Brent Fraser Weatherall Posted June 5, 2018 Posted June 5, 2018 Hello, Is a native 240p timings/resolution possible from the OrangePi PC via the A/V jack? I'd like to use it hooked up to a nice CRT for emulation.
jernej Posted June 5, 2018 Posted June 5, 2018 56 minutes ago, Brent Fraser Weatherall said: Is a native 240p timings/resolution possible from the OrangePi PC via the A/V jack? Only PAL and NTSC are possible.
Brent Fraser Weatherall Posted June 5, 2018 Author Posted June 5, 2018 I know RPi have added support recently (https://github.com/raspberrypi/firmware/issues/683#issuecomment-283179792) - so I was wondering if something similar might have made it's way into kernel to support a similar approach to outputting 240p NTSC/PAL. I think it might depend on if the A/V chipset can support whatever trick is required to support doing 240p from whatever is fed to it. I'm not sure where'd I start looking for details on that.
