Hi, if I want install any package (try mc, kodi) get this error:
root@cubieboard2:~# sudo apt-get install mc
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  libssh2-1 mc-data
Suggested packages:
  arj catdvi | texlive-binaries dbview djvulibre-bin genisoimage gv links
  | w3m | lynx odt2txt python-boto python-tz xpdf | pdf-viewer zip
The following NEW packages will be installed:
  libssh2-1 mc mc-data
0 upgraded, 3 newly installed, 0 to remove and 34 not upgraded.
Need to get 0 B/1,676 kB of archives.
After this operation, 6,817 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
dpkg: error: triggers ci file contains unknown directive syntax
E: Sub-process /usr/bin/dpkg returned an error code (2)
Any suggestions?
use image: Armbian_5.38_Cubieboard2_Ubuntu_xenial_default_3.4.113_desktop.7z and Armbian_5.38_Micro_Ubuntu_xenial_default_3.4.113_desktop.7z
