berre Posted April 26, 2018 Share Posted April 26, 2018 (edited) Hi, I've got several tinkerboards that I've reproduced this problem on. I'm using the tinkerboard to do network tests, this includes iperf3 traffic,dns querys (dig), https and http (echoping), and ping. All of these tests runs against IPv6 targets and IPv4 targets. These tests are scheduled to very frequently (every other minute or so). To begin with, all tests run fine.. I get good results (~1gbit throughput / low latency / no packet loss). However, after running the tests for 15-20min, suddenly all traffic will more or less stop working (80-90% packet loss). This is no matter what I'm pinging, can be the local router, some target on the internet... Doesn't matter. The only way to make the problem go away is to reboot the board, after this I can resume the tests until the problem is reproduced again after 15-20min. So I started troubleshooting, this is how far I've gotten so far: When the problem occurs, disable ALL tests and check connectivty. Still extremely bad but maybe slighly better (~30-50 packet loss on both IPv4/IPv6) Only run IPv4 tests (disable IPv6 tests) <--- This works, now I'm not getting the sudden extreme packet loss scenarios. (Hence the topic). Also worth mentioning is that I'm still having IPv6 enabled, it's just the tests themselves being disabled. Only run IPv6 tests <--- Problem is reproduced Update to latest kernel and nightly build - Problem still reproduced Run the same exact test on 6 other tinkerboards - Problem reproduced on all boards I've been tailing dmesg/journal, there's not a single message/error/warning/whatever when this problem happens.. Which is confusing. Right now: I'm trying to isolate which of the IPv6 tests are causing the problem (DNS,HTTP,HTTPS,ICMP or iperf3 traffic)....... But in the meantime I wanted to check for help here. Logs: Spoiler # cat * [ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Linux version 4.14.36-rockchip (root@xeon) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #22 SMP PREEMPT Thu Apr 26 06:41:40 CEST 2018 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: Rockchip RK3288 Tinker Board [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] On node 0 totalpages: 524288 [ 0.000000] free_area_init_node: node 0, pgdat c14e4780, node_mem_map eedfa000 [ 0.000000] Normal zone: 1728 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 196608 pages, LIFO batch:31 [ 0.000000] HighMem zone: 327680 pages, LIFO batch:31 [ 0.000000] percpu: Embedded 18 pages/cpu @eed8d000 s41048 r8192 d24488 u73728 [ 0.000000] pcpu-alloc: s41048 r8192 d24488 u73728 alloc=18*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 522560 [ 0.000000] Kernel command line: consoleblank=0 scandelay root=UUID=733e4b8f-8cdf-42ad-85a4-6d5487409e6e rw console=ttyS2,115200n8 rootfstype=ext4 loglevel=1 rootwait usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 2048752K/2097152K available (13312K kernel code, 968K rwdata, 3200K rodata, 1024K init, 4636K bss, 48400K reserved, 0K cma-reserved, 1310720K highmem) [ 0.000000] Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .text : 0xc0008000 - 0xc0e00000 (14304 kB) .init : 0xc1300000 - 0xc1400000 (1024 kB) .data : 0xc1400000 - 0xc14f20d8 ( 969 kB) .bss : 0xc14ff4a8 - 0xc1986584 (4637 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] ftrace: allocating 46476 entries in 137 pages [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Tasks RCU enabled. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000022] Switching to timer-based delay loop, resolution 41ns [ 0.001852] Console: colour dummy device 80x30 [ 0.001893] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000) [ 0.001912] pid_max: default: 32768 minimum: 301 [ 0.002071] Security Framework initialized [ 0.002082] Yama: becoming mindful. [ 0.002163] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.002181] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.003192] CPU: Testing write buffer coherency: ok [ 0.003583] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500 [ 0.008015] Setting up static identity map for 0x100000 - 0x100060 [ 0.010019] Hierarchical SRCU implementation. [ 0.014140] smp: Bringing up secondary CPUs ... [ 0.022648] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501 [ 0.030866] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502 [ 0.039091] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503 [ 0.039290] smp: Brought up 1 node, 4 CPUs [ 0.039305] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.039313] CPU: All CPU(s) started in SVC mode. [ 0.041277] devtmpfs: initialized [ 0.056607] random: get_random_u32 called from bucket_table_alloc+0x194/0x22c with crng_init=0 [ 0.057410] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0 [ 0.057771] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns [ 0.057793] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.058171] xor: measuring software checksum speed [ 0.067427] arm4regs : 1040.000 MB/sec [ 0.077565] 8regs : 800.000 MB/sec [ 0.087710] 32regs : 800.000 MB/sec [ 0.087720] xor: using function: arm4regs (1040.000 MB/sec) [ 0.087737] pinctrl core: initialized pinctrl subsystem [ 0.088894] NET: Registered protocol family 16 [ 0.091887] DMA: preallocated 2048 KiB pool for atomic coherent allocations [ 0.093832] cpuidle: using governor ladder [ 0.093889] cpuidle: using governor menu [ 0.095144] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.095192] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.124799] gpio gpiochip0: (gpio0): added GPIO chardev (254:0) [ 0.124939] gpiochip_setup_dev: registered GPIOs 0 to 23 on device: gpiochip0 (gpio0) [ 0.125391] gpio gpiochip1: (gpio1): added GPIO chardev (254:1) [ 0.125522] gpiochip_setup_dev: registered GPIOs 24 to 55 on device: gpiochip1 (gpio1) [ 0.125923] gpio gpiochip2: (gpio2): added GPIO chardev (254:2) [ 0.126107] gpiochip_setup_dev: registered GPIOs 56 to 87 on device: gpiochip2 (gpio2) [ 0.126511] gpio gpiochip3: (gpio3): added GPIO chardev (254:3) [ 0.126627] gpiochip_setup_dev: registered GPIOs 88 to 119 on device: gpiochip3 (gpio3) [ 0.127070] gpio gpiochip4: (gpio4): added GPIO chardev (254:4) [ 0.127191] gpiochip_setup_dev: registered GPIOs 120 to 151 on device: gpiochip4 (gpio4) [ 0.127608] gpio gpiochip5: (gpio5): added GPIO chardev (254:5) [ 0.127726] gpiochip_setup_dev: registered GPIOs 152 to 183 on device: gpiochip5 (gpio5) [ 0.128149] gpio gpiochip6: (gpio6): added GPIO chardev (254:6) [ 0.128277] gpiochip_setup_dev: registered GPIOs 184 to 215 on device: gpiochip6 (gpio6) [ 0.128681] gpio gpiochip7: (gpio7): added GPIO chardev (254:7) [ 0.128814] gpiochip_setup_dev: registered GPIOs 216 to 247 on device: gpiochip7 (gpio7) [ 0.129170] gpio gpiochip8: (gpio8): added GPIO chardev (254:8) [ 0.129299] gpiochip_setup_dev: registered GPIOs 248 to 263 on device: gpiochip8 (gpio8) [ 0.191649] raid6: int32x1 gen() 85 MB/s [ 0.209071] raid6: int32x1 xor() 93 MB/s [ 0.226397] raid6: int32x2 gen() 125 MB/s [ 0.243651] raid6: int32x2 xor() 107 MB/s [ 0.261405] raid6: int32x4 gen() 105 MB/s [ 0.278424] raid6: int32x4 xor() 83 MB/s [ 0.295700] raid6: int32x8 gen() 117 MB/s [ 0.312930] raid6: int32x8 xor() 91 MB/s [ 0.312940] raid6: using algorithm int32x2 gen() 125 MB/s [ 0.312947] raid6: .... xor() 107 MB/s, rmw enabled [ 0.312955] raid6: using intx1 recovery algorithm [ 0.313521] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vsys-regulator[0]' [ 0.314133] of_get_named_gpiod_flags: parsed 'gpio' property of node '/sdmmc-regulator[0]' - status (0) [ 0.315087] iommu: Adding device ff930000.vop to group 0 [ 0.315215] iommu: Adding device ff940000.vop to group 1 [ 0.315345] iommu: Adding device ff9a0000.vpu-service to group 2 [ 0.315468] iommu: Adding device ff9c0000.hevc-service to group 3 [ 0.318167] SCSI subsystem initialized [ 0.318466] usbcore: registered new interface driver usbfs [ 0.318544] usbcore: registered new interface driver hub [ 0.318689] usbcore: registered new device driver usb [ 0.318824] Linux video capture interface: v2.00 [ 0.318909] pps_core: LinuxPPS API ver. 1 registered [ 0.318918] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.318945] PTP clock support registered [ 0.319813] Advanced Linux Sound Architecture Driver Initialized. [ 0.320562] Bluetooth: Core ver 2.22 [ 0.320629] NET: Registered protocol family 31 [ 0.320638] Bluetooth: HCI device and connection manager initialized [ 0.320656] Bluetooth: HCI socket layer initialized [ 0.320671] Bluetooth: L2CAP socket layer initialized [ 0.320719] Bluetooth: SCO socket layer initialized [ 0.321385] NetLabel: Initializing [ 0.321395] NetLabel: domain hash size = 128 [ 0.321402] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 0.321507] NetLabel: unlabeled traffic allowed by default [ 0.322629] clocksource: Switched to clocksource arch_sys_counter [ 0.447500] VFS: Disk quotas dquot_6.6.0 [ 0.447644] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.447926] FS-Cache: Loaded [ 0.448206] CacheFiles: Loaded [ 0.465658] NET: Registered protocol family 2 [ 0.466658] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 0.466782] TCP bind hash table entries: 8192 (order: 5, 163840 bytes) [ 0.467044] TCP: Hash tables configured (established 8192 bind 8192) [ 0.467192] UDP hash table entries: 512 (order: 2, 24576 bytes) [ 0.467254] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes) [ 0.467629] NET: Registered protocol family 1 [ 0.468297] RPC: Registered named UNIX socket transport module. [ 0.468307] RPC: Registered udp transport module. [ 0.468315] RPC: Registered tcp transport module. [ 0.468323] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.468700] Trying to unpack rootfs image as initramfs... [ 0.795853] Freeing initrd memory: 3544K [ 0.797388] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available [ 0.800145] Initialise system trusted keyrings [ 0.800382] workingset: timestamp_bits=14 max_order=19 bucket_order=5 [ 0.810630] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.812000] FS-Cache: Netfs 'nfs' registered for caching [ 0.812895] NFS: Registering the id_resolver key type [ 0.812926] Key type id_resolver registered [ 0.812934] Key type id_legacy registered [ 0.812956] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.814003] Key type cifs.spnego registered [ 0.814025] Key type cifs.idmap registered [ 0.814039] ntfs: driver 2.1.32 [Flags: R/W]. [ 0.814863] JFS: nTxBlock = 8192, nTxLock = 65536 [ 0.821692] SGI XFS with security attributes, no debug enabled [ 0.824522] aufs 4.14-20171218 [ 0.832890] NET: Registered protocol family 38 [ 0.833069] async_tx: api initialized (async) [ 0.833085] Key type asymmetric registered [ 0.833094] Asymmetric key parser 'x509' registered [ 0.833179] bounce: pool size: 64 pages [ 0.833249] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 0.833449] io scheduler noop registered [ 0.833460] io scheduler deadline registered [ 0.833531] io scheduler cfq registered (default) [ 0.833541] io scheduler mq-deadline registered [ 0.833550] io scheduler kyber registered [ 0.842016] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.842034] dma-pl330 ff250000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 0.843126] dma-pl330 ffb20000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.843144] dma-pl330 ffb20000.dma-controller: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10 [ 0.844013] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 0.846682] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A [ 0.847966] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 39, base_baud = 1500000) is a 16550A [ 0.849223] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 40, base_baud = 1500000) is a 16550A [ 0.849445] console [ttyS2] enabled [ 0.850731] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 41, base_baud = 1500000) is a 16550A [ 0.851656] dw-apb-uart: probe of ff1c0000.serial failed with error -28 [ 0.857040] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0e8037c) [ 0.857647] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0e8037c) [ 0.857769] rockchip-drm display-subsystem: failed to bind ff980000.hdmi (ops 0xc0e8190c): -517 [ 0.858180] rockchip-drm display-subsystem: master bind failed: -517 [ 0.858529] usbcore: registered new interface driver udl [ 0.862847] brd: module loaded [ 0.875515] loop: module loaded [ 0.875614] lkdtm: No crash points registered, enable through debugfs [ 0.878128] rockchip-spi ff130000.spi: chipselect 0 already in use [ 0.878145] spi_master spi2: spi_device register error /spi@ff130000/spidev@1 [ 0.878162] spi_master spi2: Failed to create SPI device for /spi@ff130000/spidev@1 [ 0.879893] mdio_bus fixed-0: GPIO lookup for consumer reset [ 0.879905] mdio_bus fixed-0: using lookup tables for GPIO lookup [ 0.879918] mdio_bus fixed-0: lookup for GPIO reset failed [ 0.879947] libphy: Fixed MDIO Bus: probed [ 0.879955] tun: Universal TUN/TAP device driver, 1.6 [ 0.881999] rk_gmac-dwmac ff290000.ethernet: PTP uses main clock [ 0.882060] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing [ 0.883166] PPP generic driver version 2.4.2 [ 0.883870] usbcore: registered new interface driver rt2500usb [ 0.883947] usbcore: registered new interface driver rt73usb [ 0.884019] usbcore: registered new interface driver rt2800usb [ 0.884095] usbcore: registered new interface driver rtl8xxxu [ 0.884173] usbcore: registered new interface driver rndis_wlan [ 0.884183] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 0.884256] usbcore: registered new interface driver pegasus [ 0.884330] usbcore: registered new interface driver rtl8150 [ 0.884405] usbcore: registered new interface driver r8152 [ 0.884474] usbcore: registered new interface driver asix [ 0.884537] usbcore: registered new interface driver ax88179_178a [ 0.884650] usbcore: registered new interface driver cdc_ether [ 0.884720] usbcore: registered new interface driver dm9601 [ 0.884811] usbcore: registered new interface driver smsc75xx [ 0.884890] usbcore: registered new interface driver smsc95xx [ 0.884955] usbcore: registered new interface driver net1080 [ 0.885021] usbcore: registered new interface driver rndis_host [ 0.885087] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 0.885179] usbcore: registered new interface driver cdc_ncm [ 0.885246] usbcore: registered new interface driver cdc_mbim [ 0.885736] dwc2 ff540000.usb: ff540000.usb supply vusb_d not found, using dummy regulator [ 0.885829] dwc2 ff540000.usb: ff540000.usb supply vusb_a not found, using dummy regulator [ 0.989783] dwc2 ff540000.usb: DWC OTG Controller [ 0.989826] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1 [ 0.989876] dwc2 ff540000.usb: irq 47, io mem 0xff540000 [ 0.990266] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.990281] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.990293] usb usb1: Product: DWC OTG Controller [ 0.990304] usb usb1: Manufacturer: Linux 4.14.36-rockchip