Carlos Rodrigues Posted May 20, 2018 Share Posted May 20, 2018 Need a little help. What board do you guys recommend for multi-room audio? What a need: - Something small like OPI zero or a bit bigger (that's the space i have inside the wall) - I2S for connecting a DAC - Onboard WiFi - Maybe a Micro and onboad flash I have an OPI Zero but it has no I2S The only ones that i know are C.H.I.P and and nanopi Air Link to comment Share on other sites More sharing options...
TonyMac32 Posted May 20, 2018 Share Posted May 20, 2018 1 hour ago, Carlos Rodrigues said: I have an OPI Zero but it has no I2S That would be surprising if true (I honestly don't know). However, if you look at the FriendlyElec NanoPi Neo or NanoPi Core, you'll get the same size and I2S (even a DAC if you aren't horribly picky: http://www.friendlyarm.com/index.php?route=product/product&product_id=151 http://www.friendlyarm.com/index.php?route=product/product&product_id=169 I did a write-up on using these with MPD, so I know for a fact they and the DAC work, but I don't think you'll need it. (actually linked on the FriendlyARM device page somehow...) I don't think anything else is that small, so you already know. Link to comment Share on other sites More sharing options...
Carlos Rodrigues Posted May 20, 2018 Author Share Posted May 20, 2018 Thanks for your help I just read your blog, and i guess that in the new kernel version we just have to go to armbian-config and enable the I2S and that is it. If so, i'm convinced. Link to comment Share on other sites More sharing options...
TonyMac32 Posted May 20, 2018 Share Posted May 20, 2018 The device tree is a beautiful thing. Link to comment Share on other sites More sharing options...
