Hi!
The Armbian_Orangepi2g-iot password is not "orangepi" the correct password "1234"
I got error when boot
[ TIME ] Timed out waiting for device dev-disk-by\x2duuid-8c5...4235258.device.
[DEPEND] Dependency failed for /boot.
[DEPEND] Dependency failed for Local File Systems.
[DEPEND] Dependency failed for File System Check on /dev/disk...8-df2014235258.
[ TIME ] Timed out waiting for device dev-ttyS0.device.
Welcome to emergency mode! AfterGive root password for maintenance
I commented out /etc/fstab
#uuiD=8c56592d-4e41-4bb0-9d48-df2014235258 /boot ext2 defaults 0 2
and the first error disappear.
But I can't resolve second problem (maybe kernel config problem missing "CONFIG_FHANDLE=y" ) http://forum.lemaker.org/thread-3312-1-1.html
I can't use serial debug this.
How can I fix this problem, or will be this fixed?
the correct first run password for Armbian was never 'orangepi'... :P
keep in mind, there's no support for this board (in fact it was removed from the buildsystem fully just 2 days ago). It was once considered to support the board, first attempts were made before it was dropped due to crappy u-boot & kernel sources. It stayed for some time as .csc board before it was dropped fully.
Unfortunately Xunlong provides on their webpage an 'Armbian' image for it so that people think this is a supported board. Thats why @zador.blood.stained moved this thread to 'P2P tech. support'. Maybe someone can/will help you. :) But there's no 'official support' for the board.