dwc2_hsotg [ 0.990314] usb usb1: SerialNumber: ff540000.usb [ 0.991223] hub 1-0:1.0: USB hub found [ 0.991302] hub 1-0:1.0: 1 port detected [ 0.992319] dwc2 ff580000.usb: ff580000.usb supply vusb_d not found, using dummy regulator [ 0.992410] dwc2 ff580000.usb: ff580000.usb supply vusb_a not found, using dummy regulator [ 0.992713] dwc2 ff580000.usb: dwc2_check_param_tx_fifo_sizes: Invalid parameter g-tx-fifo-size, setting to default average [ 0.992747] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM [ 0.994542] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.994553] ehci-platform: EHCI generic platform driver [ 0.994947] ehci-platform ff500000.usb: EHCI Host Controller [ 0.995260] ehci-platform ff500000.usb: new USB bus registered, assigned bus number 2 [ 0.995439] ehci-platform ff500000.usb: irq 46, io mem 0xff500000 [ 1.001664] ehci-platform ff500000.usb: USB 2.0 started, EHCI 1.00 [ 1.001990] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.002005] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.002017] usb usb2: Product: EHCI Host Controller [ 1.002028] usb usb2: Manufacturer: Linux 4.14.36-rockchip ehci_hcd [ 1.002038] usb usb2: SerialNumber: ff500000.usb [ 1.002902] hub 2-0:1.0: USB hub found [ 1.002971] hub 2-0:1.0: 1 port detected [ 1.004037] usbcore: registered new interface driver cdc_acm [ 1.004047] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.004149] usbcore: registered new interface driver usblp [ 1.004228] usbcore: registered new interface driver cdc_wdm [ 1.004357] usbcore: registered new interface driver usb-storage [ 1.004488] usbcore: registered new interface driver usbserial [ 1.004554] usbcore: registered new interface driver usbserial_generic [ 1.004653] usbserial: USB Serial support registered for generic [ 1.004732] usbcore: registered new interface driver keyspan [ 1.004789] usbserial: USB Serial support registered for Keyspan - (without firmware) [ 1.004834] usbserial: USB Serial support registered for Keyspan 1 port adapter [ 1.004879] usbserial: USB Serial support registered for Keyspan 2 port adapter [ 1.004922] usbserial: USB Serial support registered for Keyspan 4 port adapter [ 1.004999] usbcore: registered new interface driver option [ 1.005044] usbserial: USB Serial support registered for GSM modem (1-port) [ 1.005248] usbcore: registered new interface driver oti6858 [ 1.005293] usbserial: USB Serial support registered for oti6858 [ 1.005365] usbcore: registered new interface driver qcserial [ 1.005421] usbserial: USB Serial support registered for Qualcomm USB modem [ 1.005511] usbcore: registered new interface driver sierra [ 1.005566] usbserial: USB Serial support registered for Sierra USB modem [ 1.006879] usbcore: registered new interface driver iforce [ 1.006980] usbcore: registered new interface driver xpad [ 1.007157] usbcore: registered new interface driver usbtouchscreen [ 1.008112] i2c /dev entries driver [ 1.009253] rk3x-i2c ff140000.i2c: Initialized RK3xxx I2C bus at f0fad000 [ 1.010189] rk3x-i2c ff150000.i2c: Initialized RK3xxx I2C bus at f0faf000 [ 1.011191] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at f0fb1000 [ 1.012202] rk3x-i2c ff170000.i2c: Initialized RK3xxx I2C bus at f0fb3000 [ 1.014207] rk808 0-001b: chip id: 0x0 [ 1.018265] rk808 0-001b: GPIO lookup for consumer dvs [ 1.018278] rk808 0-001b: using device tree for GPIO lookup [ 1.018335] of_get_named_gpiod_flags: parsed 'dvs-gpios' property of node '/i2c@ff650000/pmic@1b[0]' - status (0) [ 1.018620] rk808 0-001b: GPIO lookup for consumer dvs [ 1.018632] rk808 0-001b: using device tree for GPIO lookup [ 1.018700] of_get_named_gpiod_flags: parsed 'dvs-gpios' property of node '/i2c@ff650000/pmic@1b[1]' - status (0) [ 1.018861] DCDC_REG1: supplied by vcc_sys [ 1.020072] DCDC_REG2: supplied by vcc_sys [ 1.021027] DCDC_REG3: supplied by vcc_sys [ 1.021462] DCDC_REG4: supplied by vcc_sys [ 1.022277] LDO_REG1: supplied by vcc_sys [ 1.023994] LDO_REG2: supplied by vcc_sys [ 1.025193] LDO_REG3: supplied by vcc_sys [ 1.026550] LDO_REG4: supplied by vcc_io [ 1.027968] LDO_REG5: supplied by vcc_io [ 1.029349] LDO_REG6: supplied by vcc_io [ 1.030772] LDO_REG7: supplied by vcc_sys [ 1.032165] LDO_REG8: supplied by vcc_sys [ 1.033518] SWITCH_REG1: supplied by vcc_io [ 1.034006] SWITCH_REG2: supplied by vcc_io [ 1.038346] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0 [ 1.038994] rk3x-i2c ff650000.i2c: Initialized RK3xxx I2C bus at f0fb5000 [ 1.040024] i2c i2c-2: of_i2c: invalid addr=0 on /i2c@ff660000/af-controller@0 [ 1.040039] i2c i2c-2: Failed to create I2C device for /i2c@ff660000/af-controller@0 [ 1.040057] i2c i2c-2: of_i2c: invalid addr=0 on /i2c@ff660000/m24c08@50 [ 1.040069] i2c i2c-2: Failed to create I2C device for /i2c@ff660000/m24c08@50 [ 1.040097] rk3x-i2c ff660000.i2c: Initialized RK3xxx I2C bus at f0fb7000 [ 1.040951] IR NEC protocol handler initialized [ 1.040960] IR RC5(x/sz) protocol handler initialized [ 1.040967] IR RC6 protocol handler initialized [ 1.040973] IR JVC protocol handler initialized [ 1.040980] IR Sony protocol handler initialized [ 1.040986] IR SANYO protocol handler initialized [ 1.040993] IR Sharp protocol handler initialized [ 1.041000] IR MCE Keyboard/mouse protocol handler initialized [ 1.041006] IR XMP protocol handler initialized [ 1.041138] usbcore: registered new interface driver uvcvideo [ 1.041146] USB Video Class driver (1.1.1) [ 1.046214] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com [ 1.046499] device-mapper: raid: Loading target version 1.13.0 [ 1.046826] Bluetooth: HCI UART driver ver 2.3 [ 1.046838] Bluetooth: HCI UART protocol H4 registered [ 1.046847] Bluetooth: HCI UART protocol ATH3K registered [ 1.046855] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 1.046963] usbcore: registered new interface driver bfusb [ 1.047052] usbcore: registered new interface driver btusb [ 1.047062] Bluetooth: Generic Bluetooth SDIO driver ver 0.1 [ 1.048039] of: /cpus/cpu@501: Couldn't find opp node [ 1.050672] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 500000 KHz [ 1.050844] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 600000 KHz [ 1.051950] pwrseq_simple sdio-pwrseq: GPIO lookup for consumer reset [ 1.051954] pwrseq_simple sdio-pwrseq: using device tree for GPIO lookup [ 1.051968] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0) [ 1.051991] pwrseq_simple sdio-pwrseq: GPIO lookup for consumer reset [ 1.051994] pwrseq_simple sdio-pwrseq: using device tree for GPIO lookup [ 1.052009] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[1]' - status (0) [ 1.052146] sdhci: Secure Digital Host Controller Interface driver [ 1.052148] sdhci: Copyright(c) Pierre Ossman [ 1.052151] Synopsys Designware Multimedia Card Interface Driver [ 1.052596] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode. [ 1.052616] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller. [ 1.052622] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a [ 1.052648] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo [ 1.052731] dwmmc_rockchip ff0c0000.dwmmc: GPIO lookup for consumer cd [ 1.052735] dwmmc_rockchip ff0c0000.dwmmc: using device tree for GPIO lookup [ 1.052740] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/dwmmc@ff0c0000[0]' [ 1.052745] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/dwmmc@ff0c0000[0]' [ 1.052748] dwmmc_rockchip ff0c0000.dwmmc: using lookup tables for GPIO lookup [ 1.052752] dwmmc_rockchip ff0c0000.dwmmc: lookup for GPIO cd failed [ 1.052756] dwmmc_rockchip ff0c0000.dwmmc: GPIO lookup for consumer wp [ 1.052759] dwmmc_rockchip ff0c0000.dwmmc: using device tree for GPIO lookup [ 1.052763] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@ff0c0000[0]' [ 1.052766] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@ff0c0000[0]' [ 1.052769] dwmmc_rockchip ff0c0000.dwmmc: using lookup tables for GPIO lookup [ 1.052772] dwmmc_rockchip ff0c0000.dwmmc: lookup for GPIO wp failed [ 1.064963] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 1.077233] dwmmc_rockchip ff0d0000.dwmmc: 'num-slots' was deprecated. [ 1.077490] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode. [ 1.077524] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller. [ 1.077539] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a [ 1.077637] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo [ 1.077662] dwmmc_rockchip ff0d0000.dwmmc: 'clock-freq-min-max' property was deprecated. [ 1.077783] dwmmc_rockchip ff0d0000.dwmmc: GPIO lookup for consumer wp [ 1.077793] dwmmc_rockchip ff0d0000.dwmmc: using device tree for GPIO lookup [ 1.077807] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@ff0d0000[0]' [ 1.077819] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@ff0d0000[0]' [ 1.077828] dwmmc_rockchip ff0d0000.dwmmc: using lookup tables for GPIO lookup [ 1.077837] dwmmc_rockchip ff0d0000.dwmmc: lookup for GPIO wp failed [ 1.077925] dwmmc_rockchip ff0d0000.dwmmc: allocated mmc-pwrseq [ 1.077936] mmc_host mmc1: card is non-removable. [ 1.089654] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 1.101947] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.102188] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/act-led[0]' - status (0) [ 1.102211] no flags found for gpios [ 1.102396] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/heartbeat-led[0]' - status (0) [ 1.102416] no flags found for gpios [ 1.102569] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/pwr-led[0]' - status (0) [ 1.102624] no flags found for gpios [ 1.103113] ledtrig-cpu: registered to indicate activity on CPUs [ 1.103216] hidraw: raw HID events driver (C) Jiri Kosina [ 1.104247] usbcore: registered new interface driver usbhid [ 1.104254] usbhid: USB HID core driver [ 1.104654] ashmem: initialized [ 1.107150] usbcore: registered new interface driver snd-usb-audio [ 1.110913] Initializing XFRM netlink socket [ 1.111475] NET: Registered protocol family 10 [ 1.112950] Segment Routing with IPv6 [ 1.113035] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 1.113184] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 1.113756] NET: Registered protocol family 17 [ 1.113768] NET: Registered protocol family 15 [ 1.113796] Bridge firewalling registered [ 1.113866] Bluetooth: RFCOMM socket layer initialized [ 1.113881] Bluetooth: RFCOMM ver 1.11 [ 1.113889] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 1.113895] Bluetooth: HIDP socket layer initialized [ 1.113920] 8021q: 802.1Q VLAN Support v1.8 [ 1.113931] lib80211: common routines for IEEE802.11 drivers [ 1.113938] lib80211_crypt: registered algorithm 'NULL' [ 1.113941] lib80211_crypt: registered algorithm 'WEP' [ 1.113944] lib80211_crypt: registered algorithm 'CCMP' [ 1.113946] lib80211_crypt: registered algorithm 'TKIP' [ 1.113959] Key type dns_resolver registered [ 1.114136] ThumbEE CPU extension supported. [ 1.114143] Registering SWP/SWPB emulation handler [ 1.114447] Loading compiled-in X.509 certificates [ 1.114876] Btrfs loaded, crc32c=crc32c-generic [ 1.119435] random: fast init done [ 1.123516] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0e8037c) [ 1.123747] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0e8037c) [ 1.123849] dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.00a with HDCP (DWC MHL PHY) [ 1.124147] rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc0e8190c) [ 1.124152] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 1.124154] [drm] No driver support for vblank timestamp query. [ 1.124178] [drm] Cannot find any crtc or sizes [ 1.124433] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0 [ 1.124917] rk_gmac-dwmac ff290000.ethernet: PTP uses main clock [ 1.124969] rk_gmac-dwmac ff290000.ethernet: clock input or output? (input). [ 1.124974] rk_gmac-dwmac ff290000.ethernet: TX delay(0x30). [ 1.124978] rk_gmac-dwmac ff290000.ethernet: RX delay(0x10). [ 1.124986] rk_gmac-dwmac ff290000.ethernet: integrated PHY? (no). [ 1.125047] rk_gmac-dwmac ff290000.ethernet: clock input from PHY [ 1.130057] rk_gmac-dwmac ff290000.ethernet: init for RGMII [ 1.130080] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 1.130084] rk_gmac-dwmac ff290000.ethernet: Ring mode enabled [ 1.130088] rk_gmac-dwmac ff290000.ethernet: DMA HW capability register supported [ 1.130091] rk_gmac-dwmac ff290000.ethernet: Normal descriptors [ 1.130094] rk_gmac-dwmac ff290000.ethernet: RX Checksum Offload Engine supported [ 1.130097] rk_gmac-dwmac ff290000.ethernet: COE Type 2 [ 1.130100] rk_gmac-dwmac ff290000.ethernet: TX Checksum insertion supported [ 1.130103] rk_gmac-dwmac ff290000.ethernet: Wake-Up On Lan supported [ 1.130126] rk_gmac-dwmac ff290000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 1.130166] mdio_bus stmmac-0: GPIO lookup for consumer reset [ 1.130169] mdio_bus stmmac-0: using lookup tables for GPIO lookup [ 1.130174] mdio_bus stmmac-0: lookup for GPIO reset failed [ 1.130192] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@ff290000[0]' - status (0) [ 1.132265] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [ 1.132944] mmc1: new high speed SDIO card at address 0001 [ 1.172284] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0) [ 1.322596] usb 2-1: new high-speed USB device number 2 using ehci-platform [ 1.366641] usb 1-1: new high-speed USB device number 2 using dwc2 [ 1.546159] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610 [ 1.546173] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 1.546183] usb 1-1: Product: USB2.0 Hub [ 1.547020] hub 1-1:1.0: USB hub found [ 1.547376] hub 1-1:1.0: 4 ports detected [ 1.660389] usb 2-1: config 1 has an invalid interface number: 255 but max is 6 [ 1.660401] usb 2-1: config 1 has no interface number 6 [ 1.661627] usb 2-1: New USB device found, idVendor=0bda, idProduct=481a [ 1.661639] usb 2-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2 [ 1.661649] usb 2-1: Product: USB Audio [ 1.661658] usb 2-1: Manufacturer: Generic [ 1.661667] usb 2-1: SerialNumber: 201405280001 [ 1.707971] dwmmc_rockchip ff0c0000.dwmmc: Successfully tuned phase to 170 [ 1.707998] mmc0: new ultra high speed SDR104 SDHC card at address aaaa [ 1.708751] mmcblk0: mmc0:aaaa SC16G 14.8 GiB [ 1.710856] mmcblk0: p1 [ 2.152703] [drm] Cannot find any crtc or sizes [ 2.169112] libphy: stmmac: probed [ 2.169120] mdio_bus stmmac-0:00: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:00, irq=POLL) [ 2.169125] mdio_bus stmmac-0:01: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:01, irq=POLL) [ 2.169664] OF: /sound/simple-audio-card,codec: could not get #sound-dai-cells for /hdmi@ff980000 [ 2.169669] asoc-simple-card sound: parse error -22 [ 2.169680] asoc-simple-card: probe of sound failed with error -22 [ 2.170075] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-keys/button@0[0]' - status (0) [ 2.170092] gpio-5 (GPIO Key Power): gpiod_set_debounce: missing set() or set_config() operations [ 2.170208] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 2.170901] rk808-rtc