SPDIF not working due to a bug in kernel 4.16.8, after Cubox-i4Pro Armbian Ubuntu upgraded from 5.38 to 5.44
Hello everyone,
just wanted to let you know, upgrade from Armbian Ubuntu 5.38 to 5.44 caused problems on my Cubox-i4Pro.
- Armbian Ubuntu 5.38 headless (no display connected to Cubox-i) worked perfectly, there were no issues with anything.
- Upgraded Armbian Ubuntu 5.38 to 5.44 (apt-get) and rebooted
- After reboot, no audio was sent to my audio amplifier (through Toslink optical cable) by Shairport-Sync 3.1.7 (AirPlay emulator). Airplay was visible on my iOS devices (iPad, iPhone) and audio was streamed from iOS to AirPlay, but no audio was sent by Cubox-i to the optical connection to my audio amplifier.
- Removed the Shairport package using dpkg -r
- Rebooted Cubox-i using command reboot, but Cubox-i not booting anymore, SSH connection not possible anymore, red LED on Cubox-i is off (I think the LED was off also on Armbian ver. 5.38)
- Unplugged the power cable, waited a minute, restored power, Cubox-i not booting, no SSH
I'll restore the system ver. 5.38 from my backup image.
Please let me know if I can be of any help.
Thanks!
On which kernel? If I understand correctly ... Cubox booted to new system fine, only audio was missing?
First reboot after packages were upgraded to 5.44, Cubox-i booted, but no audio. After second reboot, Cubox-i did not boot anymore (no SSH).
I've just restored Armbian Ubuntu 5.38 from my backup image.
Upgraded only the package "linux-image-next-cubox 5.44", (armhf Linux kernel, version 4.16.8-cubox),  no other packages upgraded.
Cubox-i booted, but no audio on optical.
Just let me know if you need me to test anything else.
Understand. But what did you run before, exactly which kernel? I know that we have 4.16.8 now. Can you run armbianmonitor -u to see logs of the working system.
I can see in the log:
Kernel 4.14.14:
[ 1.775033] imx-spdif sound-spdif: snd-soc-dummy-dai <-> 2004000.spdif mapping ok
Kernel 4.16.8:
[ 1.764797] imx-spdif sound-spdif: ASoC: CPU DAI (null) not registered
[ 1.764810] imx-spdif sound-spdif: snd_soc_register_card failed: -517
  • chun.de.lac changed the title to SPDIF not working due to a bug in kernel 4.16.8, after Cubox-i4Pro Armbian Ubuntu upgraded from 5.38 to 5.44
Hello Igor,
after my Cubox-i was upgraded from Armbian 5.60 to 5.70 today, SPDIF audio output stopped working.
Report:
http://ix.io/1yjz
Armbian 5.70:
Operating system     Ubuntu Linux 18.04.1
Kernel and CPU     Linux 4.19.14-cubox on armv7l
SPDIF audio output used to work properly with Armbian 5.60 (kernel 4.14.70)
Please, let me know if I can be of any further help.
Thank you!
armbian-config -> alternative kernels -> switch to latest 4.14.y kernel
I've restored Armbian 5.60 from SD backup image, upgraded to Armbian 5.70 (Kernel 4.19.14), rebooted. The same way as before. Now it works. Can't explain why it works now, but thank you anyway!
