foxinstone Posted July 19, 2018 Share Posted July 19, 2018 Hi, every one: I installed Armbian Xenial desktop legacy kernel 3.10.y on my OPI win plus , it's good. (At least, Bluetooth, WIFI and Ethernet are good). But after i execute "apt upgrade",The bluetooth is fault. So, I tried to freeze the kernel upgrades, and hold "armbian-firmware"package, then run "apt upgrade", All do not work. However, when i insert a BT-dongle(USB), this dongle is functional. So I think there is a bug in some package, please help me to solve. Link to comment Share on other sites More sharing options...
Igor Posted July 20, 2018 Share Posted July 20, 2018 The problem is most likely in the BSP package, where are all those startup scripts are: linux-root-xenial-orangepiwin Link to comment Share on other sites More sharing options...
foxinstone Posted July 21, 2018 Author Share Posted July 21, 2018 Hi Igor: Thanks for your reply. But, I have frozen the kernel upgrade, but there is still a problem. I remember that freezing the kernel upgrade should mean that the BSP upgrade is also frozen, right? Where is "linux-root-xenial-orangepiwin"? Link to comment Share on other sites More sharing options...
Igor Posted July 21, 2018 Share Posted July 21, 2018 2 hours ago, foxinstone said: Where is "linux-root-xenial-orangepiwin"? If you choose to freeze from armbian-config, this should also be frozen. Then it could be a problem with upstream changes - check which packages, that might be related, are changed. No other ideas. Link to comment Share on other sites More sharing options...
foxinstone Posted July 21, 2018 Author Share Posted July 21, 2018 Hi, Igor: Yes, I did freeze them from armbian-config (except armbian-firmware, which was blocked with 'dpkg --set-selections'). It is important to point out that after performing "apt upgrade", After Bluetooth failed, I used the method of freezing upgrade. However, the freeze upgrade does not seem to solve the Bluetooth failure problem. The problem I reported can be reproduced steadily. That is: As long as an upgrade, Bluetooth will definitely fail. (Whether it is freezing the kernel upgrade) In fact, I have repeatedly flashed the TF card (This means that the installation is fresh) test many times. I think this problem should be solved... Link to comment Share on other sites More sharing options...