rk808-rtc: setting system clock to 2018-04-26 17:50:35 UTC (1524765035) [ 2.171238] vcc_sd: supplied by vcc_io [ 2.171275] vcc_sd: disabling [ 2.171282] ALSA device list: [ 2.171285] No soundcards found. [ 2.171398] ttyS2 - failed to request DMA [ 2.173631] Freeing unused kernel memory: 1024K [ 2.199882] random: systemd-udevd: uninitialized urandom read (16 bytes read) [ 2.200185] random: systemd-udevd: uninitialized urandom read (16 bytes read) [ 2.200236] random: systemd-udevd: uninitialized urandom read (16 bytes read) [ 2.203343] random: udevadm: uninitialized urandom read (16 bytes read) [ 2.204478] random: udevadm: uninitialized urandom read (16 bytes read) [ 2.204515] random: udevadm: uninitialized urandom read (16 bytes read) [ 2.204854] random: udevadm: uninitialized urandom read (16 bytes read) [ 2.205134] random: udevadm: uninitialized urandom read (16 bytes read) [ 2.205685] random: udevadm: uninitialized urandom read (16 bytes read) [ 2.205931] random: udevadm: uninitialized urandom read (16 bytes read) [ 3.773487] input: Generic USB Audio as /devices/platform/ff500000.usb/usb2/2-1/2-1:1.255/0003:0BDA:481A.0001/input/input1 [ 3.826311] hid-generic 0003:0BDA:481A.0001: input,hiddev96,hidraw0: USB HID v1.11 Device [Generic USB Audio] on usb-ff500000.usb-1/input255 [ 4.040551] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 4.317712] ip_tables: (C) 2000-2006 Netfilter Core Team [ 4.336319] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN) [ 4.336891] systemd[1]: Detected architecture arm. [ 4.352214] systemd[1]: Set hostname to <chprobe.chprobe20>. [ 4.610606] systemd[1]: Listening on fsck to fsckd communication Socket. [ 4.620865] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 4.632100] systemd[1]: Listening on Syslog Socket. [ 4.642983] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 4.653760] systemd[1]: Reached target Paths. [ 4.660995] systemd[1]: Listening on udev Control Socket. [ 4.668902] systemd[1]: Listening on udev Kernel Socket. [ 4.786939] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro [ 5.028305] Adding 131068k swap on /var/swap. Priority:-2 extents:2 across:163836k SS [ 5.359696] r8723bs: module is from the staging directory, the quality is unknown, you have been warned. [ 5.363121] RTL8723BS: module init start [ 5.363126] RTL8723BS: rtl8723bs v4.3.5.5_12290.20140916_BTCOEX20140507-4E40 [ 5.363129] RTL8723BS: rtl8723bs BT-Coex version = BTCOEX20140507-4E40 [ 5.364286] pnetdev = ecc84000 [ 5.441275] rk3288-crypto ff8a0000.cypto-controller: Crypto Accelerator successfully registered [ 5.459545] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1 [ 5.459740] mali ffa30000.gpu: Protected mode not available [ 5.462371] mali ffa30000.gpu: Probed as mali0 [ 5.478873] RTL8723BS: rtw_ndev_init(wlan0) [ 5.479760] RTL8723BS: module init ret =0 [ 5.667019] Generic PHY stmmac-0:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-0:00, irq=POLL) [ 5.668116] rk_gmac-dwmac ff290000.ethernet eth0: PTP not supported by HW [ 5.668277] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 5.721731] systemd-journald[462]: Received request to flush runtime journal from PID 1 [ 5.932801] ttyS0 - failed to request DMA [ 6.699167] rk_gmac-dwmac ff290000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx [ 6.699196] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 6.930818] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 6.939602] rtl8723bs: acquire FW from file:rtlwifi/rtl8723bs_nic.bin [ 6.970575] random: crng init done [ 8.171488] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 8.313319] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 13.190909] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 7133.446817] Console: switching to colour frame buffer device 240x67 [ 7133.479694] rockchip-drm display-subsystem: fb0: frame buffer device [ 7190.371312] usb 1-1.3: new low-speed USB device number 3 using dwc2 [ 7190.456870] usb 1-1.3: New USB device found, idVendor=04b4, idProduct=0101 [ 7190.456895] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 7190.456905] usb 1-1.3: Product: SteelS쀁Љ̒DATA [ 7190.456914] usb 1-1.3: Manufacturer: DATACOMP [ 7190.482443] input: DATACOMP SteelS쀁Љ̒DATA as /devices/platform/ff540000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:04B4:0101.0002/input/input2 [ 7190.535211] hid-generic 0003:04B4:0101.0002: input,hidraw1: USB HID v1.00 Keyboard [DATACOMP SteelS쀁Љ̒DATA] on usb-ff540000.usb-1.3/input0 [ 7190.549332] input: DATACOMP SteelS쀁Љ̒DATA as /devices/platform/ff540000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:04B4:0101.0003/input/input3 [ 7190.601690] hid-generic 0003:04B4:0101.0003: input,hidraw2: USB HID v1.00 Device [DATACOMP SteelS쀁Љ̒DATA] on usb-ff540000.usb-1.3/input1 Ip: Forwarding: 2 4465589 total packets received 3 with invalid addresses 0 forwarded 0 incoming packets discarded 4430024 incoming packets delivered 4419405 requests sent out 1 dropped because of missing route 400 reassemblies required 200 packets reassembled ok 200 fragments received ok 400 fragments created Icmp: 3861 ICMP messages received 4 input ICMP message failed ICMP input histogram: destination unreachable: 8 echo requests: 1 echo replies: 3852 4714 ICMP messages sent 0 ICMP messages failed ICMP output histogram: destination unreachable: 12 echo requests: 4701 echo replies: 1 IcmpMsg: InType0: 3852 InType3: 8 InType8: 1 OutType0: 1 OutType3: 12 OutType8: 4701 Tcp: 5189 active connection openings 15 passive connection openings 85 failed connection attempts 648 connection resets received 0 connections established 4909117 segments received 6718651 segments sent out 11742 segments retransmitted 0 bad segments received 3819 resets sent Udp: 142758 packets received 12 packets to unknown port received 0 packet receive errors 224164 packets sent 0 receive buffer errors 0 send buffer errors IgnoredMulti: 319 UdpLite: TcpExt: 4211 TCP sockets finished time wait in fast timer 2052 delayed acks sent 50 delayed acks further delayed because of locked socket Quick ack mode was activated 234 times 3336722 packet headers predicted 190903 acknowledgments not containing data payload received 1269305 predicted acknowledgments TCPSackRecovery: 6239 Detected reordering 47 times using SACK Detected reordering 19 times using time stamp 1 congestion windows fully recovered without slow start 19 congestion windows partially recovered using Hoe heuristic TCPDSACKUndo: 1 18 congestion windows recovered without slow start after partial ack TCPLostRetransmit: 372 10733 fast retransmits TCPTimeouts: 164 TCPLossProbes: 322 TCPLossProbeRecovery: 61 TCPSackRecoveryFail: 24 TCPDSACKOldSent: 234 TCPDSACKRecv: 48 7 connections reset due to unexpected data 395 connections reset due to early user close 117 connections aborted due to timeout TCPDSACKIgnoredNoUndo: 43 TCPSackShifted: 15649 TCPSackMerged: 98714 TCPSackShiftFallback: 16185 TCPRcvCoalesce: 208314 TCPOFOQueue: 51026 TCPSpuriousRtxHostQueues: 1 TCPAutoCorking: 9730 TCPSynRetrans: 569 TCPOrigDataSent: 3795142 TCPHystartTrainDetect: 92 TCPHystartTrainCwnd: 4291 TCPHystartDelayDetect: 303 TCPHystartDelayCwnd: 13885 IpExt: OutMcastPkts: 96 InBcastPkts: 6689 InOctets: 22120467674 OutOctets: 5622450149 OutMcastOctets: 14760 InBcastOctets: 549177 InNoECTPkts: 16498074 InECT0Pkts: 1302 PING 192.168.0.1 (192.168.0.1) 56(84) bytes of data. no answer yet for icmp_seq=1 no answer yet for icmp_seq=2 no answer yet for icmp_seq=3 no answer yet for icmp_seq=4 64 bytes from 192.168.0.1: icmp_seq=5 ttl=64 time=0.707 ms no answer yet for icmp_seq=6 no answer yet for icmp_seq=7 no answer yet for icmp_seq=8 no answer yet for icmp_seq=9 64 bytes from 192.168.0.1: icmp_seq=10 ttl=64 time=1.26 ms no answer yet for icmp_seq=11 no answer yet for icmp_seq=12 no answer yet for icmp_seq=13 64 bytes from 192.168.0.1: icmp_seq=14 ttl=64 time=1.20 ms no answer yet for icmp_seq=15 64 bytes from 192.168.0.1: icmp_seq=16 ttl=64 time=1.23 ms no answer yet for icmp_seq=17 64 bytes from 192.168.0.1: icmp_seq=18 ttl=64 time=1.23 ms 64 bytes from 192.168.0.1: icmp_seq=19 ttl=64 time=0.571 ms 64 bytes from 192.168.0.1: icmp_seq=20 ttl=64 time=0.533 ms 64 bytes from 192.168.0.1: icmp_seq=21 ttl=64 time=1.20 ms no answer yet for icmp_seq=22 64 bytes from 192.168.0.1: icmp_seq=23 ttl=64 time=0.617 ms 64 bytes from 192.168.0.1: icmp_seq=24 ttl=64 time=0.637 ms no answer yet for icmp_seq=25 64 bytes from 192.168.0.1: icmp_seq=26 ttl=64 time=1.21 ms no answer yet for icmp_seq=27 64 bytes from 192.168.0.1: icmp_seq=28 ttl=64 time=1.19 ms no answer yet for icmp_seq=29 64 bytes from 192.168.0.1: icmp_seq=30 ttl=64 time=1.20 ms 64 bytes from 192.168.0.1: icmp_seq=31 ttl=64 time=0.795 ms no answer yet for icmp_seq=32 64 bytes from 192.168.0.1: icmp_seq=33 ttl=64 time=1.28 ms 64 bytes from 192.168.0.1: icmp_seq=34 ttl=64 time=1.24 ms 64 bytes from 192.168.0.1: icmp_seq=35 ttl=64 time=0.804 ms 64 bytes from 192.168.0.1: icmp_seq=36 ttl=64 time=0.800 ms no answer yet for icmp_seq=37 64 bytes from 192.168.0.1: icmp_seq=38 ttl=64 time=1.20 ms 64 bytes from 192.168.0.1: icmp_seq=39 ttl=64 time=0.597 ms 64 bytes from 192.168.0.1: icmp_seq=40 ttl=64 time=0.874 ms 64 bytes from 192.168.0.1: icmp_seq=41 ttl=64 time=0.549 ms no answer yet for icmp_seq=42 no answer yet for icmp_seq=43 64 bytes from 192.168.0.1: icmp_seq=44 ttl=64 time=0.559 ms 64 bytes from 192.168.0.1: icmp_seq=45 ttl=64 time=0.748 ms 64 bytes from 192.168.0.1: icmp_seq=46 ttl=64 time=0.635 ms no answer yet for icmp_seq=47 ==> /proc/net/anycast6 <== ==> /proc/net/arp <== IP address HW type Flags HW address Mask Device 192.168.0.32 0x1 0x2 e4:bb:6e:ab:ee:e8 * eth0 192.168.0.41 0x1 0x2 a0:85:a9:8f:c7:32 * eth0 192.168.0.1 0x1 0x2 f0:98:2b:76:f1:46 * eth0 192.168.0.30 0x1 0x2 ec:8b:fd:a1:2a:4d * eth0 192.168.0.34 0x1 0x2 d0:56:82:df:2d:2e * eth0 ==> /proc/net/connector <== Name ID cn_proc 1:1 ==> /proc/net/dev <== Inter-| Receive | Transmit face |bytes packets errs drop fifo frame compressed multicast|bytes packets errs drop fifo colls carrier compressed ip6tnl0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 sit0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 eth0: 343888675 18729161 0 0 0 0 0 0 1957867304 6970780 0 0 0 0 0 0 wlan0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 lo: 2616029 5309 0 0 0 0 0 0 2616029 5309 0 0 0 0 0 0 dummy0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ==> /proc/net/dev_mcast <== 5 eth0 1 0 01005e000001 5 eth0 1 0 333300000001 5 eth0 1 0 3333ff97bb5f 5 eth0 1 0 3333ffd4fcb5 6 wlan0 1 0 01005e000001 2 dummy0 1 0 333300000001 ==> /proc/net/dev_snmp6 <== ==> /proc/net/fib_trie <== Main: +-- 0.0.0.0/0 3 0 4 |-- 0.0.0.0 /0 universe UNICAST +-- 127.0.0.0/8 2 0 2 +-- 127.0.0.0/31 1 0 0 |-- 127.0.0.0 /32 link BROADCAST /8 host LOCAL |-- 127.0.0.1 /32 host LOCAL |-- 127.255.255.255 /32 link BROADCAST |-- 169.254.0.0 /16 link UNICAST +-- 192.168.0.0/24 2 0 1 |-- 192.168.0.0 /32 link BROADCAST /24 link UNICAST +-- 192.168.0.64/30 2 0 2 |-- 192.168.0.65 /32 host LOCAL |-- 192.168.0.66 /32 host LOCAL |-- 192.168.0.255 /32 link BROADCAST Local: +-- 0.0.0.0/0 3 0 4 |-- 0.0.0.0 /0 universe UNICAST +-- 127.0.0.0/8 2 0 2 +-- 127.0.0.0/31 1 0 0 |-- 127.0.0.0 /32 link BROADCAST /8 host LOCAL |-- 127.0.0.1 /32 host LOCAL |-- 127.255.255.255 /32 link BROADCAST |-- 169.254.0.0 /16 link UNICAST +-- 192.168.0.0/24 2 0 1 |-- 192.168.0.0 /32 link BROADCAST /24 link UNICAST +-- 192.168.0.64/30 2 0 2 |-- 192.168.0.65 /32 host LOCAL |-- 192.168.0.66 /32 host LOCAL |-- 192.168.0.255 /32 link BROADCAST ==> /proc/net/fib_triestat <== Basic info: size of leaf: 32 bytes, size of tnode: 28 bytes. Main: Aver depth: 2.22 Max depth: 3 Leaves: 9 Prefixes: 11 Internal nodes: 5 1: 1 2: 3 3: 1 Pointers: 22 Null ptrs: 9 Total size: 1 kB Local: Aver depth: 2.22 Max depth: 3 Leaves: 9 Prefixes: 11 Internal nodes: 5 1: 1 2: 3 3: 1 Pointers: 22 Null ptrs: 9 Total size: 1 kB ==> /proc/net/hci <== sk RefCnt Rmem Wmem User Inode Parent ==> /proc/net/hidp <== sk RefCnt Rmem Wmem User Inode Parent ==> /proc/net/hostap <== ==> /proc/net/icmp <== sl local_address rem_address st tx_queue rx_queue tr tm->when retrnsmt uid timeout inode ref pointer drops ==> /proc/net/icmp6 <== sl local_address remote_address st tx_queue rx_queue tr tm->when retrnsmt uid timeout inode ref pointer drops ==> /proc/net/if_inet6 <== fe8000000000000078f8992ac097bb5f 05 40 20 80 eth0 00000000000000000000000000000001 01 80 10 80 lo 2a04ae041404c2002a4f11de98d4fcb5 05 40 00 00 eth0 ==> /proc/net/igmp <== Idx Device : Count Querier Group Users Timer Reporter 1 lo : 1 V3 010000E0 1 0:00000000 0 5 eth0 : 1 V3 010000E0 1 0:00000000 0 6 wlan0 : 1 V3 010000E0 1 0:00000000 0 ==> /proc/net/igmp6 <== 1 lo ff020000000000000000000000000001 1 0000000C 0 1 lo ff010000000000000000000000000001 1 00000008 0 2 dummy0 ff020000000000000000000000000001 1 0000000C 0 2 dummy0 ff010000000000000000000000000001 1 00000008 0 3 sit0 ff020000000000000000000000000001 1 0000000C 0 3 sit0 ff010000000000000000000000000001 1 00000008 0 4 ip6tnl0 ff020000000000000000000000000001 1 0000000C 0 4 ip6tnl0 ff010000000000000000000000000001 1 00000008 0 5 eth0 ff0200000000000000000001ffd4fcb5 1 00000004 0 5 eth0 ff0200000000000000000001ff97bb5f 1 00000004 0 5 eth0 ff020000000000000000000000000001 1 0000000C 0 5 eth0 ff010000000000000000000000000001 1 00000008 0 6 wlan0 ff020000000000000000000000000001 1 00000008 0 6 wlan0 ff010000000000000000000000000001 1 00000008 0 ==> /proc/net/ip6_flowlabel <== Label S Owner Users Linger Expires Dst Opt ==> /proc/net/ip6_tables_matches <== conntrack conntrack conntrack comment ipv6header icmp6 udplite udp tcp ==> /proc/net/ip6_tables_names <== mangle filter ==> /proc/net/ip6_tables_targets <== REJECT ERROR ==> /proc/net/ip_mr_cache <== Group Origin Iif Pkts Bytes Wrong Oifs ==> /proc/net/ip_mr_vif <== Interface BytesIn PktsIn BytesOut PktsOut Flags Local Remote ==> /proc/net/ip_tables_matches <== conntrack conntrack conntrack comment icmp udplite udp tcp ==> /proc/net/ip_tables_names <== filter ==> /proc/net/ip_tables_targets <== ERROR ==> /proc/net/ipv6_route <== 2a04ae041404c2000000000000000000 40 00000000000000000000000000000000 00 fe80000000000000b2982bfffe76f146 00000064 00000001 00000000 00000003 eth0 fe80000000000000b2982bfffe76f146 80 00000000000000000000000000000000 00 00000000000000000000000000000000 00000064 00000001 00000000 00000001 eth0 fe800000000000000000000000000000 40 00000000000000000000000000000000 00 00000000000000000000000000000000 00000100 00000001 00000000 00000001 eth0 00000000000000000000000000000000 00 00000000000000000000000000000000 00 fe80000000000000b2982bfffe76f146 00000064 00000001 00000000 00000003 eth0 00000000000000000000000000000000 00 00000000000000000000000000000000 00 00000000000000000000000000000000 ffffffff 00000001 000034ff 00200200 lo 00000000000000000000000000000001 80 00000000000000000000000000000000 00 00000000000000000000000000000000 00000000 00000006 000005c0 