Osiris Posted June 20, 2018 Posted June 20, 2018 Has anyone here tested the Rock64 successfully with an u-boot version which is not the one from ayufan? I did not have much luck with the rk3328 default config and mainline u-boot when I tried it a while back. The same is true when I tried to use the board config from ayufan with mainline u-boot. The version by ayufan is working in principle but also is rather dated as far as I know and therefore does not support some newer features. Anyone knows if the version from ayufan will be bumped or has a working config for a more recent u-boot version?
