ug
	Wake-on: d
	Current message level: 0x0000003f (63)
			       drv probe link timer ifdown ifup
	Link detected: yes
Check your board result with # ethtool eth0 and let us know.
Ah. For what is worth, I have just finished a stress test here (I will replace the raspi with this tinkerboard) with netcat using the Tinkerboard both as the final destination (netcat running in the Tinkerboard) and NATting (using VLAN tag from two different VLANs).
I got effective routing throughput of ~ 930 Mbps from both up and downstream.
For completeness, this is a diagram of the test:
            |  Computer 1 |  | Tinkerboard |   |  Computer 2  |
            |  172.16.3.1 |  |             |   |  172.16.8.1  |
                |            eth0.3 | eth0.8                |
Untagged VLAN 3 |            VLAN 3 | VLAN 8                |Untagged VLAN 8
                |       172.16.3.13 | 172.16.8.13           |
                +-------+         Switch             +------+
The tinkerboard is acting as a NAT / Gateway for VLAN 8. So we have here:
# sysctl -w net.ipv4.ip_forward=1
# iptables -t nat -I POSTROUTING -o eth0.3 -j MASQUERADE
So in Computer 1 I have:
# cat /dev/zero | nc -l 3333
In computer 2:
# nc 172.16.3.1 > /dev/null
Monitoring the traffic in Tinkerboard, using # iptraf-ng
This puts double penalty over the Tinkerboard. Instead of just routing, which is easy-peasy, it also does makes the Traffic pass through the Netfilter engine, and remember that I'm using VLAN tag, meaning the same physical inetraface servers both endpoints.
But wait, there's more: I'm using the Asus-provided heatsink (Tony will surely roll his eyes) with temperatures not  going above 56 Celsius.
Even with this scenario I managed to pull ~930 Mbps of effective NAT traffic.
The reverse is also true. Scenario:
Tinkerboard:
# iptables -t nat -I PREROUTING -p tcp --dport 4444 -j DNAT --to 172.16.8.1
Computer 2:
# cat /dev/zero | nc -l 4444
Computer 1:
# nc 172.16.8.13 4444
The second test is even more costly, because it has both the NAT and the Destination NAT.
Still ~930 Mbps.
<3'ing my tinkerboard!!!! \o/
  On 4/8/2018 at 6:41 PM, Rfreire said:
Hello domoticity;
Settings for eth0:
	Duplex: Full
	Port: MII
	PHYAD: 0
	Wake-on: d
	Link detected: yes
                |            eth0.3 | eth0.8                |
In computer 2:
Tinkerboard:
Computer 2:
Computer 1:
Still ~930 Mbps.
Expand
Hy,
Thank you for you Answer
  Quote
root@diagbox:~# ethtool eth0
Settings for eth0:
        Supported pause frame use: Symmetric Receive-only
        Speed: 1000Mb/s   =======> it seems be in gigabit
        Duplex: Full
        Port: MII
        PHYAD: 0
        Wake-on: d
        Link detected: yes
Expand
When i do a speedtest in my lan behind the router, i have 9300M uo and down.
But when i what to replace my fiber box by my Asus Tinkerboard, plugging in directly behind my optical terminal
i have 150M maximum
Hello
question. Is the TinkerBoard routing / NATing to your internal LAN or is the TinkerBoard the final traffic destination?
If You are routing / NATing, how is your environment set up?
  On 4/8/2018 at 7:22 PM, Rfreire said:
Hello
Expand
the TinkerBoard is the final traffic destination.
thank you for your help :)
Hnm. Interesting.
ok then. Let's try to find the bottleneck.
1. Install the dstat package:
# apt-get install -y dstat
2. Leave running in a terminal:
# dstat -cdnm
3. Run the speed test
4. Send to this thread some 20-30 lines of dstat output while running the speed test
  On 4/8/2018 at 7:44 PM, Rfreire said:
Hnm. Interesting.
