ArmbianCubox-i_User1 Posted May 7, 2018 Posted May 7, 2018 Hello, I have a brand new cubox-i4x4 and am attempting to install Armbian Stretch mainline kernel 4.15.y I downloaded the image from https://dl.armbian.com/cubox-i/Debian_stretch_next.7z used keka and etch to extract and write image to the SD card. After installing the SD card in the cubox and powering on, it gets stuck at: U-Boot SPL 2017.11-armbian (Jan 24 2018 - 22:39:16) Trying to boot from MMC1 U-Boot 2017.11-armbian (Jan 24 2018 - 22:39:16 +0100) CPU: Freescale i.MX6Q rev1.5 996 MHz (running at 792 MHz) CPU: Extended Commercial temperature grade (-20C to 105C) at 24C Reset cause: POR Board: MX6 Cubox-i DRAM: 2 GiB MMC: FSL_SDHC: 0 *** Warning - bad CRC, using default environment No panel detected: default to HDMI Display: HDMI (1024x768) In: serial Out: serial Err: serial Net: FEC Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 1816 bytes read in 104 ms (16.6 KiB/s) ## Executing script at 12000000 0 bytes read in 67 ms (0 Bytes/s) 113 bytes read in 83 ms (1000 Bytes/s) 38007 bytes read in 221 ms (167 KiB/s) 4824515 bytes read in 365 ms (12.6 MiB/s) 5546904 bytes read in 407 ms (13 MiB/s) ## Loading init Ramdisk from Legacy Image at 14800000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 4824451 Bytes = 4.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 18000000 Booting using the fdt blob at 0x18000000 Using Device Tree in place at 18000000, end 1800c476 Starting kernel ... Uncompressing Linux... done, booting the kernel. I have tried setting the fdt_file parameter in /boot/armbianEnv.txt file and tried all the available variant of imx6q-cubix-i*.dtb files but get the same result. The cubox boots ok from Solid-run's ignition image, but I want to install armbian. Any advice would be greatly apprciated.
Igor Posted May 30, 2018 Posted May 30, 2018 On 5/7/2018 at 2:49 PM, ArmbianCubox-i_User1 said: The cubox boots ok from Solid-run's ignition image, but I want to install armbian. Any advice would be greatly apprciated. Try DEV images:
