Sometimes it's unclear if my Nanopi NEO2 is still running, or fully locked up / FUBAR. Ping and SSH give no result. As there is no HDMI, I have no way to check if it's still there.
So I was thinking: can I let the green LED flash each x seconds as a sign of life?
Quote from Igor: "Both are accessible via sysfs, green is configurable while blue is not lit and reacting to anything. ".
So a crontab script that writes something to /sys/ <LED> ... ?
Feedback appreciated.
4 hours ago, chrisf said:
If your LED's are in the device tree,
echo "heartbeat" > /sys/class/leds/xxxx/trigger
OK, thanks, I will try ... as soon as I get my Neo2 back to life ... ;-)
Wow ... it works! Thank you
The blue LED:
root@nanopineo2:~# echo 1 > /sys/class/leds/nanopi:blue:status/brightness
root@nanopineo2:~# echo 0 > /sys/class/leds/nanopi:blue:status/brightness
The green LED
root@nanopineo2:~# echo 0 > /sys/class/leds/nanopi:green:pwr/brightness
root@nanopineo2:~# echo 1 > /sys/class/leds/nanopi:green:pwr/brightness
root's crontab:
* * * * *    /root/green-on-and-off.sh
with that script being:
for i in `seq 10`
do
    sleep 0.2
    sleep 0.2
done
Result: green LED is always on, but flashes off/on 10 times each minute. That's a good sign of life for me.
