I am trying to build an Image for  the Rockpro but i am allways getting an Error when it comes to compile U-boot (did not make any Changes so far):
Displaying message: Preparing host info
Displaying message: Build host OS release bionic info
Displaying message: Syncing clock host info
## BUILD SCRIPT ENVIRONMENT
Repository: https://github.com/armbian/build
Version: 46340a24
Host OS: bionic
Host arch: amd64
Host system: Linux ek-desktop 4.15.0-33-generic #36-Ubuntu SMP Wed Aug 15 16:00:05 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
Virtualization type: none
## Build script directories
Build directory is located on:
TARGET SOURCE    FSTYPE  AVAIL
/home  /dev/sda1 ext4   319,9G
Build directory permissions:
# file: /home/ek/build
# owner: ek
# group: ek
user::rwx
group::rwx
other::r-x
Temp directory permissions:
# file: /home/ek/build/.tmp
# owner: root
# group: root
user::rwx
group::rwx
other::r-x
## BUILD CONFIGURATION
Build target:
Board: rockpro64
Branch: default
Desktop: yes
Kernel configuration:
Repository: https://github.com/ayufan-rock64/linux-kernel
Branch: tag:4.4.138-1094-rockchip-ayufan
Config file: linux-rockchip64-default
U-boot configuration:
Repository: https://github.com/ayufan-rock64/linux-u-boot
Branch: branch:rockchip-master
Config file: rockpro64-rk3399_defconfig
Partitioning configuration:
Root partition type: ext4
Boot partition type: (none)
User provided boot partition size: 0
Offset: 16
CPU configuration:
600000 - 1900000 with ondemand
Displaying message: Downloading sources  info
Displaying message: Checking git sources u-boot-rockchip64 rockchip-master info
Displaying message: Checking out
Displaying message: Checking git sources linux-rockchip64 4.4.138-1094-rockchip-ayufan info
Displaying message: Up to date
Displaying message: Checking git sources arm-trusted-firmware-rockchip64 rockchip info
Displaying message: Checking git sources sunxi-tools master info
Displaying message: Checking git sources rkbin-tools master info
Displaying message: Checking git sources marvell-tools A3700_utils-armada-17.10 info
Displaying message: Checking git sources odroidc2-blobs master info
Displaying message: Checking git sources testing-reports master info
Displaying message: Cleaning output/debs for rockpro64 default info
Displaying message: Cleaning arm-trusted-firmware-rockchip64/rockchip info
Displaying message: Compiling ATF  info
Displaying message: Compiler version aarch64-linux-gnu-gcc 6.4.1 info
Displaying message: Started patching process for atf rockchip64-rockpro64-default info
Displaying message: Looking for user patches in userpatches/atf/atf-rockchip64 info
Displaying message: * [\e[32ml\e[0m][\e[35mb\e[0m] add-trust-ini.patch  info
Displaying message: Cleaning u-boot-rockchip64/rockchip-master info
Displaying message: Compiling u-boot 2017.09 info
Displaying message: Compiler version aarch64-linux-gnu-gcc 7.2.1 info
Displaying message: Checking out sources
Displaying message: Started patching process for u-boot rockchip64-rockpro64-default info
Displaying message: Looking for user patches in userpatches/u-boot/u-boot-rockchip64-default info
Displaying message: * [\e[32ml\e[0m][\e[32mc\e[0m] add_fdtfile_dt_overlays.patch  info
Displaying message: ERROR in function compile_uboot compilation.sh:185 err
Displaying message: U-boot file not found idbloader.bin err
Displaying message: Process terminated  info
Trying to build an Image for the PineH64 does not work either:
Displaying message: ERROR in function source main.sh:188 err
Displaying message: No kernel branch selected  err
