daw0lverine Posted July 23, 2018 Posted July 23, 2018 Hello First of all, amazing project overall, it's incredible to see what we can do already. I have Armbian running on a Sunvell T95Z Plus (3gb RAM, 32GB storage) and it's working fine overall, there just seem to be a few things that could be better and I would need to help to progress : - The video driver doesn't seem to be optimized, playing a video, kodi or youtube shows a lot of tearing. My dtb is t95z-le9-dtb.img My distribution is Armbian_5.44_S9xxx_Ubuntu_bionic_3.14.29_mate_20180721.img I got both of them from scouring the forum. How can I update the video driver to the latest or most adequate one ? - The network card seems to be limited to 100mbits, whereas I believe it is a 1gbits, any way to update ? - Finally, I also tried LibreElec which doesn't have any video problem and allows me to use the remote thanks to a remote.conf file, how would I set up and use the remote on Armbian ? Thanks in advance !
daw0lverine Posted July 23, 2018 Author Posted July 23, 2018 One more thing, ethernet works fine but not WiFi which doesn't seem to be recognized
guidol Posted July 23, 2018 Posted July 23, 2018 1 hour ago, daw0lverine said: One more thing, ethernet works fine but not WiFi which doesn't seem to be recognized You could try it like I did on my Sunvell T95K Pro:
daw0lverine Posted July 23, 2018 Author Posted July 23, 2018 Thanks unfortunately the file URL is 404'd, do you still have it by any chance ?
guidol Posted July 23, 2018 Posted July 23, 2018 34 minutes ago, daw0lverine said: Thanks unfortunately the file URL is 404'd, do you still have it by any chance ? Sorry - you dont have to download this file. I used the files which where already onto my disk of the box after installing armbian: /lib/firmware/brcm/fw_bcm40183b2.bin and /lib/firmware/brcm/nvram_ap6330.txt but you have to check if your T95Z also has a ap6330 , because some seem to have a LTM8830 or other WiFi Chips:http://freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s912/624055-t95z-plus-disassembled-wifi-issue-warning-wifi-chip-is-not-ap6330-but-ltm8830 http://freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s912/vontar/firmware-roms-aa/627174-rom-custom-sunvell-t95z-plus-amlogic-s912-with-9377-wifi-chip/page3
daw0lverine Posted July 23, 2018 Author Posted July 23, 2018 Thanks so much for the help, sorry but this is too advanced for me. Any way to check the chipset without de-assembling ? And if it is ap6330 how to fix the issue afterwards ? Thanks !
guidol Posted July 23, 2018 Posted July 23, 2018 6 hours ago, daw0lverine said: And if it is ap6330 how to fix the issue afterwards ? if your T95Z Plus got a ap6330 you can try to use eth0 after these 2 commands (until the next reboot) : modprobe cfg80211 modprobe dhd firmware_path=/lib/firmware/brcm/fw_bcm40183b2.bin nvram_path=/lib/firmware/brcm/nvram_ap6330.txt
