19 minutes ago, martinayotte said:
It depends : are you using those ?
Simply edit again /boot/armbianEnv.txt and add "param_spidev_spi_bus=0" or "param_spidev_spi_bus=1" depending which bus you want to activate... and then reboot ...
thanks, will check with this and let you know the result
Thanks It worked
