yanosz Posted August 25, 2018 Share Posted August 25, 2018 Hello folks, I'm having trouble booting https://dl.armbian.com/lime-a64/Debian_stretch_next_nightly.7z as of today on my A64-OLinuXino-1G4GW. Armbian is installed on an external µSD card; the device has internal flash. Do you see, how I can fix this issue? Thanks, yanosz Log is: U-Boot 2018.05-armbian (Aug 21 2018 - 08:46:56 +0200) Allwinner Technology CPU: Allwinner A64 (SUN50I) Model: Olimex A64-Olinuxino DRAM: 1 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** Failed (-5) In: serial Out: serial Err: serial Net: No ethernet found. 230454 bytes read in 21 ms (10.5 MiB/s) starting USB... No controllers found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3090 bytes read in 15 ms (201.2 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 104 bytes read in 12 ms (7.8 KiB/s) 31652 bytes read in 23 ms (1.3 MiB/s) 3795 bytes read in 23 ms (161.1 KiB/s) Applying kernel provided DT fixup script (sun50i-a64-fixup.scr) ## Executing script at 44000000 4922442 bytes read in 260 ms (18.1 MiB/s) ** fs_devread read error ** ** File not found /boot/Image ** Bad Linux ARM64 Image magic! SCRIPT FAILED: continuing... switch to partitions #0, OK mmc1(part 0) is current device ** No partition table - mmc 1 ** starting USB... No controllers found USB is stopped. Please issue 'usb start' first. starting USB... No controllers found No ethernet found. missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 No ethernet found. Link to comment Share on other sites More sharing options...
Igor Posted August 26, 2018 Share Posted August 26, 2018 8 hours ago, yanosz said: Do you see, how I can fix this issue? I can only confirm that A64 boards are mostly broken ATM. By joining and slowly discovering where is the problem and fixing it? https://docs.armbian.com/Process_Contribute/https://groups.google.com/forum/#!forum/linux-sunxi You can try to build an image on your own by using DEV targets, kernel 4.18.y. IIRC it boots, but many things do not work yet. Check kernel development progress here: https://linux-sunxi.org/Linux_mainlining_effort#Status_Matrix Link to comment Share on other sites More sharing options...
