psygnosis Posted August 23, 2018 Share Posted August 23, 2018 Hi guys I have no time to test performace between armbian, retrorangepi and h3droid, does some one test the same app on the three system, does it run the same? I have now an armbian with kodi and retroarch that i'm using for test, but I'm planning to move to a more TV friendly OS as retrorangepi or h3droid. the main problem is Netflix, I should go for h3droid only for netflix app, but I want to be sure that retrorangepi and kodi works the same as on armbian/retrorangepi. and that the temps are the same. Can you help me if you had some experience? PS I know that I could run netflix on kodi but I didn't tested it. thank you in advance Link to comment Share on other sites More sharing options...