80200001 lo 2a04ae041404c2002a4f11de98d4fcb5 80 00000000000000000000000000000000 00 00000000000000000000000000000000 00000000 00000006 000000f3 80200001 eth0 fe8000000000000078f8992ac097bb5f 80 00000000000000000000000000000000 00 00000000000000000000000000000000 00000000 00000004 000000e1 80200001 eth0 ff000000000000000000000000000000 08 00000000000000000000000000000000 00 00000000000000000000000000000000 00000100 00000004 000000db 00000001 eth0 00000000000000000000000000000000 00 00000000000000000000000000000000 00 00000000000000000000000000000000 ffffffff 00000001 000034ff 00200200 lo ==> /proc/net/l2cap <== sk RefCnt Rmem Wmem User Inode Parent edad8000 2 0 0 0 1164 0 ==> /proc/net/mcfilter <== Idx Device MCA SRC INC EXC ==> /proc/net/mcfilter6 <== Idx Device Multicast Address Source Address INC EXC ==> /proc/net/netfilter <== ==> /proc/net/netlink <== sk Eth Pid Groups Rmem Wmem Dump Locks Drops Inode ee836c00 0 0 00000000 0 0 0 2 0 16 ecea3c00 0 767558172 00000551 0 0 0 2 0 17090 ec506400 0 1189 00000771 0 0 0 2 0 19956 ecf81800 0 839 00000001 0 0 0 2 0 18584 edabc000 4 0 00000000 0 0 0 2 0 11470 edabd400 6 0 00000000 0 0 0 2 0 11471 ee20bc00 10 0 00000000 0 0 0 2 0 10389 eeaf7800 11 0 00000000 0 0 0 2 0 41 ecfd3800 15 551 00000002 0 0 0 2 0 16917 edad8c00 15 2940286473 00000002 0 0 0 2 0 17862 ecea3800 15 4266769875 00000002 0 0 0 2 0 17089 ee837400 15 0 00000000 0 0 0 2 0 20 ecea2800 15 540 00000002 0 0 0 2 0 17088 ecfd3c00 15 3724694504 00000002 0 0 0 2 0 16919 edada000 15 4287468030 00000001 0 0 0 2 0 1355 ec4b5800 15 24439 00000002 0 0 0 2 0 804108 ecf14800 15 4238474557 00000002 0 0 0 2 0 15170 ecfd3000 15 3779924029 00000002 0 0 0 2 0 16918 ed651000 15 1 00000002 0 0 0 2 0 15726 ecfd1000 15 3192679313 00000002 0 0 0 2 0 16920 ecf81400 16 1392509767 0000003c 0 0 0 2 0 18586 ecf82000 16 675283783 00000000 0 0 0 2 0 18585 ee208400 16 0 00000000 0 0 0 2 0 47 ecf17000 16 1350566428 00000000 0 0 0 2 0 15229 ecf80c00 16 1975518023 00000000 0 0 0 2 0 18589 ==> /proc/net/netstat <== TcpExt: SyncookiesSent SyncookiesRecv SyncookiesFailed EmbryonicRsts PruneCalled RcvPruned OfoPruned OutOfWindowIcmps LockDroppedIcmps ArpFilter TW TWRecycled TWKilled PAWSActive PAWSEstab DelayedACKs DelayedACKLocked DelayedACKLost ListenOverflows ListenDrops TCPHPHits TCPPureAcks TCPHPAcks TCPRenoRecovery TCPSackRecovery TCPSACKReneging TCPFACKReorder TCPSACKReorder TCPRenoReorder TCPTSReorder TCPFullUndo TCPPartialUndo TCPDSACKUndo TCPLossUndo TCPLostRetransmit TCPRenoFailures TCPSackFailures TCPLossFailures TCPFastRetrans TCPSlowStartRetrans TCPTimeouts TCPLossProbes TCPLossProbeRecovery TCPRenoRecoveryFail TCPSackRecoveryFail TCPRcvCollapsed TCPDSACKOldSent TCPDSACKOfoSent TCPDSACKRecv TCPDSACKOfoRecv TCPAbortOnData TCPAbortOnClose TCPAbortOnMemory TCPAbortOnTimeout TCPAbortOnLinger TCPAbortFailed TCPMemoryPressures TCPMemoryPressuresChrono TCPSACKDiscard TCPDSACKIgnoredOld TCPDSACKIgnoredNoUndo TCPSpuriousRTOs TCPMD5NotFound TCPMD5Unexpected TCPMD5Failure TCPSackShifted TCPSackMerged TCPSackShiftFallback TCPBacklogDrop PFMemallocDrop TCPMinTTLDrop TCPDeferAcceptDrop IPReversePathFilter TCPTimeWaitOverflow TCPReqQFullDoCookies TCPReqQFullDrop TCPRetransFail TCPRcvCoalesce TCPOFOQueue TCPOFODrop TCPOFOMerge TCPChallengeACK TCPSYNChallenge TCPFastOpenActive TCPFastOpenActiveFail TCPFastOpenPassive TCPFastOpenPassiveFail TCPFastOpenListenOverflow TCPFastOpenCookieReqd TCPFastOpenBlackhole TCPSpuriousRtxHostQueues BusyPollRxPackets TCPAutoCorking TCPFromZeroWindowAdv TCPToZeroWindowAdv TCPWantZeroWindowAdv TCPSynRetrans TCPOrigDataSent TCPHystartTrainDetect TCPHystartTrainCwnd TCPHystartDelayDetect TCPHystartDelayCwnd TCPACKSkippedSynRecv TCPACKSkippedPAWS TCPACKSkippedSeq TCPACKSkippedFinWait2 TCPACKSkippedTimeWait TCPACKSkippedChallenge TCPWinProbe TCPKeepAlive TCPMTUPFail TCPMTUPSuccess TcpExt: 0 0 0 0 0 0 0 0 0 0 4211 0 0 0 0 2052 50 234 0 0 3336722 190903 1269305 0 6239 0 0 47 0 19 1 19 1 18 372 0 0 0 10733 0 164 322 61 0 24 0 234 0 48 0 7 395 0 117 0 0 0 0 0 0 43 0 0 0 0 15649 98714 16185 0 0 0 0 0 0 0 0 0 208314 51026 0 0 0 0 0 0 0 0 0 0 0 1 0 9730 0 0 0 569 3795142 92 4291 303 13885 0 0 0 0 0 0 0 0 0 0 IpExt: InNoRoutes InTruncatedPkts InMcastPkts OutMcastPkts InBcastPkts OutBcastPkts InOctets OutOctets InMcastOctets OutMcastOctets InBcastOctets OutBcastOctets InCsumErrors InNoECTPkts InECT1Pkts InECT0Pkts InCEPkts IpExt: 0 0 0 96 6903 0 22120497133 5622476377 0 14760 569244 0 0 16498397 0 1302 0 ==> /proc/net/nf_conntrack <== ==> /proc/net/nf_conntrack_expect <== ==> /proc/net/nfsfs <== ==> /proc/net/packet <== sk RefCnt Type Proto Iface R Rmem User Inode ec561000 3 2 890d 6 1 0 0 18600 ec4dc800 3 3 0003 5 1 0 0 18145 ec417800 3 2 888e 6 1 0 0 18591 ec417000 2 2 0000 0 0 0 0 18590 ee9e4800 3 3 0003 5 1 0 0 1912 ==> /proc/net/pfkey <== sk RefCnt Rmem Wmem User Inode ==> /proc/net/pnp <== #MANUAL nameserver 0.0.0.0 nameserver 0.0.0.0 nameserver 0.0.0.0 ==> /proc/net/protocols <== protocol size sockets memory press maxhdr slab module cl co di ac io in de sh ss gs se re sp bi br ha uh gp em HIDP 600 0 -1 NI 0 no kernel n n n n n n n n n n n n n n n n n n n RFCOMM 624 0 -1 NI 0 no kernel n n n n n n n n n n n n n n n n n n n KEY 656 0 -1 NI 0 no kernel n n n n n n n n n n n n n n n n n n n PACKET 1088 5 -1 NI 0 no kernel n n n n n n n n n n n n n n n n n n n PINGv6 904 0 -1 NI 0 yes kernel y y y n n y n n y y y y n y y y y y n RAWv6 904 2 -1 NI 0 yes kernel y y y n y y y n y y y y n y y y y n n UDPLITEv6 1024 0 3 NI 0 yes kernel y y y n y y y n y y y y n n n y y y n UDPv6 1024 4 3 NI 0 yes kernel y y y n y y y n y y y y n n n y y y n TCPv6 1776 1 0 no 304 yes kernel y y y y y y y y y y y y y n y y y y y ALG 600 0 0 NI 0 no kernel n n n n n n n n n n n n n n n n n n n UNIX 832 73 -1 NI 0 yes kernel n n n n n n n n n n n n n n n n n n n UDP-Lite 896 0 3 NI 0 yes kernel y y y n y y y n y y y y y n n y y y n PING 744 0 -1 NI 0 yes kernel y y y n n y n n y y y y n y y y y y n RAW 752 1 -1 NI 0 yes kernel y y y n y y y n y y y y n y y y y n n UDP 896 8 3 NI 0 yes kernel y y y n y y y n y y y y y n n y y y n TCP 1664 1 0 no 304 yes kernel y y y y y y y y y y y y y n y y y y y SCO 624 0 -1 NI 0 no kernel n n n n n n n n n n n n n n n n n n n L2CAP 608 0 -1 NI 0 no kernel n n n n n n n n n n n n n n n n n n n HCI 656 0 -1 NI 0 no kernel n n n n n n n n n n n n n n n n n n n NETLINK 792 18 -1 NI 0 no kernel n n n n n n n n n n n n n n n n n n n ==> /proc/net/psched <== 000003e8 00000040 000f4240 3b9aca00 ==> /proc/net/ptype <== Type Device Function 0800 ip_rcv 0011 llc_rcv 0004 llc_rcv 0806 arp_rcv 86dd ipv6_rcv ==> /proc/net/raw <== sl local_address rem_address st tx_queue rx_queue tr tm->when retrnsmt uid timeout inode ref pointer drops 1: 00000000:0001 00000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 811993 2 ed6f9e00 0 ==> /proc/net/raw6 <== sl local_address remote_address st tx_queue rx_queue tr tm->when retrnsmt uid timeout inode ref pointer drops 58: 00000000000000000000000000000000:003A 00000000000000000000000000000000:0000 07 00000000:00000A00 00:00000000 00000000 0 0 811995 2 ec4c2580 0 58: 00000000000000000000000000000000:003A 00000000000000000000000000000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 18582 2 eced1e00 0 ==> /proc/net/rfcomm <== sk RefCnt Rmem Wmem User Inode Parent ==> /proc/net/route <== Iface Destination Gateway Flags RefCnt Use Metric Mask MTU Window IRTT eth0 00000000 0100A8C0 0003 0 0 100 00000000 0 0 0 eth0 0000FEA9 00000000 0001 0 0 1000 0000FFFF 0 0 0 eth0 0000A8C0 00000000 0001 0 0 100 00FFFFFF 0 0 0 ==> /proc/net/rpc <== ==> /proc/net/rt6_stats <== 0000 0007 0000 0008 0000 0000 000c ==> /proc/net/rt_acct <== ==> /proc/net/rt_cache <== Iface Destination Gateway Flags RefCnt Use Metric Source MTU Window IRTT TOS HHRef HHUptod SpecDst ==> /proc/net/rtl8723bs <== ==> /proc/net/sco <== sk RefCnt Rmem Wmem User Inode Parent ==> /proc/net/snmp <== Ip: Forwarding DefaultTTL InReceives InHdrErrors InAddrErrors ForwDatagrams InUnknownProtos InDiscards InDelivers OutRequests OutDiscards OutNoRoutes ReasmTimeout ReasmReqds ReasmOKs ReasmFails FragOKs FragFails FragCreates Ip: 2 64 4465912 0 3 0 0 0 4430347 4419679 0 1 0 400 200 0 200 0 400 Icmp: InMsgs InErrors InCsumErrors InDestUnreachs InTimeExcds InParmProbs InSrcQuenchs InRedirects InEchos InEchoReps InTimestamps InTimestampReps InAddrMasks InAddrMaskReps OutMsgs OutErrors OutDestUnreachs OutTimeExcds OutParmProbs OutSrcQuenchs OutRedirects OutEchos OutEchoReps OutTimestamps OutTimestampReps OutAddrMasks OutAddrMaskReps Icmp: 3968 4 0 8 0 0 0 0 1 3959 0 0 0 0 4870 0 12 0 0 0 0 4857 1 0 0 0 0 IcmpMsg: InType0 InType3 InType8 OutType0 OutType3 OutType8 IcmpMsg: 3959 8 1 1 12 4857 Tcp: RtoAlgorithm RtoMin RtoMax MaxConn ActiveOpens PassiveOpens AttemptFails EstabResets CurrEstab InSegs OutSegs RetransSegs InErrs OutRsts InCsumErrors Tcp: 1 200 120000 -1 5189 15 85 648 0 4909117 6718651 11742 0 3819 0 Udp: InDatagrams NoPorts InErrors OutDatagrams RcvbufErrors SndbufErrors InCsumErrors IgnoredMulti Udp: 142760 12 0 224282 0 0 0 533 UdpLite: InDatagrams NoPorts InErrors OutDatagrams RcvbufErrors SndbufErrors InCsumErrors IgnoredMulti UdpLite: 0 0 0 0 0 0 0 0 ==> /proc/net/snmp6 <== Ip6InReceives 637962 Ip6InHdrErrors 0 Ip6InTooBigErrors 0 Ip6InNoRoutes 0 Ip6InAddrErrors 0 Ip6InUnknownProtos 0 Ip6InTruncatedPkts 0 Ip6InDiscards 0 Ip6InDelivers 636100 Ip6OutForwDatagrams 0 Ip6OutRequests 585259 Ip6OutDiscards 0 Ip6OutNoRoutes 11 Ip6ReasmTimeout 0 Ip6ReasmReqds 3722 Ip6ReasmOKs 1861 Ip6ReasmFails 0 Ip6FragOKs 1900 Ip6FragFails 0 Ip6FragCreates 3800 Ip6InMcastPkts 201 Ip6OutMcastPkts 223 Ip6InOctets 2993193569 Ip6OutOctets 430864446 Ip6InMcastOctets 24888 Ip6OutMcastOctets 17914 Ip6InBcastOctets 0 Ip6OutBcastOctets 0 Ip6InNoECTPkts 2221359 Ip6InECT1Pkts 0 Ip6InECT0Pkts 1298 Ip6InCEPkts 0 Icmp6InMsgs 8234 Icmp6InErrors 5 Icmp6OutMsgs 8594 Icmp6OutErrors 0 Icmp6InCsumErrors 0 Icmp6InDestUnreachs 106 Icmp6InPktTooBigs 0 Icmp6InTimeExcds 4 Icmp6InParmProblems 0 Icmp6InEchos 0 Icmp6InEchoReplies 7452 Icmp6InGroupMembQueries 0 Icmp6InGroupMembResponses 0 Icmp6InGroupMembReductions 0 Icmp6InRouterSolicits 0 Icmp6InRouterAdvertisements 198 Icmp6InNeighborSolicits 347 Icmp6InNeighborAdvertisements 127 Icmp6InRedirects 0 Icmp6InMLDv2Reports 0 Icmp6OutDestUnreachs 106 Icmp6OutPktTooBigs 0 Icmp6OutTimeExcds 0 Icmp6OutParmProblems 0 Icmp6OutEchos 7611 Icmp6OutEchoReplies 0 Icmp6OutGroupMembQueries 0 Icmp6OutGroupMembResponses 0 Icmp6OutGroupMembReductions 0 Icmp6OutRouterSolicits 1 Icmp6OutRouterAdvertisements 0 Icmp6OutNeighborSolicits 517 Icmp6OutNeighborAdvertisements 347 Icmp6OutRedirects 0 Icmp6OutMLDv2Reports 12 Icmp6InType1 106 Icmp6InType3 4 Icmp6InType129 7452 Icmp6InType134 198 Icmp6InType135 347 Icmp6InType136 127 Icmp6OutType1 106 Icmp6OutType128 7611 Icmp6OutType133 1 Icmp6OutType135 517 Icmp6OutType136 347 Icmp6OutType143 12 Udp6InDatagrams 1817 Udp6NoPorts 5 Udp6InErrors 0 Udp6OutDatagrams 5429 Udp6RcvbufErrors 0 Udp6SndbufErrors 0 Udp6InCsumErrors 0 Udp6IgnoredMulti 0 UdpLite6InDatagrams 0 UdpLite6NoPorts 0 UdpLite6InErrors 0 UdpLite6OutDatagrams 0 UdpLite6RcvbufErrors 0 UdpLite6SndbufErrors 0 UdpLite6InCsumErrors 0 ==> /proc/net/sockstat <== sockets: used 162 TCP: inuse 1 orphan 0 tw 0 alloc 2 mem 0 UDP: inuse 8 mem 3 UDPLITE: inuse 0 RAW: inuse 1 FRAG: inuse 0 memory 0 ==> /proc/net/sockstat6 <== TCP6: inuse 1 UDP6: inuse 4 UDPLITE6: inuse 0 RAW6: inuse 2 FRAG6: inuse 0 memory 0 ==> /proc/net/softnet_stat <== 001c5578 00000000 00000003 00000000 00000000 00000000 00000000 00000000 00000000 001274b2 00000000 00199dfe 00000000 00000004 00000000 00000000 00000000 00000000 00000000 00000000 001143a1 00000000 00181854 00000000 00000001 00000000 00000000 00000000 00000000 00000000 00000000 001144f0 00000000 0000048a 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ==> /proc/net/stat <== ==> /proc/net/tcp <== sl local_address rem_address st tx_queue rx_queue tr tm->when retrnsmt uid timeout inode 0: 00000000:86D9 00000000:0000 0A 00000000:00000000 00:00000000 00000000 0 0 20724 1 ec610000 100 0 0 10 0 ==> /proc/net/tcp6 <== sl local_address remote_address st tx_queue rx_queue tr tm->when retrnsmt uid timeout inode 0: 00000000000000000000000000000000:86D9 00000000000000000000000000000000:0000 0A 00000000:00000000 00:00000000 00000000 0 0 20726 1 ec608000 100 0 0 10 0 ==> /proc/net/udp <== sl local_address rem_address st tx_queue rx_queue tr tm->when retrnsmt uid timeout inode ref pointer drops 86: 4200A8C0:C9EF 02FFFF53:0035 01 00000000:00000000 00:00000000 00000000 106 0 815318 2 ecfc4e00 0 171: 00000000:0044 00000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 18147 2 ed76ce00 0 171: 00000000:0044 00000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 1914 2 ed6bc000 0 226: 4100A8C0:007B 00000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 19947 2 ee289880 0 226: 4200A8C0:007B 00000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 19945 2 ee289500 0 226: 0100007F:007B 00000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 19943 2 ee289180 0 226: 00000000:007B 00000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 19939 2 ee288e00 0 375: 4200A8C0:AF10 01FFFF53:0035 01 00000000:00000000 00:00000000 00000000 106 0 815317 2 ecfc5880 0 ==> /proc/net/udp6 <== sl local_address remote_address st tx_queue rx_queue tr tm->when retrnsmt uid timeout inode ref pointer drops 226: 000080FE000000002A99F8785FBB97C0:007B 00000000000000000000000000000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 19955 2 ec507000 0 226: 04AE042A00C20414DE114F2AB5FCD498:007B 00000000000000000000000000000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 19953 2 ec507400 0 226: 00000000000000000000000001000000:007B 00000000000000000000000000000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 19949 2 ec504c00 0 226: 00000000000000000000000000000000:007B 00000000000000000000000000000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 19936 2 ec505000 0 ==> /proc/net/udplite <== sl local_address rem_address st tx_queue rx_queue tr tm->when retrnsmt uid timeout inode ref pointer drops ==> /proc/net/udplite6 <== sl local_address remote_address st tx_queue rx_queue tr tm->when retrnsmt uid timeout inode ref pointer drops ==> /proc/net/unix <== Num RefCount Protocol Flags Type St Inode Path ec421a00: 00000002 00000000 00000000 0002 01 804115 /run/user/0/systemd/notify ec4209c0: 00000002 00000000 00010000 0001 01 804119 /run/user/0/systemd/private ec421040: 00000002 00000000 00010000 0001 01 804124 /run/user/0/gnupg/S.gpg-agent ec4216c0: 00000002 00000000 00010000 0001 01 804127 /run/user/0/gnupg/S.gpg-agent.extra ec422a40: 00000002 00000000 00010000 0001 01 804129 /run/user/0/gnupg/S.gpg-agent.browser ec420680: 00000002 00000000 00010000 0001 01 804131 /run/user/0/gnupg/S.gpg-agent.ssh ec4223c0: 00000002 00000000 00010000 0001 01 804133 /run/user/0/gnupg/S.dirmngr ed748d00: 00000002 00000000 00010000 0001 01 16693 /var/run/dbus/system_bus_socket eccd8000: 00000002 00000000 00010000 0001 01 1345 /run/systemd/fsck.progress eccd8340: 00000002 00000000 00000000 0002 01 1348 /run/systemd/journal/syslog eccd8680: 00000002 00000000 00010000 0005 01 1353 /run/udev/control eccd89c0: 00000009 00000000 00000000 0002 01 1356 /run/systemd/journal/dev-log eccd8d00: 00000002 00000000 00010000 0001 01 1359 /run/systemd/journal/stdout eccd9040: 00000006 00000000 00000000 0002 01 1361 /run/systemd/journal/socket ed66c340: 00000003 00000000 00000000 0002 01 15728 /run/systemd/notify ed66c680: 00000002 00000000 00000000 0002 01 15730 /run/systemd/cgroups-agent ececb740: 00000002 00000000 00010000 0001 01 18550 /var/run/NetworkManager/private-dhcp ed66d040: 00000002 00000000 00010000 0001 01 15734 /run/systemd/private ececa700: 00000002 00000000 00000000 0002 01 18602 /run/wpa_supplicant/wlan0 ed749a00: 00000003 00000000 00000000 0001 03 16753 eeab89c0: 00000003 00000000 00000000 0001 03 15153 ec422080: 00000003 00000000 00000000 0002 01 804117 ecec9380: 00000003 00000000 00000000 0001 03 1967 ececa080: 00000003 00000000 00000000 0001 03 18455 ed66ea40: 00000003 00000000 00000000 0002 01 15953 eeaba3c0: 00000003 00000000 00000000 0002 01 14988 ececad80: 00000003 00000000 00000000 0001 03 18544 eeabb0c0: 00000003 00000000 00000000 0001 03 20847 ec4256c0: 00000003 00000000 00000000 0001 03 19961 ececba80: 00000003 00000000 00000000 0001 03 18583 ed66f740: 00000003 00000000 00000000 0001 03 17532 ec421380: 00000002 00000000 00000000 0002 01 22265 ed74a700: 00000003 00000000 00000000 0001 03 17465 /var/run/dbus/system_bus_socket eeab8680: 00000003 00000000 00000000 0001 03 15351 ed749d40: 00000003 00000000 00000000 0001 03 17449 /run/systemd/journal/stdout ebebc680: 00000003 00000000 00000000 0001 03 802615 /run/systemd/journal/stdout ed66cd00: 00000003 00000000 00000000 0002 01 15733 ed749040: 00000003 00000000 00000000 0001 03 16760 ecec89c0: 00000002 00000000 00000000 0002 01 1907 ed66da00: 00000002 00000000 00000000 0002 01 15910 eeab9380: 00000003 00000000 00000000 0001 03 16229 /run/systemd/journal/stdout ed748340: 00000003 00000000 00000000 0001 03 16813 ececa3c0: 00000003 00000000 00000000 0001 03 17257 /run/systemd/journal/stdout eeaba080: 00000003 00000000 00000000 0002 01 14989 ec424680: 00000002 00000000 00000000 0002 01 17107 eeabad80: 00000002 00000000 00000000 0002 01 15147 eb8d0d00: 00000002 00000000 00000000 0002 01 801361 ed66e700: 00000003 00000000 00000000 0002 01 15952 ebebed80: 00000003 00000000 00000000 0001 03 803111 ed74b740: 00000003 00000000 00000000 0001 03 17539 /var/run/dbus/system_bus_socket ececb0c0: 00000003 00000000 00000000 0001 03 18106 /var/run/dbus/system_bus_socket eeabba80: 00000003 00000000 00000000 0001 03 19101 /run/systemd/journal/stdout ed66c9c0: 00000003 00000000 00000000 0002 01 15732 ebebd040: 00000002 00000000 00000000 0002 01 803117 eeab9040: 00000003 00000000 00000000 0001 03 15352 /run/systemd/journal/stdout eeab9d40: 00000003 00000000 00000000 0001 03 14674 ed748680: 00000003 00000000 00000000 0001 03 17469 /run/systemd/journal/stdout ec420000: 00000002 00000000 00000000 0002 01 804102 eeabaa40: 00000002 00000000 00000000 0002 01 14976 eeabb740: 00000002 00000000 00000000 0002 01 20858 ec425d40: 00000003 00000000 00000000 0001 03 19962 ececb400: 00000002 00000000 00000000 0002 01 18549 ed66f0c0: 00000003 00000000 00000000 0001 03 17464 eeab8d00: 00000003 00000000 00000000 0001 03 15154 /var/run/dbus/system_bus_socket ed7489c0: 00000002 00000000 00000000 0002 01 16915 ed66d380: 00000003 00000000 00000000 0001 03 17463 ec423740: 00000002 00000000 00000000 0002 01 18136 ecec9d40: 00000003 00000000 00000000 0001 03 16257 /run/systemd/journal/stdout eeaba700: 00000002 00000000 00000000 0002 01 14964 ed74b0c0: 00000003 00000000 00000000 0001 03 16921 ececaa40: 00000003 00000000 00000000 0001 03 18140 /var/run/dbus/system_bus_socket ed66fa80: 00000003 00000000 00000000 0001 03 15118 /run/systemd/journal/stdout ec421d40: 00000003 00000000 00000000 0002 01 804118 ==> /proc/net/vlan <== ==> /proc/net/wireless <== Inter-| sta-| Quality | Discarded packets | Missed | WE face | tus | link level noise | nwid crypt frag retry misc | beacon | 22 wlan0: 0000 0. 0. 0. 0 0 0 0 0 0 -------------------- Thermal Zone 0 58.181 °C 136.725 °F -------------------- Thermal Zone 1 56.363 °C 133.453 °F -------------------- Filesystem Size Used Avail Use% Mounted on udev 1001M 0 1001M 0% /dev tmpfs 201M 16M 186M 8% /run /dev/mmcblk0p1 15G 1.1G 14G 8% / tmpfs 1003M 0 1003M 0% /dev/shm tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 1003M 0 1003M 0% /sys/fs/cgroup tmpfs 1003M 0 1003M 0% /tmp log2ram 200M 12M 189M 6% /var/log tmpfs 201M 0 201M 0% /run/user/0 total used free shared buff/cache available Mem: 2.0G 63M 1.7G 34M 178M 1.8G Swap: 127M 0B 127M USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND root 1 0.0 0.2 26404 4940 ? Ss 19:50 0:03 /sbin/init scandelay root 2 0.0 0.0 0 0 ? S 19:50 0:00 [kthreadd] root 4 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/0:0H] root 6 0.0 0.0 0 0 ? I< 19:50 0:00 [mm_percpu_wq] root 7 0.0 0.0 0 0 ? S 19:50 0:01 [ksoftirqd/0] root 8 0.1 0.0 0 0 ? I 19:50 0:11 [rcu_preempt] root 9 0.0 0.0 0 0 ? I 19:50 0:00 [rcu_sched] root 10 0.0 0.0 0 0 ? I 19:50 0:00 [rcu_bh] root 11 0.0 0.0 0 0 ? S 19:50 0:00 [migration/0] root 12 0.0 0.0 0 0 ? S 19:50 0:00 [cpuhp/0] root 13 0.0 0.0 0 0 ? S 19:50 0:00 [cpuhp/1] root 14 0.0 0.0 0 0 ? S 19:50 0:00 [migration/1] root 15 0.0 0.0 0 0 ? S 19:50 0:01 [ksoftirqd/1] root 17 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/1:0H] root 18 0.0 0.0 0 0 ? S 19:50 0:00 [cpuhp/2] root 19 0.0 0.0 0 0 ? S 19:50 0:00 [migration/2] root 20 0.0 0.0 0 0 ? S 19:50 0:00 [ksoftirqd/2] root 22 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/2:0H] root 23 0.0 0.0 0 0 ? S 19:50 0:00 [cpuhp/3] root 24 0.0 0.0 0 0 ? S 19:50 0:00 [migration/3] root 25 0.0 0.0 0 0 ? S 19:50 0:02 [ksoftirqd/3] root 27 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/3:0H] root 28 0.0 0.0 0 0 ? S 19:50 0:00 [kdevtmpfs] root 29 0.0 0.0 0 0 ? I< 19:50 0:00 [netns] root 31 0.0 0.0 0 0 ? S 19:50 0:00 [khungtaskd] root 32 0.0 0.0 0 0 ? S 19:50 0:00 [oom_reaper] root 33 0.0 0.0 0 0 ? I< 19:50 0:00 [writeback] root 34 0.0 0.0 0 0 ? I< 19:50 0:00 [crypto] root 35 0.0 0.0 0 0 ? I< 19:50 0:00 [kblockd] root 36 0.0 0.0 0 0 ? I< 19:50 0:00 [md] root 37 0.0 0.0 0 0 ? I< 19:50 0:00 [devfreq_wq] root 38 0.0 0.0 0 0 ? I< 19:50 0:00 [cfg80211] root 39 0.0 0.0 0 0 ? I< 19:50 0:00 [watchdogd] root 40 0.0 0.0 0 0 ? I< 19:50 0:00 [rpciod] root 41 0.0 0.0 0 0 ? I< 19:50 0:00 [xprtiod] root 42 0.0 0.0 0 0 ? S 19:50 0:00 [kswapd0] root 43 0.0 0.0 0 0 ? S 19:50 0:00 [ecryptfs-kthrea] root 44 0.0 0.0 0 0 ? I< 19:50 0:00 [nfsiod] root 45 0.0 0.0 0 0 ? I< 19:50 0:00 [cifsiod] root 46 0.0 0.0 0 0 ? I< 19:50 0:00 [cifsoplockd] root 47 0.0 0.0 0 0 ? S 19:50 0:00 [jfsIO] root 48 0.0 0.0 0 0 ? S 19:50 0:00 [jfsCommit] root 49 0.0 0.0 0 0 ? S 19:50 0:00 [jfsCommit] root 50 0.0 0.0 0 0 ? S 19:50 0:00 [jfsCommit] root 51 0.0 0.0 0 0 ? S 19:50 0:00 [jfsCommit] root 52 0.0 0.0 0 0 ? S 19:50 0:00 [jfsSync] root 53 0.0 0.0 0 0 ? I< 19:50 0:00 [xfsalloc] root 54 0.0 0.0 0 0 ? I< 19:50 0:00 [xfs_mru_cache] root 92 0.0 0.0 0 0 ? I< 19:50 0:00 [kthrotld] root 93 0.0 0.0 0 0 ? S 19:50 0:00 [spi2] root 94 0.0 0.0 0 0 ? I< 19:50 0:00 [libertastf] root 96 0.0 0.0 0 0 ? S 19:50 0:00 [irq/79-rk808] root 97 0.0 0.0 0 0 ? S 19:50 0:00 [irq/43-rockchip] root 98 0.0 0.0 0 0 ? I< 19:50 0:00 [raid5wq] root 99 0.0 0.0 0 0 ? I< 19:50 0:00 [dm_bufio_cache] root 102 0.0 0.0 0 0 ? I< 19:50 0:00 [ipv6_addrconf] root 103 0.0 0.0 0 0 ? S< 19:50 0:00 [krfcommd] root 106 0.0 0.0 0 0 ? S 19:50 0:00 [irq/57-ff980000] root 108 0.0 0.0 0 0 ? S 19:50 0:01 [mmcqd/0] root 143 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/1:1H] root 147 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/0:1H] root 167 0.0 0.0 0 0 ? S 19:50 0:00 [jbd2/mmcblk0p1-] root 168 0.0 0.0 0 0 ? I< 19:50 0:00 [ext4-rsv-conver] root 182 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/3:1H] root 189 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/2:1H] root 263 0.0 0.1 12368 2604 ? Ss 19:50 0:00 /lib/systemd/systemd-udevd root 385 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/u9:0] root 386 0.0 0.0 0 0 ? I< 19:50 0:00 [kbase_job_fault] root 387 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/u9:1] root 462 0.1 0.2 27112 5052 ? Ss 19:50 0:09 /lib/systemd/systemd-journald root 498 0.0 0.2 7216 4116 ? Ss 19:50 0:03 /usr/sbin/haveged --Foreground --verbose=1 -w 1024 message+ 518 0.0 0.1 5412 2960 ? Ss 19:50 0:02 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation root 540 0.1 0.6 96832 13604 ? Ssl 19:50 0:09 /usr/sbin/NetworkManager --no-daemon root 551 0.0 0.1 6128 3480 ? Ss 19:50 0:00 /lib/systemd/systemd-logind root 649 0.0 0.2 8500 4460 ? Ss 19:50 0:00 /usr/sbin/sshd -D root 830 0.0 0.0 0 0 ? S 19:50 0:00 [RTW_XMIT_THREAD] root 831 0.1 0.0 0 0 ? S 19:50 0:08 [RTW_CMD_THREAD] root 832 0.0 0.0 0 0 ? S 19:50 0:00 [RTWHALXT] root 834 0.0 0.2 37544 5908 ? Ssl 19:50 0:00 /usr/lib/policykit-1/polkitd --no-debug root 839 0.0 0.2 7876 4932 ? Ss 19:50 0:02 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant root 862 0.0 0.1 5256 2832 ? S 19:50 0:00 /sbin/dhclient -d -q -sf /usr/lib/NetworkManager/nm-dhcp-helper -pf /var/run/dhclient-eth0.pid -lf /var/lib/NetworkManager/dhclient-27abdbc0-957a-3b32-a9ca-609cde406708-eth0.lease -cf /var/lib/NetworkManager/dhclient-eth0.conf eth0 root 1100 0.0 0.1 5256 2056 ? Ss 19:50 0:00 /sbin/dhclient -4 -v -pf /run/dhclient.eth0.pid -lf /var/lib/dhcp/dhclient.eth0.leases -I -df /var/lib/dhcp/dhclient6.eth0.leases eth0 root 1152 0.1 0.5 904924 11012 ? Ssl 19:50 0:10 /usr/share/filebeat/bin/filebeat -c /etc/filebeat/filebeat.yml -path.home /usr/share/filebeat -path.config /etc/filebeat -path.data /var/lib/filebeat -path.logs /var/log/filebeat ntp 1189 0.0 0.1 6900 2868 ? Ssl 19:50 0:01 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 106:110 root 1441 0.0 0.0 0 0 ? I 20:58 0:00 [kworker/1:0] root 2123 0.0 0.0 3476 1580 ttyS2 Ss+ 19:51 0:00 /sbin/agetty --keep-baud 115200,38400,9600 ttyS2 linux root 2125 0.0 0.1 5016 2300 tty1 Ss 19:51 0:00 /bin/login -- root 2786 0.0 0.0 23092 2040 ? Ssl 19:53 0:01 /usr/sbin/rsyslogd -n root 10613 0.0 0.0 0 0 ? I 21:38 0:00 [kworker/3:0] root 17260 0.1 0.0 0 0 ? I 21:46 0:01 [kworker/0:1] root 18766 0.0 0.0 0 0 ? I 21:48 0:00 [kworker/u8:4] root 18771 0.0 0.0 0 0 ? I 21:48 0:00 [kworker/u8:6] root 24439 0.0 0.1 7580 4100 ? Ss 21:50 0:00 /lib/systemd/systemd --user root 24442 0.0 0.0 27876 1296 ? S 21:50 0:00 (sd-pam) root 24448 0.1 0.1 5704 3968 tty1 S 21:50 0:01 -bash root 25273 0.0 0.0 0 0 ? I 20:53 0:00 [kworker/2:2] root 27684 0.1 0.0 0 0 ? I 21:53 0:00 [kworker/3:1] root 27748 0.0 0.0 0 0 ? I 21:54 0:00 [kworker/0:2] root 27751 0.1 0.0 0 0 ? I 21:54 0:00 [kworker/1:2] root 27774 0.0 0.0 0 0 ? I 21:56 0:00 [kworker/2:1] root 27830 0.0 0.0 0 0 ? I 21:59 0:00 [kworker/0:0] root 27872 0.0 0.0 4388 656 tty1 S 22:01 0:00 ping 192.168.0.1 -O root 27913 0.0 0.1 6728 2512 tty1 R+ 22:03 0:00 ps aux USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND root 1 0.0 0.2 26404 4940 ? Ss 19:50 0:03 /sbin/init scandelay root 2 0.0 0.0 0 0 ? S 19:50 0:00 [kthreadd] root 4 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/0:0H] root 6 0.0 0.0 0 0 ? I< 19:50 0:00 [mm_percpu_wq] root 7 0.0 0.0 0 0 ? S 19:50 0:01 [ksoftirqd/0] root 8 0.1 0.0 0 0 ? I 19:50 0:11 [rcu_preempt] root 9 0.0 0.0 0 0 ? I 19:50 0:00 [rcu_sched] root 10 0.0 0.0 0 0 ? I 19:50 0:00 [rcu_bh] root 11 0.0 0.0 0 0 ? S 19:50 0:00 [migration/0] root 12 0.0 0.0 0 0 ? S 19:50 0:00 [cpuhp/0] root 13 0.0 0.0 0 0 ? S 19:50 0:00 [cpuhp/1] root 14 0.0 0.0 0 0 ? S 19:50 0:00 [migration/1] root 15 0.0 0.0 0 0 ? S 19:50 0:01 [ksoftirqd/1] root 17 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/1:0H] root 18 0.0 0.0 0 0 ? S 19:50 0:00 [cpuhp/2] root 19 0.0 0.0 0 0 ? S 19:50 0:00 [migration/2] root 20 0.0 0.0 0 0 ? S 19:50 0:00 [ksoftirqd/2] root 22 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/2:0H] root 23 0.0 0.0 0 0 ? S 19:50 0:00 [cpuhp/3] root 24 0.0 0.0 0 0 ? S 19:50 0:00 [migration/3] root 25 0.0 0.0 0 0 ? S 19:50 0:02 [ksoftirqd/3] root 27 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/3:0H] root 28 0.0 0.0 0 0 ? S 19:50 0:00 [kdevtmpfs] root 29 0.0 0.0 0 0 ? I< 19:50 0:00 [netns] root 31 0.0 0.0 0 0 ? S 19:50 0:00 [khungtaskd] root 32 0.0 0.0 0 0 ? S 19:50 0:00 [oom_reaper] root 33 0.0 0.0 0 0 ? I< 19:50 0:00 [writeback] root 34 0.0 0.0 0 0 ? I< 19:50 0:00 [crypto] root 35 0.0 0.0 0 0 ? I< 19:50 0:00 [kblockd] root 36 0.0 0.0 0 0 ? I< 19:50 0:00 [md] root 37 0.0 0.0 0 0 ? I< 19:50 0:00 [devfreq_wq] root 38 0.0 0.0 0 0 ? I< 19:50 0:00 [cfg80211] root 39 0.0 0.0 0 0 ? I< 19:50 0:00 [watchdogd] root 40 0.0 0.0 0 0 ? I< 19:50 0:00 [rpciod] root 41 0.0 0.0 0 0 ? I< 19:50 0:00 [xprtiod] root 42 0.0 0.0 0 0 ? S 19:50 0:00 [kswapd0] root 43 0.0 0.0 0 0 ? S 19:50 0:00 [ecryptfs-kthrea] root 44 0.0 0.0 0 0 ? I< 19:50 0:00 [nfsiod] root 45 0.0 0.0 0 0 ? I< 19:50 0:00 [cifsiod] root 46 0.0 0.0 0 0 ? I< 19:50 0:00 [cifsoplockd] root 47 0.0 0.0 0 0 ? S 19:50 0:00 [jfsIO] root 48 0.0 0.0 0 0 ? S 19:50 0:00 [jfsCommit] root 49 0.0 0.0 0 0 ? S 19:50 0:00 [jfsCommit] root 50 0.0 0.0 0 0 ? S 19:50 0:00 [jfsCommit] root 51 0.0 0.0 0 0 ? S 19:50 0:00 [jfsCommit] root 52 0.0 0.0 0 0 ? S 19:50 0:00 [jfsSync] root 53 0.0 0.0 0 0 ? I< 19:50 0:00 [xfsalloc] root 54 0.0 0.0 0 0 ? I< 19:50 0:00 [xfs_mru_cache] root 92 0.0 0.0 0 0 ? I< 19:50 0:00 [kthrotld] root 93 0.0 0.0 0 0 ? S 19:50 0:00 [spi2] root 94 0.0 0.0 0 0 ? I< 19:50 0:00 [libertastf] root 96 0.0 0.0 0 0 ? S 19:50 0:00 [irq/79-rk808] root 97 0.0 0.0 0 0 ? S 19:50 0:00 [irq/43-rockchip] root 98 0.0 0.0 0 0 ? I< 19:50 0:00 [raid5wq] root 99 0.0 0.0 0 0 ? I< 19:50 0:00 [dm_bufio_cache] root 102 0.0 0.0 0 0 ? I< 19:50 0:00 [ipv6_addrconf] root 103 0.0 0.0 0 0 ? S< 19:50 0:00 [krfcommd] root 106 0.0 0.0 0 0 ? S 19:50 0:00 [irq/57-ff980000] root 108 0.0 0.0 0 0 ? S 19:50 0:01 [mmcqd/0] root 143 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/1:1H] root 147 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/0:1H] root 167 0.0 0.0 0 0 ? S 19:50 0:00 [jbd2/mmcblk0p1-] root 168 0.0 0.0 0 0 ? I< 19:50 0:00 [ext4-rsv-conver] root 182 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/3:1H] root 189 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/2:1H] root 263 0.0 0.1 12368 2604 ? Ss 19:50 0:00 /lib/systemd/systemd-udevd root 385 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/u9:0] root 386 0.0 0.0 0 0 ? I< 19:50 0:00 [kbase_job_fault] root 387 0.0 0.0 0 0 ? I< 19:50 0:00 [kworker/u9:1] root 462 0.1 0.2 27112 5052 ? Ss 19:50 0:09 /lib/systemd/systemd-journald root 498 0.0 0.2 7216 4116 ? Ss 19:50 0:03 /usr/sbin/haveged --Foreground --verbose=1 -w 1024 message+ 518 0.0 0.1 5412 2960 ? Ss 19:50 0:02 