hi
I am grateful for the help that will be given to me.
Please help me with the launch of the cam500a by Nano Air.
I tried to use http://wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO_Air#Connect_to_DVP_Camera_CAM500B guides and go along with it.
but I did not succeed .
I am very beginner and need help.
This is all that I get by following the guide http://wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO_Air#Connect_to_DVP_Camera_CAM500B.
root@NanoPi-NEO-Air:~# cd /root/mjpg-streamer
root@NanoPi-NEO-Air:~/mjpg-streamer# make
make: svnversion: Command not found
make: Warning: File 'Makefile' has modification time 427105 s in the future
gcc -D'SVN_REV=""' -O2 -DLINUX -D_GNU_SOURCE -Wall    -c -o mjpg_streamer.o mjpg_streamer.c
gcc -D'SVN_REV=""' -O2 -DLINUX -D_GNU_SOURCE -Wall    -c -o utils.o utils.c
gcc -D'SVN_REV=""' -O2 -DLINUX -D_GNU_SOURCE -Wall  mjpg_streamer.o utils.o -lpthread -ldl -o mjpg_streamer
chmod 755 mjpg_streamer
make -C plugins/input_uvc all
make[1]: Entering directory '/root/mjpg-streamer/plugins/input_uvc'
make[1]: Warning: File 'Makefile' has modification time 427103 s in the future
gcc -c -O1 -DLINUX -D_GNU_SOURCE -Wall -shared -fPIC -o v4l2uvc.lo v4l2uvc.c
v4l2uvc.c: In function init_videoIn’:
v4l2uvc.c:88:23: warning: variable currentHeight set but not used [-Wunused-but-set-variable]
     int currentWidth, currentHeight = 0;
v4l2uvc.c:88:9: warning: variable currentWidth set but not used [-Wunused-but-set-variable]
gcc -c -O1 -DLINUX -D_GNU_SOURCE -Wall -shared -fPIC -o jpeg_utils.lo jpeg_utils.c
jpeg_utils.c: In function compress_yuv_to_jpeg’:
jpeg_utils.c:208:27: warning: v may be used uninitialized in this function [-Wmaybe-uninitialized]
             r = (y + (359 * v)) >> 8;
jpeg_utils.c:209:26: warning: u may be used uninitialized in this function [-Wmaybe-uninitialized]
             g = (y - (88 * u) - (183 * v)) >> 8;
jpeg_utils.c:209:20: warning: y may be used uninitialized in this function [-Wmaybe-uninitialized]
gcc -c -O1 -DLINUX -D_GNU_SOURCE -Wall -shared -fPIC -o dynctrl.lo dynctrl.c
gcc -O1 -DLINUX -D_GNU_SOURCE -Wall -shared -fPIC -o input_uvc.so input_uvc.c v4l2uvc.lo jpeg_utils.lo dynctrl.lo -ljpeg
make[1]: warning:  Clock skew detected.  Your build may be incomplete.
make[1]: Leaving directory '/root/mjpg-streamer/plugins/input_uvc'
cp plugins/input_uvc/input_uvc.so .
make -C plugins/output_file all
make[1]: Entering directory '/root/mjpg-streamer/plugins/output_file'
make[1]: Warning: File 'Makefile' has modification time 427099 s in the future
gcc -O2 -DLINUX -D_GNU_SOURCE -Wall -shared -fPIC -o output_file.so output_file.c
make[1]: Leaving directory '/root/mjpg-streamer/plugins/output_file'
cp plugins/output_file/output_file.so .
make -C plugins/output_udp all
make[1]: Entering directory '/root/mjpg-streamer/plugins/output_udp'
make[1]: Warning: File 'Makefile' has modification time 427098 s in the future
gcc -O2 -DLINUX -D_GNU_SOURCE -Wall -shared -fPIC -o output_udp.so output_udp.c
make[1]: Leaving directory '/root/mjpg-streamer/plugins/output_udp'
cp plugins/output_udp/output_udp.so .
make -C plugins/output_http all
make[1]: Entering directory '/root/mjpg-streamer/plugins/output_http'
make[1]: Warning: File 'Makefile' has modification time 427097 s in the future
gcc -c -O1 -DLINUX -D_GNU_SOURCE -Wall -shared -fPIC -o httpd.lo httpd.c
gcc -O1 -DLINUX -D_GNU_SOURCE -Wall -shared -fPIC -o output_http.so output_http.c httpd.lo
make[1]: Leaving directory '/root/mjpg-streamer/plugins/output_http'
cp plugins/output_http/output_http.so .
make -C plugins/input_file all
make[1]: Entering directory '/root/mjpg-streamer/plugins/input_file'
make[1]: Warning: File 'Makefile' has modification time 427094 s in the future
make[1]: Nothing to be done for 'all'.
make[1]: Leaving directory '/root/mjpg-streamer/plugins/input_file'
cp plugins/input_file/input_file.so .
make: warning:  Clock skew detected.  Your build may be incomplete.
root@NanoPi-NEO-Air:~/mjpg-streamer# ./start.sh
MJPG Streamer Version: svn rev:
 i: Using V4L2 device.: /dev/video0
 i: Desired Resolution: 1280 x 720
 i: Frames Per Second.: 30
 i: Format............: YUV
 i: JPEG Quality......: 90
ERROR opening V4L interface: No such file or directory
 Init v4L2 failed !! exit fatal
 i: init_VideoIn failed
What should i do
7 hours ago, amin said:
cam500a
CAM500A needs to add some resistor to work with neo air.
There was an instruction on FriendlyArm  to add this resistor to become CAM500B, but i can't find it right now.
  • Tido changed the title to Launch cam500a camera by nanopi neo air [solved]
1 hour ago, @lex said:
Here you have it:
Is cam500a the only problem? Is the problem resolved by changing it to cam500b?
There is no way to answer the cam500a?
Thank you very much for your directions
I also feel there is another problem, I do not understand it
When I execute command ''make'' , the operation is not successful
Can you guide me where the problem is?
