In fact I had already tried this method and it does not work :-(
sudo python2 setup.py install
[sudo] Mot de passe de magatst :
Dropping privileges to those of magatst: 1000
* Running build
Traceback (most recent call last):
  File "setup.py", line 119, in <module>
    sys.exit(main())
  File "setup.py", line 104, in main
    command.run_all(opts)
  File "/home/magatst/calibre-3.21.0/setup/__init__.py", line 236, in run_all
    self.run_cmd(self, opts)
  File "/home/magatst/calibre-3.21.0/setup/__init__.py", line 228, in run_cmd
    self.run_cmd(scmd, opts)
  File "/home/magatst/calibre-3.21.0/setup/__init__.py", line 232, in run_cmd
    cmd.run(opts)
  File "/home/magatst/calibre-3.21.0/setup/build.py", line 247, in run
    self.env = init_env()
  File "/home/magatst/calibre-3.21.0/setup/build.py", line 142, in init_env
    from setup.build_environment import msvc, is64bit, win_inc, win_lib, NMAKE
  File "/home/magatst/calibre-3.21.0/setup/build_environment.py", line 77, in <module>
    qraw = subprocess.check_output([QMAKE, '-query']).decode('utf-8')
  File "/usr/lib/python2.7/subprocess.py", line 567, in check_output
    process = Popen(stdout=PIPE, *popenargs, **kwargs)
  File "/usr/lib/python2.7/subprocess.py", line 711, in __init__
    errread, errwrite)
  File "/usr/lib/python2.7/subprocess.py", line 1343, in _execute_child
    raise child_exception
OSError: [Errno 2] No such file or directory
magatst@orangepione:~/calibre-3.21.0$
