napo7 Posted June 8, 2018 Share Posted June 8, 2018 Hi I managed to get armbian on my Amlogic S905W device. I'd like to run the whole root fs on an external usb device (ssd). I know how to format it to ext4, mount it, but I can't manage to boot linux on it : I tried to modify the /etc/fstab file, but it seems that it's not the good place ? Perhaps a file in /boot ? Link to comment Share on other sites More sharing options...
balbes150 Posted June 8, 2018 Share Posted June 8, 2018 Where is the BOOT partition and kernel files with startup scripts? Link to comment Share on other sites More sharing options...
napo7 Posted June 8, 2018 Author Share Posted June 8, 2018 Hmmm Good question ! I don't know, I suppose in some /dev/mmc.... device ? It's the stock image (an x96 mini tv box) I'm very comfident with linux on desktop, servers and rpi, but not with this kind of devices (uboot ?) s905_autoscript contains : setenv initrd_loadaddr "0x13000000" setenv init_hdmi "logo=osd1,loaded,${fb_addr},${hdmimode} vout=${hdmimode},enable" setenv condev "console=ttyS0,115200n8 console=tty0 no_console_suspend consoleblank=0" setenv bootargs "root=LABEL=ROOTFS rootflags=data=writeback rw ${init_hdmi} ${condev} fsck.repair=yes net.ifnames=0 mac=${mac}" setenv boot_start booti ${kernel_loadaddr} ${initrd_loadaddr} ${dtb_mem_addr} if fatload usb 0 ${initrd_loadaddr} uInitrd; then if fatload usb 0 ${kernel_loadaddr} zImage; then if fatload usb 0 ${dtb_mem_addr} dtb.img; then run boot_start; else store dtb read ${dtb_mem_addr}; run boot_start;fi;fi;fi; if fatload usb 1 ${initrd_loadaddr} uInitrd; then if fatload usb 1 ${kernel_loadaddr} zImage; then if fatload usb 1 ${dtb_mem_addr} dtb.img; then run boot_start; else store dtb read ${dtb_mem_addr}; run boot_start;fi;fi;fi; if fatload usb 2 ${initrd_loadaddr} uInitrd; then if fatload usb 2 ${kernel_loadaddr} zImage; then if fatload usb 2 ${dtb_mem_addr} dtb.img; then run boot_start; else store dtb read ${dtb_mem_addr}; run boot_start;fi;fi;fi; if fatload usb 3 ${initrd_loadaddr} uInitrd; then if fatload usb 3 ${kernel_loadaddr} zImage; then if fatload usb 3 ${dtb_mem_addr} dtb.img; then run boot_start; else store dtb read ${dtb_mem_addr}; run boot_start;fi;fi;fi; if fatload mmc 0 ${initrd_loadaddr} uInitrd; then if fatload mmc 0 ${kernel_loadaddr} zImage; then if fatload mmc 0 ${dtb_mem_addr} dtb.img; then run boot_start; else store dtb read ${dtb_mem_addr}; run boot_start;fi;fi;fi; Link to comment Share on other sites More sharing options...
balbes150 Posted June 8, 2018 Share Posted June 8, 2018 Write in detail all your steps, what and where you copied, what you did with the media, etc. Link to comment Share on other sites More sharing options...
napo7 Posted June 11, 2018 Author Share Posted June 11, 2018 I've made : dd if=/dev/data of=/dev/sda1 then resize2fs /dev/sda1 edited /etc/fstab to change "/dev/root" to "/dev/sda1" When I rebooted and typed "mount" to verify, root fs was still mounted from /dev/data... Is /etc/fstab really used to mount rootfs ? I suppose It's a kernel commandline option in facts. I suppose I have to change the s905_autoscript, but I don't know the syntax and how to modify it ? (it seems to contain binary data in header section ??) Link to comment Share on other sites More sharing options...
balbes150 Posted June 13, 2018 Share Posted June 13, 2018 On 6/11/2018 at 9:59 PM, napo7 said: I've made : dd if=/dev/data of=/dev/sda1 then resize2fs /dev/sda1 edited /etc/fstab to change "/dev/root" to "/dev/sda1" When I rebooted and typed "mount" to verify, root fs was still mounted from /dev/data... Is /etc/fstab really used to mount rootfs ? I suppose It's a kernel commandline option in facts. I suppose I have to change the s905_autoscript, but I don't know the syntax and how to modify it ? (it seems to contain binary data in header section ??) I don't understand why you are trying to install the system in eMMC from the beginning and then try to change the rootfs location ? Immediately write the system image to an external media and use it. Link to comment Share on other sites More sharing options...
napo7 Posted June 13, 2018 Author Share Posted June 13, 2018 Sorry :) I didn't knew I could install the system on an external media... thought I could only be done on a sd card... So, the instructions are just : write image on SSD, boot on SSD. done !? Link to comment Share on other sites More sharing options...
balbes150 Posted June 13, 2018 Share Posted June 13, 2018 yes (USB->SSD) But please note that the speed through USB 2.0 is very low. Link to comment Share on other sites More sharing options...
napo7 Posted June 14, 2018 Author Share Posted June 14, 2018 It worked. thanks ! In facts, SSD over USB 2.0 is anyway faster than internal MMC !! I run a MYSQL server (for home automation), and it is 60 times faster to make 1000 "insert into" on the database on SSD than internal memory ! Thanks for your help... Link to comment Share on other sites More sharing options...
balbes150 Posted June 15, 2018 Share Posted June 15, 2018 21 hours ago, napo7 said: In facts, SSD over USB 2.0 is anyway faster than internal MMC !! I run a MYSQL server (for home automation), and it is 60 times faster to make 1000 "insert into" on the database on SSD than internal memory ! This is weird. The result should be the exact opposite. If so, eMMC does not work correctly (there may be different reasons). Link to comment Share on other sites More sharing options...
napo7 Posted June 15, 2018 Author Share Posted June 15, 2018 I don't know the specifications of this eMMc, but i saw "cheap computers" with 32gb of MMC which was slower than a good Sandisk SSD. Link to comment Share on other sites More sharing options...
