Compile FFmpeg aml for S912 ( Mecool K3 Pro)
Hello all,
I buy an another box tv ( ... do not laugh please ... it's only my 3 .... )
A K3 pro with S912 aml soc ( 8 cores = 4c a53 at 1.5ghz plus 4c a53 core at 1 ghz, 3G Ram and 16 G Flash ) with a DVB T2 and DVB S2 tuner ( find promotion at 60 $ )
I play with android 7.1.1 and use ffmpeg , i make an transcode : ( French Channel M6 in DVB T2 in 1920x1080 )
ffmpeg  -i http://192.168.1.50:8001/+1:0:19:401:4:20FA:EEEE0000:0:0:0 -s 320x240 /tmp/test.mp4
and speed ( without hardware decoder / encoder , only software ) give :
Speed 1x !!! ( my other S905W with 4 cores in same test give Speed 0.65 )
So test last libreelec , crash at boot, some armbian lot of crash ( be carefull the dtb with K3 in the name could ne not the good because it's old version now use 201 ... more information after test )
So find a distrib with ethernet works
make an ffmpeg compil
test
ok what i need :
Armbian with kernel 3.14 ( for vpu + mali )
Works with ethx
Dvb drivers works
Tvheadend
gstreamer aml
NO kodi
ffmpeg (with HW it could works )
I am out of the home for 5 days, so i tri it after
Ok for the moment :
I put corelec CoreELEC-S912.arm-8.95.0.img and ONLY if i put gxm_q200_k3_pro.dtb in dtb.img , i can have dvb device. ( i try a lot of dtb file)
I install add-on : tvheadend, oscam , ffmpeg
I don't use kodi ( the device have no hdmi connection , just used with lan )
I can see my channel in the lan with vlc ( the linux drivers of dvb is not so good than the drivers in android, but it's works )
I can make an transcode with ffmpeg ( HD 1920*1080 to 320*240 ) with ffmpeg ( in software with bandwith at 300K ) , the cpu S912 is enough ( not the S905 )
But this type of distrib is closed i can't install the Web Gui E Transcoder.
So i must find how to find a armbian dtb who works with my device ( for the moment i can boot but no ethX lan and no dvb )
If you have some idea ...
  • Werner locked this topic
