Somya Chawla Posted April 10, 2018 Posted April 10, 2018 Hey everyone, I am newbie to linux. I have loaded the armbian 5.14xx image in NAND Flash through nand sata install.However wifi is not working. how to fix this issue? I already used modprobe rtl8192cu command but it does not work.
Somya Chawla Posted April 11, 2018 Author Posted April 11, 2018 Am stuck how to make Wifi work. Please guys help me with it
Tido Posted April 11, 2018 Posted April 11, 2018 Please post your output of "lsmod" after these commands ? modprobe dhd or modprobe wifi_dummy
tkaiser Posted April 11, 2018 Posted April 11, 2018 On 4/11/2018 at 5:56 AM, Tido said: modprobe dhd Expand For a RealTek module? @Somya Chawla: 'I did it correctly but it doesn't work' is nothing anyone can help you with. You better start to describe the problem you run into and provide output of 'armbianmonitor -u'.
Somya Chawla Posted April 11, 2018 Author Posted April 11, 2018 When entered modprobe dhd am getting the error "could not insert 'dhd' : No such device