# dstat -cdnm
Expand
here the dstat
root@diagbox:/diagbox/scripts_sh# dstat -cdnm
----total-cpu-usage---- -dsk/total- -net/total- ------memory-usage-----
usr sys idl wai hiq siq| read  writ| recv  send| used  buff  cach  free
  0   1  99   0   0   0| 226k   47k|   0     0 | 115M 12.0M  177M 1702M
  1   1  98   0   0   0|   0     0 |5678B  172k| 115M 12.0M  177M 1702M
  0   0 100   0   0   0|   0     0 |6016B  176k| 115M 12.0M  177M 1702M
  0   0 100   0   0   0|   0     0 |3820B  179k| 115M 12.0M  177M 1702M
  0   0 100   0   0   0|   0     0 |4908B  189k| 115M 12.0M  177M 1702M
  0   0 100   0   0   0|   0     0 |4169B  179k| 115M 12.0M  177M 1702M
  0   0  99   0   0   0|   0     0 |3922B  182k| 115M 12.0M  177M 1702M
  0   0 100   0   0   0|   0     0 |3820B  176k| 115M 12.0M  177M 1702M
  0   0 100   0   0   0|   0     0 |4148B  176k| 115M 12.0M  177M 1702M
  0   0 100   0   0   0|   0     0 |3922B  176k| 115M 12.0M  177M 1702M
  0   0 100   0   0   0|   0     0 |3596B  170k| 115M 12.0M  177M 1702M
  0   1  99   0   0   0|   0     0 |3730B  176k| 115M 12.0M  177M 1702M
  1   5  95   0   0   0|   0     0 |6198B   49k| 115M 12.0M  177M 1702M
  0   0 100   0   0   0|   0     0 |2398B 2404B| 114M 12.0M  177M 1702M
  1   1  98   0   0   0|   0     0 |5217k   13k| 115M 12.0M  177M 1702M
  1   5  94   0   0   1|   0     0 | 108M  156k| 115M 12.0M  177M 1701M
  0   4  96   0   0   0|   0     0 |  85M  152k| 115M 12.0M  177M 1702M
  0   4  95   0   0   0|   0     0 |  83M  152k| 115M 12.0M  177M 1701M
  0   3  96   0   0   0|   0     0 |  85M  152k| 115M 12.0M  177M 1701M
  0   5  95   0   0   1|   0     0 |  90M  152k| 115M 12.0M  177M 1701M
  0   4  95   0   0   1|   0     0 |  86M  154k| 115M 12.0M  177M 1701M
  0   5  93   0   0   2|   0     0 | 100M  151k| 115M 12.0M  177M 1702M
  0   3  95   0   0   1|   0     0 |  89M  154k| 115M 12.0M  177M 1701M
  0   4  96   0   0   1|   0     0 |  82M  152k| 115M 12.0M  177M 1702M
  0   4  94   0   0   2|   0     0 | 102M  142k| 115M 12.0M  177M 1702M
  0   0 100   0   0   0|   0     0 |1626B 2866B| 115M 12.0M  177M 1702M
  0   0 100   0   0   0|   0     0 | 192B  668B| 115M 12.0M  177M 1702M
And here the speedtest for upload : ==> normally i have between 200 and 280M
root@diagbox:~# iperf3 -c bouygues.iperf.fr -4 -p 5202
Connecting to host bouygues.iperf.fr, port 5202
[  4] local 2.15.12.45 port 48846 connected to 89.84.1.222 port 5202
[ ID] Interval           Transfer     Bandwidth       Retr  Cwnd
[  4]   0.00-1.00   sec   129 KBytes  1.05 Mbits/sec    0   36.8 KBytes
[  4]   1.00-2.00   sec   105 KBytes   857 Kbits/sec    0   41.0 KBytes
[  4]   2.00-3.00   sec  90.5 KBytes   741 Kbits/sec    0   45.2 KBytes
[  4]   3.00-4.00   sec   102 KBytes   834 Kbits/sec    0   53.7 KBytes
[  4]   4.00-5.00   sec  84.8 KBytes   695 Kbits/sec    0   63.6 KBytes
[  4]   5.00-6.00   sec  84.8 KBytes   695 Kbits/sec    0   63.6 KBytes
[  4]   6.00-7.00   sec  84.8 KBytes   695 Kbits/sec    0   70.7 KBytes
[  4]   7.00-8.00   sec   113 KBytes   926 Kbits/sec    0   97.6 KBytes
[  4]   8.00-9.00   sec   130 KBytes  1.07 Mbits/sec    0   97.6 KBytes
[  4]   9.00-10.00  sec  65.0 KBytes   533 Kbits/sec    0   97.6 KBytes
[  4]   0.00-10.00  sec   988 KBytes   810 Kbits/sec    0             sender