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation root 540 0.1 0.6 96832 13604 ? Ssl 19:50 0:09 /usr/sbin/NetworkManager --no-daemon root 551 0.0 0.1 6128 3480 ? Ss 19:50 0:00 /lib/systemd/systemd-logind root 649 0.0 0.2 8500 4460 ? Ss 19:50 0:00 /usr/sbin/sshd -D root 830 0.0 0.0 0 0 ? S 19:50 0:00 [RTW_XMIT_THREAD] root 831 0.1 0.0 0 0 ? S 19:50 0:08 [RTW_CMD_THREAD] root 832 0.0 0.0 0 0 ? S 19:50 0:00 [RTWHALXT] root 834 0.0 0.2 37544 5908 ? Ssl 19:50 0:00 /usr/lib/policykit-1/polkitd --no-debug root 839 0.0 0.2 7876 4932 ? Ss 19:50 0:02 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant root 862 0.0 0.1 5256 2832 ? S 19:50 0:00 /sbin/dhclient -d -q -sf /usr/lib/NetworkManager/nm-dhcp-helper -pf /var/run/dhclient-eth0.pid -lf /var/lib/NetworkManager/dhclient-27abdbc0-957a-3b32-a9ca-609cde406708-eth0.lease -cf /var/lib/NetworkManager/dhclient-eth0.conf eth0 root 1100 0.0 0.1 5256 2056 ? Ss 19:50 0:00 /sbin/dhclient -4 -v -pf /run/dhclient.eth0.pid -lf /var/lib/dhcp/dhclient.eth0.leases -I -df /var/lib/dhcp/dhclient6.eth0.leases eth0 root 1152 0.1 0.5 904924 11012 ? Ssl 19:50 0:10 /usr/share/filebeat/bin/filebeat -c /etc/filebeat/filebeat.yml -path.home /usr/share/filebeat -path.config /etc/filebeat -path.data /var/lib/filebeat -path.logs /var/log/filebeat ntp 1189 0.0 0.1 6900 2868 ? Ssl 19:50 0:01 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 106:110 root 1441 0.0 0.0 0 0 ? I 20:58 0:00 [kworker/1:0] root 2123 0.0 0.0 3476 1580 ttyS2 Ss+ 19:51 0:00 /sbin/agetty --keep-baud 115200,38400,9600 ttyS2 linux root 2125 0.0 0.1 5016 2300 tty1 Ss 19:51 0:00 /bin/login -- root 2786 0.0 0.0 23092 2040 ? Ssl 19:53 0:01 /usr/sbin/rsyslogd -n root 10613 0.0 0.0 0 0 ? I 21:38 0:00 [kworker/3:0] root 17260 0.1 0.0 0 0 ? I 21:46 0:01 [kworker/0:1] root 18766 0.0 0.0 0 0 ? I 21:48 0:00 [kworker/u8:4] root 18771 0.0 0.0 0 0 ? I 21:48 0:00 [kworker/u8:6] root 24439 0.0 0.1 7580 4100 ? Ss 21:50 0:00 /lib/systemd/systemd --user root 24442 0.0 0.0 27876 1296 ? S 21:50 0:00 (sd-pam) root 24448 0.1 0.1 5704 3968 tty1 S 21:50 0:01 -bash root 25273 0.0 0.0 0 0 ? I 20:53 0:00 [kworker/2:2] root 27684 0.1 0.0 0 0 ? I 21:53 0:00 [kworker/3:1] root 27748 0.0 0.0 0 0 ? I 21:54 0:00 [kworker/0:2] root 27751 0.1 0.0 0 0 ? I 21:54 0:00 [kworker/1:2] root 27774 0.0 0.0 0 0 ? I 21:56 0:00 [kworker/2:1] root 27830 0.0 0.0 0 0 ? I 21:59 0:00 [kworker/0:0] root 27872 0.0 0.0 4388 656 tty1 S 22:01 0:00 ping 192.168.0.1 -O root 27918 0.0 0.1 6728 2376 tty1 R+ 22:03 0:00 ps aux UNIT LOAD ACTIVE SUB DESCRIPTION proc-sys-fs-binfmt_misc.automount loaded inactive dead Arbitrary Executable File Formats File System Automount Point dev-disk-by\x2did-mmc\x2dSC16G_0x336240ed.device loaded active plugged /dev/disk/by-id/mmc-SC16G_0x336240ed dev-disk-by\x2did-mmc\x2dSC16G_0x336240ed\x2dpart1.device loaded active plugged /dev/disk/by-id/mmc-SC16G_0x336240ed-part1 dev-disk-by\x2dpartuuid-1abd305f\x2d01.device loaded active plugged /dev/disk/by-partuuid/1abd305f-01 dev-disk-by\x2dpath-platform\x2dff0c0000.dwmmc.device loaded active plugged /dev/disk/by-path/platform-ff0c0000.dwmmc dev-disk-by\x2dpath-platform\x2dff0c0000.dwmmc\x2dpart1.device loaded active plugged /dev/disk/by-path/platform-ff0c0000.dwmmc-part1 dev-disk-by\x2duuid-733e4b8f\x2d8cdf\x2d42ad\x2d85a4\x2d6d5487409e6e.device loaded active plugged /dev/disk/by-uuid/733e4b8f-8cdf-42ad-85a4-6d5487409e6e dev-mmcblk0.device loaded active plugged /dev/mmcblk0 dev-mmcblk0p1.device loaded active plugged /dev/mmcblk0p1 dev-ram0.device loaded active plugged /dev/ram0 dev-rfkill.device loaded active plugged /dev/rfkill dev-ttyS0.device loaded active plugged /dev/ttyS0 dev-ttyS1.device loaded active plugged /dev/ttyS1 dev-ttyS2.device loaded active plugged /dev/ttyS2 dev-ttyS3.device loaded active plugged /dev/ttyS3 sys-devices-platform-ff0c0000.dwmmc-mmc_host-mmc0-mmc0:aaaa-block-mmcblk0-mmcblk0p1.device loaded active plugged /sys/devices/platform/ff0c0000.dwmmc/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1 sys-devices-platform-ff0c0000.dwmmc-mmc_host-mmc0-mmc0:aaaa-block-mmcblk0.device loaded active plugged /sys/devices/platform/ff0c0000.dwmmc/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0 sys-devices-platform-ff0d0000.dwmmc-mmc_host-mmc1-mmc1:0001-mmc1:0001:1-net-wlan0.device loaded active plugged /sys/devices/platform/ff0d0000.dwmmc/mmc_host/mmc1/mmc1:0001/mmc1:0001:1/net/wlan0 sys-devices-platform-ff180000.serial-tty-ttyS0.device loaded active plugged /sys/devices/platform/ff180000.serial/tty/ttyS0 sys-devices-platform-ff190000.serial-tty-ttyS1.device loaded active plugged /sys/devices/platform/ff190000.serial/tty/ttyS1 sys-devices-platform-ff1b0000.serial-tty-ttyS3.device loaded active plugged /sys/devices/platform/ff1b0000.serial/tty/ttyS3 sys-devices-platform-ff290000.ethernet-net-eth0.device loaded active plugged /sys/devices/platform/ff290000.ethernet/net/eth0 sys-devices-platform-ff500000.usb-usb2-2\x2d1-2\x2d1:1.0-sound-card0.device loaded active plugged USB_Audio sys-devices-platform-ff690000.serial-tty-ttyS2.device loaded active plugged /sys/devices/platform/ff690000.serial/tty/ttyS2 sys-devices-virtual-block-ram0.device loaded active plugged /sys/devices/virtual/block/ram0 sys-devices-virtual-misc-rfkill.device loaded active plugged /sys/devices/virtual/misc/rfkill sys-devices-virtual-net-dummy0.device loaded active plugged /sys/devices/virtual/net/dummy0 sys-devices-virtual-net-ip6tnl0.device loaded active plugged /sys/devices/virtual/net/ip6tnl0 sys-devices-virtual-net-sit0.device loaded active plugged /sys/devices/virtual/net/sit0 sys-module-configfs.device loaded active plugged /sys/module/configfs sys-subsystem-net-devices-dummy0.device loaded active plugged /sys/subsystem/net/devices/dummy0 sys-subsystem-net-devices-eth0.device loaded active plugged /sys/subsystem/net/devices/eth0 sys-subsystem-net-devices-ip6tnl0.device loaded active plugged /sys/subsystem/net/devices/ip6tnl0 sys-subsystem-net-devices-sit0.device loaded active plugged /sys/subsystem/net/devices/sit0 sys-subsystem-net-devices-wlan0.device loaded active plugged /sys/subsystem/net/devices/wlan0 -.mount loaded active mounted Root Mount dev-hugepages.mount loaded inactive dead Huge Pages File System dev-mqueue.mount loaded active mounted POSIX Message Queue File System proc-sys-fs-binfmt_misc.mount loaded inactive dead Arbitrary Executable File Formats File System run-user-0.mount loaded active mounted /run/user/0 sys-fs-fuse-connections.mount loaded inactive dead FUSE Control File System sys-kernel-config.mount loaded active mounted Configuration File System sys-kernel-debug-tracing.mount loaded active mounted /sys/kernel/debug/tracing sys-kernel-debug.mount loaded active mounted Debug File System tmp.mount loaded active mounted /tmp var-log.hdd.mount loaded active mounted /var/log.hdd var-log.mount loaded active mounted /var/log systemd-ask-password-console.path loaded active waiting Dispatch Password Requests to Console Directory Watch systemd-ask-password-wall.path loaded active waiting Forward Password Requests to Wall Directory Watch init.scope loaded active running System and Service Manager session-c14.scope loaded active running Session c14 of user root alsa-restore.service loaded active exited Save/Restore Sound Card State alsa-state.service loaded inactive dead Manage Sound Card State (restore and store) ● apparmor.service not-found inactive dead apparmor.service apt-daily-upgrade.service loaded inactive dead Daily apt upgrade and clean activities apt-daily.service loaded inactive dead Daily apt download activities armhwinfo.service loaded active exited LSB: Armbian gathering hardware information ● auditd.service not-found inactive dead auditd.service ● bluetooth.service not-found inactive dead bluetooth.service ● console-screen.service not-found inactive dead console-screen.service console-setup.service loaded active exited Set console font and keymap cpufrequtils.service loaded active exited LSB: set CPUFreq kernel parameters cron.service loaded inactive dead Regular background program processing daemon dbus.service loaded active running D-Bus System Message Bus ● display-manager.service not-found inactive dead display-manager.service emergency.service loaded inactive dead Emergency Shell fake-hwclock.service loaded active exited Restore / save the current clock filebeat.service loaded active running filebeat firstrun-config.service loaded inactive dead Armbian first run optional user configuration getty-static.service loaded inactive dead getty on tty2-tty6 if dbus and logind are not available getty@tty1.service loaded active running Getty on tty1 haveged.service loaded active running Entropy daemon using the HAVEGE algorithm hddtemp.service loaded active exited LSB: disk temperature monitoring daemon hostapd.service loaded active exited LSB: Advanced IEEE 802.11 management daemon ifup@eth0.service loaded active exited ifup for eth0 ● kbd.service not-found inactive dead kbd.service keyboard-setup.service loaded active exited Set the console keyboard layout kmod-static-nodes.service loaded active exited Create list of required static device nodes for the current kernel loadcpufreq.service loaded active exited LSB: Load kernel modules needed to enable cpufreq scaling log2ram.service loaded active exited Armbian enhanced Log2Ram ● mountkernfs.service masked inactive dead mountkernfs.service networking.service loaded active exited Raise network interfaces NetworkManager-wait-online.service loaded active exited Network Manager Wait Online NetworkManager.service loaded active running Network Manager ntp.service loaded active running LSB: Start NTP daemon ● plymouth-quit-wait.service not-found inactive dead plymouth-quit-wait.service ● plymouth-start.service not-found inactive dead plymouth-start.service polkit.service loaded active running Authorization Manager ● rc-local.service loaded failed failed /etc/rc.local Compatibility rescue.service loaded inactive dead Rescue Shell resolvconf.service loaded active exited Nameserver information manager rsync.service loaded inactive dead fast remote file copy program daemon rsyslog.service loaded active running System Logging Service serial-getty@ttyS2.service loaded active running Serial Getty on ttyS2 ssh.service loaded active running OpenBSD Secure Shell server sshtunnel.service loaded inactive dead Establishes SSH tunnel to master sysfsutils.service loaded active exited LSB: Set sysfs variables from /etc/sysfs.conf sysstat.service loaded active exited LSB: Start/stop sysstat's sadc systemd-ask-password-console.service loaded inactive dead Dispatch Password Requests to Console systemd-ask-password-wall.service loaded inactive dead Forward Password Requests to Wall systemd-binfmt.service loaded inactive dead Set Up Additional Binary Formats systemd-fsck-root.service loaded inactive dead File System Check on Root Device systemd-fsckd.service loaded inactive dead File System Check Daemon to report status systemd-hwdb-update.service loaded inactive dead Rebuild Hardware Database systemd-initctl.service loaded inactive dead /dev/initctl Compatibility Daemon systemd-journal-flush.service loaded active exited Flush Journal to Persistent Storage systemd-journald.service loaded active running Journal Service systemd-logind.service loaded active running Login Service systemd-machine-id-commit.service loaded inactive dead Commit a transient machine-id on disk systemd-modules-load.service loaded active exited Load Kernel Modules systemd-random-seed.service loaded active exited Load/Save Random Seed systemd-remount-fs.service loaded active exited Remount Root and Kernel File Systems systemd-rfkill.service loaded inactive dead Load/Save RF Kill Switch Status systemd-sysctl.service loaded active exited Apply Kernel Variables ● systemd-sysusers.service not-found inactive dead systemd-sysusers.service systemd-timesyncd.service loaded inactive dead Network Time Synchronization systemd-tmpfiles-clean.service loaded inactive dead Cleanup of Temporary Directories systemd-tmpfiles-setup-dev.service loaded active exited Create Static Device Nodes in /dev systemd-tmpfiles-setup.service loaded active exited Create Volatile Files and Directories systemd-udev-trigger.service loaded active exited udev Coldplug all Devices systemd-udevd.service loaded active running udev Kernel Device Manager ● systemd-update-done.service not-found inactive dead systemd-update-done.service systemd-update-utmp-runlevel.service loaded inactive dead Update UTMP about System Runlevel Changes systemd-update-utmp.service loaded active exited Update UTMP about System Boot/Shutdown systemd-user-sessions.service loaded active exited Permit User Sessions ● systemd-vconsole-setup.service not-found inactive dead systemd-vconsole-setup.service tinker-bluetooth-restart.service loaded inactive dead Bluetooth restart walkaround ● tinker-bluetooth.service loaded failed failed Realtek H5 bluetooth support unattended-upgrades.service loaded active exited Unattended Upgrades Shutdown user@0.service loaded active running User Manager for UID 0 wpa_supplicant.service loaded active running WPA supplicant -.slice loaded active active Root Slice system-getty.slice loaded active active system-getty.slice system-serial\x2dgetty.slice loaded active active system-serial\x2dgetty.slice system.slice loaded active active System Slice user-0.slice loaded active active User Slice of root user.slice loaded active active User and Session Slice dbus.socket loaded active running D-Bus System Message Bus Socket syslog.socket loaded active running Syslog Socket systemd-fsckd.socket loaded active listening fsck to fsckd communication Socket systemd-initctl.socket loaded active listening /dev/initctl Compatibility Named Pipe systemd-journald-audit.socket loaded inactive dead Journal Audit Socket systemd-journald-dev-log.socket loaded active running Journal Socket (/dev/log) systemd-journald.socket loaded active running Journal Socket systemd-rfkill.socket loaded active listening Load/Save RF Kill Switch Status /dev/rfkill Watch systemd-udevd-control.socket loaded active running udev Control Socket systemd-udevd-kernel.socket loaded active running udev Kernel Socket var-swap.swap loaded active active /var/swap basic.target loaded active active Basic System cryptsetup.target loaded active active Encrypted Volumes emergency.target loaded inactive dead Emergency Mode getty.target loaded active active Login Prompts graphical.target loaded active active Graphical Interface local-fs-pre.target loaded active active Local File Systems (Pre) local-fs.target loaded active active Local File Systems multi-user.target loaded active active Multi-User System network-online.target loaded active active Network is Online network-pre.target loaded inactive dead Network (Pre) network.target loaded active active Network nss-user-lookup.target loaded inactive dead User and Group Name Lookups paths.target loaded active active Paths remote-fs-pre.target loaded inactive dead Remote File Systems (Pre) remote-fs.target loaded active active Remote File Systems rescue.target loaded inactive dead Rescue Mode shutdown.target loaded inactive dead Shutdown slices.target loaded active active Slices sockets.target loaded active active Sockets sound.target loaded active active Sound Card swap.target loaded active active Swap sysinit.target loaded active active System Initialization ● syslog.target not-found inactive dead syslog.target time-sync.target loaded active active System Time Synchronized timers.target loaded active active Timers umount.target loaded inactive dead Unmount All Filesystems apt-daily-upgrade.timer loaded active waiting Daily apt upgrade and clean activities apt-daily.timer loaded active waiting Daily apt download activities systemd-tmpfiles-clean.timer loaded active waiting Daily Cleanup of Temporary Directories LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 177 loaded units listed. To show all installed unit files use 'systemctl list-unit-files'. Linux chprobe.chprobe20 4.14.36-rockchip #22 SMP PREEMPT Thu Apr 26 06:41:40 CEST 2018 armv7l GNU/Linux Edited April 26, 2018 by chwe spoilered log Link to comment Share on other sites More sharing options...
