gyrex Posted August 17, 2018 Posted August 17, 2018 (edited) I've got an Orange Pi Zero Plus running Armbian Bionic. I'm trying to add a virtual wifi interface so I can create a wifi hotspot so I can connect to it easily on remote networks. iw list shows that the adapter *should* be capable of adding an additional interface. This works on other Orange Pi boards I've got but not this one. Any ideas? root@opizero:~# iw list Wiphy phy0 max # scan SSIDs: 9 max scan IEs length: 2304 bytes max # sched scan SSIDs: 0 max # match sets: 0 max # scan plans: 1 max scan plan interval: -1 max scan plan iterations: 0 Retry short limit: 7 Retry long limit: 4 Coverage class: 0 (up to 0m) Supported Ciphers: * WEP40 (00-0f-ac:1) * WEP104 (00-0f-ac:5) * TKIP (00-0f-ac:2) * CCMP-128 (00-0f-ac:4) Available Antennas: TX 0 RX 0 Supported interface modes: * IBSS * managed * AP * monitor * P2P-client * P2P-GO iw dev wlan0 interface add vwlan0 type station command failed: No such device (-19) iw phy phy0 interface add vwlan0 type station command failed: No such device (-19) Edited August 17, 2018 by gyrex
gyrex Posted August 17, 2018 Author Posted August 17, 2018 I think I've figured out the reason and it's because the hardware wifi device doesn't support additional virtual/software interfaces: software interface modes (can always be added): * monitor interface combinations are not supported