[  4]   0.00-10.00  sec   877 KBytes   718 Kbits/sec                  receiver
and here the download : ==> normally i have between 880 and 940M
root@diagbox:~# iperf3 -c bouygues.iperf.fr -4 -p 5202 -R
Reverse mode, remote host bouygues.iperf.fr is sending
[  4] local 2.15.12.45 port 48850 connected to 89.84.1.222 port 5202
[  4]   0.00-1.00   sec  50.4 MBytes   423 Mbits/sec
[  4]   1.00-2.00   sec  41.6 MBytes   349 Mbits/sec
[  4]   2.00-3.00   sec  40.5 MBytes   339 Mbits/sec
[  4]   3.00-4.00   sec  41.1 MBytes   344 Mbits/sec
[  4]   4.00-5.00   sec  42.7 MBytes   358 Mbits/sec
[  4]   5.00-6.00   sec  43.6 MBytes   366 Mbits/sec
[  4]   6.00-7.00   sec  45.3 MBytes   380 Mbits/sec
[  4]   7.00-8.00   sec  47.0 MBytes   394 Mbits/sec
[  4]   8.00-9.00   sec  39.8 MBytes   334 Mbits/sec
[  4]   9.00-10.00  sec  51.7 MBytes   433 Mbits/sec
[  4]   0.00-10.00  sec   446 MBytes   374 Mbits/sec    0             sender
[  4]   0.00-10.00  sec   446 MBytes   374 Mbits/sec                  receiver
Hello there,
Check this snippet:
Well, I do see something entirely different here. dstat reports data traffic in BYTES. So, in order to get a rough approximation with BITS, multiply it times 9, you will get the approx. value in megabits.
So I do see RX performance ranging from 85 MBytes/s (~765 Mbps) to 108 MB/s (~972 Mbps). Which sounds to be very well in line with the NIC total possible bandwidth. I do see good (low) CPU usage
So, in total effective bandwidth, it seems that your Tinker is doing just fine. You should then investigate what else is going on with your iperf to account for your 'hidden' traffic :-)
Have a great week,
- RF.
I've learnt: Use the router supplied by your ISP.
I had a 100/20M fibre service and they supplied a Netgear gigabit wifi router. I replaced it with a Ubiquiti EdgeRouter X and all was well.
I upgraded to 1000/450M and they sent me a new router, despite the old one being gigabit on both WAN and LAN. The new one is a Fritzbox.
I thought I knew better and tried using my UBNT router, but it could never get the full speed. It was down in the 200 - 300M speeds.
I gave up and used the Fritzbox. Speeds went up to 950M.
There must be some weird network settings required to get the high speeds. I didn't get around to finding out what they were.
See if there are any differences in your fibre routers WAN interface settings or routing config compared to your Tinkerboard. Like MTU. Maybe you're fragmenting packets or something.
Expand
Hy
Thank you for your help.
For a Dhcp fiber connexion, which Mtu do you recommend?
Expand
I don't know, that's why I suggested checking the configuration on the supplied router that works.
It may be different for different connections.
Mine is in New Zealand, we have half a dozen different providers supplying different ONT's on the same "national" fibre network.
If you're lucky you might get some help from your ISP's technical service desk. Although most of the people you talk to there will probably say "sorry, unsupported device"
I have installed debian on tinker board. Tried ethtool to change the speed to 1000, it gives 100Mb/s  after reboot. Any idea to modify the setting to Speed: 1000Mb/s Duplex:Full and off in Autoneg? thx in advance.
