i worked on the BPI M1 Board (the first one) for quite a while now improving or more or less rewriting the A20 CSI camera driver.
there are no more artifact-ghost-frames any more.
The framerate goes from 5fps(full) to 120fps(crobbed small)
i also modified the camera-device driver for the ov5640.
disadvantage: existing camera device drivers would not be compatible any more.
maybe someone wants to give it a try and check it out.
it can be found here:
https://github.com/xenpac/OV5640-Sunxi-A20
I would suggest you work on the legacy kernel 3.4.112 , that would be a boost. Any plans on that?
Hi ?Alex
Yes, kernel version is 3.4.112, i guess (not having it on desk)
actual source code was:
https://github.com/LeMaker/linux-sunxi
It seems the CSI driver did not change over the last years.
If u check it out, disable the DEBUG output in the source files (forgot that)
addendum:
the device driver files are all for ov5640, but different setups:
- ov5640.c = standard
the others have features like autofocus, crobbing, scaling.
so just to be be able to easy switch to explore features.
In ..docu/ there is a util "vt" to measure framerate with no output and also set resolutions.
Just as a thought....if to integrate that into mainline.....
is there any CSI support in mainline?  (if not, we put it right into the Cam driver. as no one else is using CSI-0 and 1).
plus supporting videobuf2.
I think the Clock module is there as well as the I2C.
ps. just wonder what other chips have compatible CSI port ???
Hi jiapei100,
yes i should have named it "sun4i_csi" so one can easier clone it under .../drivers/media/video/sun4i_sci...
and yes you shall have an allwinner/lemaker based kernel sourcecode on your Bananapi with its uImage being booted.
Last week i checked this one and it works: https://github.com/nisenbeck/linux-bananapi
unfortunate i found no armbian kernel on github, but this works with patches only i guess.
Under /lib/modules/..  you find the module tree for each kernel that ever resided on your system.
So..install:
goto cd .../drivers/media/video/ ,  rm -r sun4i_csi  to remove the whole driver.
git clone  https://github.com/xenpac/OV5640-Sunxi-A20.git
now u have this "ov5640-sunxi-a20"  directory under video. rename it: mv  ov5640-sunxi-a20   sun4i_csi
goback to your source root:
make modules
make modules_install
reboot
if you specified ov5640 as default camera in your fex file you are all set, else you have to modprobe the right one.
i used "guvcview" app for testing which worked fair, cheese did not.
another good test app is "qv4l2", apt-get install qv4l2  !  though video output is slow but controls work exact.
in the "docu" directory there are some scripts to easy change your camera device and also a "vt" commandline tool that also outputs video.
the other camera drivers in "device" are all ov5640 with some different setups, read first line in file.
i will update some changes shortly.
