Hello.
Sorry for my bad English.
I have just acquired an Orange Pi plus 2e.
Armbian Xenial is installed on emmc.
I wish my SD card to become my /home.
Can you help me?
Thank you.
I guess you can make a symbolic link, a shortcut from your home folder that points t te SD card.
Note that you'll have to delete your home folder before running the command.
If you do not delete ir beforehand, you'll end up with a folder like this: /home/home
ln -s /home [YOUR SD CARD PATH]
Hello, thank you for the answer but I managed it thanks to this method (4.2 section of this web page -French Ubuntu site - : https://doc.ubuntu-fr.org/tutoriel/deplacer_home )
Copy the contents of the current / home into the new:
     sudo rsync -av /home/ /new.home
Check for security the contents of the future / home:
     ls -la /new.home
Then change the name of the old / home to /old.home:
     sudo mv /home /old.home
Restart Disk-Manager to assign the new mount point / home to the sdaX partition
Restart the computer. The new / home is mounted and in use.