mpmc Posted April 26, 2018 Share Posted April 26, 2018 Are you able to paste what command/script you're using? I'll happily give it a run on my TB. Link to comment Share on other sites More sharing options...
TonyMac32 Posted April 26, 2018 Share Posted April 26, 2018 Indeed. I've seen a few reports of bad behavior on mainline kernels now with Tinker, I'll poke around and see if there's any explanation for it from the kernel side. Link to comment Share on other sites More sharing options...
berre Posted April 27, 2018 Author Share Posted April 27, 2018 Hi, I've now isolated the problem. It occurs when I'm running bbk_cli (this is a speedtest, similiar to ookla and such). When I run this test over IPv6 specfically, the whole network will break down as described earlier. Using the very same binary for IPv4 tests works just fine... It's just when I'm running the IPv6 test. This binary runs OK in for example RPI3 (not sure about kernel, but I've only tested on CentOS). Can check these details if it's interesting. I also noted it seems to occur when the upstream is being tested. Running similiar traffic patterns with iperf3 over IPv6 seems to work OK.. But this one is different as it uses HTTP protocol. About the BBK speedtest: https://ensupport.bredbandskollen.se/support/solutions/articles/1000228167-how-does-the-measurement-work-in-technical-terms- How to reproduce: Download and install BBK @ https://beta1.bredbandskollen.se/download/bbk-cli_0.3.8_armhf.deb Run the IPv6 test (the test should crash when the upstream test starts): root@tinkerboard:~# bbk_cli --v6 Start: 2018-04-27 07:48:31 [ipv6] Latency: 150.650 ms Download: 826.816 Mbit/s Upload: 8.141 Mbit/s /B Link to comment Share on other sites More sharing options...
Rfreire Posted April 28, 2018 Share Posted April 28, 2018 Hi there @berre Would you be willing to run your test along 'dstat -cdnm' and: - Paste us around 15 lines of good behaviour - Paste us the same 15 lines when you're getting the bad behaviour Looking forward, - RF. Link to comment Share on other sites More sharing options...
berre Posted April 29, 2018 Author Share Posted April 29, 2018 Hi @Rfreire See the output below. The send counter never increases when I'm running the IPv6 traffic, it dies of too quickly I guess. The IPv4 test shows that expected traffic pattern. I also tried reproducing this problem with curl and POST, e.g "curl -6 -XPOST -d @bigfile http://[ipv6-address]. This works just fine, even when I'm paralleling 4-5 streams. Idle: Spoiler ----total-cpu-usage---- -dsk/total- -net/total- ------memory-usage----- usr sys idl wai hiq siq| read writ| recv send| used buff cach free 3 4 92 1 0 0|2715k 34k| 0 0 |65.9M 9932k 91.6M 1838M 0 0 100 0 0 0| 0 0 | 246B 42B|65.9M 9932k 91.6M 1838M 0 0 100 0 0 0| 0 0 | 266B 78B|65.9M 9932k 91.6M 1838M 0 0 100 0 0 0| 0 0 | 335B 86B|65.9M 9932k 91.6M 1838M 0 0 100 0 0 0| 0 0 | 240B 0 |65.9M 9932k 91.6M 1838M 0 0 100 0 0 0| 0 0 | 60B 0 |65.9M 9932k 91.6M 1838M 0 0 100 0 0 0| 0 0 | 306B 0 |65.9M 9932k 91.6M 1838M 0 0 99 0 0 0| 0 0 | 180B 0 |65.9M 9932k 91.6M 1838M 0 0 100 0 0 0| 0 0 | 326B 78B|65.9M 9932k 91.6M 1838M 0 0 100 0 0 0| 0 0 | 137B 0 |65.9M 9932k 91.6M 1838M 0 0 100 0 0 0| 0 0 | 180B 0 |65.9M 9932k 91.6M 1838M 0 0 100 0 0 0| 0 0 | 306B 0 |65.9M 9932k 91.6M 1838M 0 0 100 0 0 0| 0 0 | 240B 0 |65.9M 9932k 91.6M 1838M 0 0 100 0 0 0| 0 0 | 60B 0 |65.9M 9932k 91.6M 1838M 0 0 100 0 0 0| 0 0 | 180B 0 |65.9M 9932k 91.6M 1838M 0 0 100 0 0 0| 0 0 | 257B 0 |65.9M 9932k 91.6M 1838M 0 0 100 0 0 0| 0 0 | 366B 0 |65.9M 9932k 91.6M 1838M 0 0 100 0 0 0| 0 0 | 60B 0 |65.9M 9932k 91.6M 1838M 0 0 100 0 0 0| 0 0 | 180B 0 |65.9M 9932k 91.6M 1838M 0 0 100 0 0 0| 0 0 | 342B 96B|65.9M 9932k 91.6M 1838M 2 1 97 0 0 0| 40k 0 |3797B 2319B|66.7M 9932k 91.6M 1837M 0 1 99 0 0 0| 0 0 | 263B 0 |66.8M 9932k 91.6M 1837M 2 1 97 0 0 0| 0 0 | 774B 446B|66.9M 9932k 91.6M 1837M 5 7 88 0 0 0| 48k 0 |1594B 3736B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 330B 0 |69.8M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 150B 90B|69.8M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 396B 90B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 257B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 60B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 306B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 8192B| 240B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 809B 408B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 348B 102B|69.7M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 348B 102B|69.7M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 |1302B 944B|69.7M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 60B 0 |69.7M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.7M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 257B 0 |69.7M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 240B 0 |69.7M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 186B 0 |69.7M 9936k 91.6M 1834M 1 2 97 0 0 0| 0 0 | 180B 0 |69.7M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 137B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 306B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 60B 0 |69.9M 9936k 91.6M 1834M 1 0 99 0 0 0| 0 0 |1656B 0 |69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 383B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 60B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 330B 130B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 366B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 227B 90B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 610B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 270B 90B|69.9M 9936k 91.6M 1834M 1 2 98 0 0 0| 0 0 | 656B 470B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 42B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 16k| 377B 42B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 60B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 332B 78B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 258B 86B|69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 2 98 0 0 0| 0 0 | 257B 0 |69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 306B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 266B 78B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 257B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 306B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 1 0 99 0 0 0| 0 0 |1656B 0 |69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 383B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 246B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 257B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 270B 90B|69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 270B 90B|69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 300B 270B|69.9M 9936k 91.6M 1834M 1 1 99 0 0 0| 0 0 | 616B 220B|69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 450B 270B|69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 257B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 8192B| 120B 0 |69.9M 9936k 91.6M 1834M 1 2 98 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 366B 42B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 257B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 306B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 257B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 246B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 |1596B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 383B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 306B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 257B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 610B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 456B 90B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 197B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 240B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 16k| 186B 0 |69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 440B 242B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 407B 90B|69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 |1075B 270B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 306B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 404B 206B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 197B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 366B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 266B 78B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 1 0 99 0 0 0| 0 0 |1716B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 383B 0 |69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 |1345B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 709B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 246B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 197B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 246B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 257B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 456B 90B|69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 8192B| 470B 380B|69.9M 9936k 91.6M 1834M 1 2 97 0 0 0| 0 0 | 300B 90B|69.9M 9936k 91.6M 1834M 1 1 98 0 0 0| 0 0 | 487B 290B|70.0M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 456B 132B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 240B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 257B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 246B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 1 0 99 0 0 0| 0 0 |1596B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 323B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 300B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 366B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 257B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 550B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 390B 130B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 306B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 197B 0 |69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 240B 0 |69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 186B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 330B 90B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 16k| 137B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 246B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 42B|69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 350B 152B|69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 377B 180B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 306B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 270B 90B|69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 464B 344B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 |1596B 0 |69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 443B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 625B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 206B 78B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 246B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 257B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 306B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 317B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 246B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 257B 0 |69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 8192B| 120B 0 |69.9M 9936k 91.6M 1834M 1 1 98 0 0 0| 0 0 | 366B 0 |69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 210B 90B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 290B 110B|69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 210B 90B|69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 607B 380B|69.9M 9936k 91.6M 1834M 0 1 98 0 0 0| 0 0 | 336B 0 |69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 330B 132B|69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 210B 90B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.9M 9936k 91.6M 1834M 1 0 99 0 0 0| 0 0 |1686B 90B|69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 383B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 246B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 317B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 550B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 366B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 257B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 306B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 60B 0 |69.9M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 317B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 246B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 16k| 120B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 270B 90B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 197B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 246B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 42B|69.9M 9936k 91.6M 1834M 1 0 99 0 0 0| 0 0 |1716B 42B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 473B 90B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 170B 110B|69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 90B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 546B 180B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 137B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 434B 254B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 314B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 186B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 343B 78B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 60B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 306B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 137B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 306B 0 |69.8M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 240B 0 |69.8M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 16k| 60B 0 |69.8M 9936k 91.6M 1834M 1 1 98 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 257B 0 |69.9M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 366B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 60B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 270B 90B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 1 0 99 0 0 0| 0 0 |1806B 90B|69.8M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 353B 180B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 380B 110B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 42B|69.8M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 440B 200B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 150B 90B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 396B 90B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 347B 90B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 60B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 610B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 306B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 197B 42B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 330B 130B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 366B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 60B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 257B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 186B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 8192B| 120B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 197B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 306B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.8M 9936k 91.6M 1834M 1 0 99 0 0 0| 0 0 |1596B 0 |69.8M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 473B 90B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 120B 0 |69.8M 9936k 91.6M 1834M 0 1 98 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 366B 42B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 257B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 270B 90B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 506B 200B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 257B 0 |69.8M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 270B 90B|69.8M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 270B 90B|69.8M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 500B 254B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 257B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 392B 78B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 16k| 257B 0 |69.8M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 306B 0 |69.8M 9936k 91.6M 1834M 1 2 98 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 120B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 354B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 |1482B 0 |69.8M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 383B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 270B 90B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 246B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 347B 90B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 90B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 330B 42B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 810B 242B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 416B 110B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 347B 90B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 300B 180B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 270B 90B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 618B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 272B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 257B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.8M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 306B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 60B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 257B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 8192B| 306B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 60B 0 |69.8M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 240B 0 |69.8M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 354B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 |1422B 0 |69.8M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 323B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 366B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 347B 90B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 306B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 42B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 197B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 246B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 320B 200B|69.8M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 330B 90B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 257B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 336B 90B|69.8M 9936k 91.6M 1834M 0 1 98 0 0 0| 0 0 | 416B 168B|69.8M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 258B 86B|69.8M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 120B 0 |69.8M 9936k 91.6M 1834M 0 0 99 0 0 0| 0 0 | 287B 90B|69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 366B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 16k| 240B 42B|69.8M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 206B 78B|69.8M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 294B 0 |69.8M 9936k 91.6M 1834M 1 1 98 0 0 0| 0 0 |1542B 0 |69.8M 9936k 91.6M 1834M 0 1 99 0 0 0| 0 0 | 383B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 120B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 246B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 197B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 240B 0 |69.8M 9936k 91.6M 1834M 0 0 100 0 0 0| 0 0 | 180B 0 |69.8M 9936k 91.6M 1834M During IPv4 test: Spoiler ----total-cpu-usage---- -dsk/total- -net/total- ------memory-usage----- usr sys idl wai hiq siq| read writ| recv send| used buff cach free 0 0 99 0 0 0| 112k 1615B| 0 0 |78.2M 10.1M 93.2M 1824M 0 0 99 0 0 0| 0 0 | 318B 960B|78.3M 10.1M 93.2M 1824M 0 1 99 0 0 0| 0 0 | 312B 460B|78.3M 10.1M 93.2M 1824M 0 0 99 0 0 0| 0 0 | 312B 460B|78.3M 10.1M 93.2M 1824M 0 0 100 0 0 0| 0 0 | 252B 460B|78.3M 10.1M 93.2M 1824M 1 2 96 0 0 0| 0 0 |6452k 56k|77.2M 10.1M 93.2M 1825M 1 15 84 0 0 1| 0 0 | 92M 714k|77.4M 10.1M 93.2M 1824M 1 12 87 0 0 0| 0 0 | 93M 666k|77.8M 10.1M 93.2M 1824M 1 12 87 0 0 1| 0 0 | 94M 658k|77.8M 10.1M 93.2M 1824M 1 12 86 0 0 1| 0 0 | 96M 667k|77.8M 10.1M 93.2M 1824M 1 11 88 0 0 1| 0 0 | 100M 691k|77.9M 10.1M 93.2M 1824M 1 11 87 0 0 1| 0 0 | 105M 716k|77.7M 10.1M 93.2M 1824M 1 10 88 0 0 0| 0 0 | 88M 681k|77.8M 10.1M 93.2M 1824M 1 11 87 0 0 1| 0 0 | 92M 706k|78.1M 10.1M 93.2M 1824M 1 11 87 0 0 1| 0 0 | 95M 685k|78.2M 10.1M 93.2M 1824M 1 8 91 0 0 1| 0 0 | 61M 3793k|78.7M 10.1M 93.2M 1823M 0 3 97 0 0 1| 0 0 | 286k 16M|80.5M 10.1M 93.2M 1821M 0 3 96 0 0 0| 0 0 | 380k 16M|82.0M 10.1M 93.2M 1820M 0 2 97 0 0 1| 0 0 | 456k 15M|82.2M 10.1M 93.2M 1820M 0 1 98 0 0 0| 0 0 | 306k 14M|81.4M 10.1M 93.2M 1820M 0 1 98 0 0 0| 0 0 | 275k 14M|82.1M 10.1M 93.2M 1820M 0 1 98 0 0 0| 0 0 | 306k 14M|81.7M 10.1M 93.2M 1820M 0 1 98 0 0 0| 0 0 | 244k 12M|82.2M 10.1M 93.2M 1820M 0 1 98 0 0 0| 0 0 | 313k 15M|81.4M 10.1M 93.2M 1820M 0 1 98 0 0 0| 0 0 | 304k 13M|81.3M 10.1M 93.2M 1821M 0 1 99 0 0 0| 0 88k| 70k 2539k|79.4M 10.1M 93.2M 1822M 0 1 99 0 0 0| 0 0 | 602B 3620B|79.3M 10.1M 93.2M 1823M 0 0 100 0 0 0| 0 0 | 312B 1974B|79.3M 10.1M 93.2M 1823M 0 1 99 0 0 0| 0 0 | 192B 460B|79.3M 10.1M 93.2M 1823M 0 0 99 0 0 0| 0 0 | 252B 1974B|79.3M 10.1M 93.2M 1823M 0 0 100 0 0 0| 0 0 | 312B 460B|79.3M 10.1M 93.2M 1823M 0 0 99 0 0 0| 0 0 | 438B 460B|79.3M 10.1M 93.2M 1823M 0 0 99 0 0 0| 0 0 | 126B 1872B|79.3M 10.1M 93.2M 1823M 0 1 99 0 0 0| 0 0 | 186B 358B|79.3M 10.1M 93.2M 1823M 0 0 99 0 0 0| 0 0 | 246B 358B|79.3M 10.1M 93.2M 1823M 0 0 100 0 0 0| 0 0 | 246B 1872B|79.3M 10.1M 93.2M 1823M 0 0 99 0 0 0| 0 0 | 252B 358B|79.3M 10.1M 93.2M 1823M 0 0 99 0 0 0| 0 0 | 246B 400B|79.3M 10.1M 93.2M 1823M 0 1 99 0 0 0| 0 0 | 246B 358B|79.3M 10.1M 93.2M 1823M 0 0 99 0 0 0| 0 0 | 246B 1872B|79.3M 10.1M 93.2M 1823M 0 0 100 0 0 0| 0 0 | 126B 358B|79.3M 10.1M 93.2M 1823M 0 1 99 0 0 0| 0 0 | 312B 358B|79.3M 10.1M 93.2M 1823M 0 1 99 0 0 0| 0 0 | 246B 358B|79.3M 10.1M 93.2M 1823M 1 1 99 0 0 0| 0 0 | 420B 358B|79.3M 10.1M 93.2M 1823M 0 1 99 0 0 0| 0 0 | 126B 358B|79.3M 10.1M 93.2M 1823M 1 2 97 0 0 0| 0 0 |1488B 358B|79.4M 10.1M 93.2M 1822M 0 1 99 0 0 0| 0 0 | 372B 358B|79.5M 10.1M 93.2M 1822M 0 0 100 0 0 0| 0 0 | 246B 358B|79.5M 10.1M 93.2M 1822M 0 1 99 0 0 0| 0 0 | 276B 488B|79.5M 10.1M 93.2M 1822M During IPv6 test (and crash): Spoiler ----total-cpu-usage---- -dsk/total- -net/total- ------memory-usage----- usr sys idl wai hiq siq| read writ| recv send| used buff cach free 0 1 99 0 0 0| 169k 2792B| 0 0 |71.8M 10.1M 92.0M 1831M 0 0 100 0 0 0| 0 0 | 120B 0 |71.8M 10.1M 92.0M 1831M 0 0 99 0 0 0| 0 0 | 270B 130B|71.8M 10.1M 92.0M 1831M 0 0 100 0 0 0| 0 0 | 120B 0 |71.8M 10.1M 92.0M 1831M 0 0 100 0 0 0| 0 0 | 180B 0 |71.8M 10.1M 92.0M 1831M 0 0 100 0 0 0| 0 0 | 246B 0 |71.8M 10.1M 92.0M 1831M 0 0 100 0 0 0| 0 8192B| 120B 0 |71.8M 10.1M 92.0M 1831M 0 0 100 0 0 0| 0 0 | 120B 0 |71.8M 10.1M 92.0M 1831M 0 0 100 0 0 0| 0 0 | 180B 0 |71.8M 10.1M 92.0M 1831M 0 0 100 0 0 0| 0 0 | 120B 0 |71.8M 10.1M 92.0M 1831M 2 4 93 0 0 1|8192B 0 | 21M 300k|72.1M 10.1M 92.0M 1831M 1 15 82 0 0 2| 0 0 | 101M 1926k|76.1M 10.1M 92.0M 1827M 1 13 84 0 0 2| 0 8192B| 94M 1513k|72.3M 10.1M 92.0M 1831M 1 12 86 0 0 1| 0 0 | 95M 1440k|71.9M 10.1M 92.0M 1831M 1 11 86 0 0 1| 0 0 | 92M 1229k|72.1M 10.1M 92.0M 1831M 1 14 84 0 0 1| 0 0 | 106M 1583k|71.9M 10.1M 92.0M 1831M 1 10 85 0 0 3| 0 0 | 92M 1508k|72.1M 10.1M 92.0M 1831M 1 12 85 0 0 2| 0 0 | 99M 1606k|72.3M 10.1M 92.0M 1831M 1 11 87 0 0 1| 0 8192B| 94M 1388k|72.0M 10.1M 92.0M 1831M 1 10 87 0 0 3| 0 0 | 89M 1222k|72.2M 10.1M 92.0M 1831M 1 5 94 0 0 1| 0 0 | 44M 4955k|73.2M 10.1M 92.0M 1830M 0 0 99 0 0 0| 0 0 | 114k 2655k|73.4M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 130k 2995k|73.0M 10.1M 92.0M 1830M 0 0 99 0 0 0| 0 0 | 95k 2046k|73.5M 10.1M 92.0M 1830M 1 0 99 0 0 0| 0 8192B| 85k 1896k|73.3M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 13k 282k|73.2M 10.1M 92.0M 1830M 0 0 99 0 0 0| 0 0 | 623B 5309B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 206B 1824B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 810B 3803B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 266B 749B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 8192B|5645B 11k|73.1M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 |3799B 12k|73.1M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 |1159B 2972B|73.2M 10.1M 92.0M 1830M 0 0 99 0 0 0| 0 0 |1986B 3454B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 858B 1758B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 332B 98B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 8192B| 180B 1731B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 |1986B 4603B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 533B 5415B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 473B 98B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 306B 0 |73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 180B 0 |73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 8192B| 146B 98B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 120B 0 |73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 |1126B 2114B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 |1534B 3004B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 60B 94B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 120B 0 |73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 8192B| 180B 110B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 180B 200B|73.2M 10.1M 92.0M 1830M 0 1 99 0 0 0| 0 0 |1488B 0 |73.2M 10.1M 92.0M 1830M 1 2 97 0 0 0| 0 0 | 120B 1648B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 180B 3277B|73.2M 10.1M 92.0M 1830M 0 1 99 0 0 0| 0 0 | 180B 90B|73.2M 10.1M 92.0M 1830M 1 0 99 0 0 0| 0 8192B| 234B 42B|73.2M 10.1M 92.0M 1830M 1 0 99 0 0 0| 0 80k| 246B 298B|73.2M 10.1M 92.0M 1830M 0 1 99 0 0 0| 0 0 | 180B 42B|73.3M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 240B 42B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 120B 394B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 120B 1164B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 306B 1408B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 180B 86B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 60B 0 |73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 120B 206B|73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 180B 0 |73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 306B 0 |73.2M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 60B 0 |73.2M 10.1M 92.0M 1830M Link to comment Share on other sites More sharing options...
Rfreire Posted May 1, 2018 Share Posted May 1, 2018 Hello there, @berre o/ During your IPv6 tests: 0 0 100 0 0 0| 0 0 | 180B 0 |71.8M 10.1M 92.0M 1831M 0 0 100 0 0 0| 0 0 | 120B 0 |71.8M 10.1M 92.0M 1831M 2 4 93 0 0 1|8192B 0 | 21M 300k|72.1M 10.1M 92.0M 1831M 1 15 82 0 0 2| 0 0 | 101M 1926k|76.1M 10.1M 92.0M 1827M 1 13 84 0 0 2| 0 8192B| 94M 1513k|72.3M 10.1M 92.0M 1831M 1 12 86 0 0 1| 0 0 | 95M 1440k|71.9M 10.1M 92.0M 1831M 1 11 86 0 0 1| 0 0 | 92M 1229k|72.1M 10.1M 92.0M 1831M 1 14 84 0 0 1| 0 0 | 106M 1583k|71.9M 10.1M 92.0M 1831M 1 10 85 0 0 3| 0 0 | 92M 1508k|72.1M 10.1M 92.0M 1831M 1 12 85 0 0 2| 0 0 | 99M 1606k|72.3M 10.1M 92.0M 1831M 1 11 87 0 0 1| 0 8192B| 94M 1388k|72.0M 10.1M 92.0M 1831M 1 10 87 0 0 3| 0 0 | 89M 1222k|72.2M 10.1M 92.0M 1831M 1 5 94 0 0 1| 0 0 | 44M 4955k|73.2M 10.1M 92.0M 1830M 0 0 99 0 0 0| 0 0 | 114k 2655k|73.4M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 130k 2995k|73.0M 10.1M 92.0M 1830M 0 0 99 0 0 0| 0 0 | 95k 2046k|73.5M 10.1M 92.0M 1830M 1 0 99 0 0 0| 0 8192B| 85k 1896k|73.3M 10.1M 92.0M 1830M 0 0 100 0 0 0| 0 0 | 13k 282k|73.2M 10.1M 92.0M 1830M 0 0 99 0 0 0| 0 0 | 623B 5309B|73.2M 10.1M 92.0M 1830M I do see it filling up the available bandwidth (ranging from 92-101 MB/s; times 9 -> 808 ~ 909 Mbps. Pretty decent. The System CPU times (2nd column) are on par with the IPV4 tests. And matter of fact, the BW tests too. So there's no aberration to point you immediately. I will be travelling in the end of May and will buy a extra tinkerboard (as a backup and for playing) and will run your tests. Link to comment Share on other sites More sharing options...
berre Posted May 13, 2018 Author Share Posted May 13, 2018 Hi @Rfreire, You're right about the bandwidth in the downstream, this seems unaffected and does not cause the crash. But if you look at the upstream traffic instead (where the crash occurs on IPv6) you'll see there's very little bandwidth being generated there, even though it's the same test. Looking forward to the results. Personally I haven't done much more on this yet.. It would be nice to see if someone else can reproduce it. /B Link to comment Share on other sites More sharing options...
