Rolf Bakker Posted September 10, 2018 Posted September 10, 2018 I'm trying to boot my Nano Pi Neo 2 from the network but I am a bit stuck. I have found out how to add network support to u-boot for the Nano Pi Neo 2, I can set the serverip and perform the dchp command, the Nanopi neo get's an IP address from the DHCP server but then booting halts with the message that it can't find the file. I'm pretty sure the location & access rights are valid. (Is there an easy way to check?) U-Boot 2018.09-rc3-00026-g4cdeda511f-dirty (Sep 10 2018 - 16:37:11 +0200) Allwinner Technology CPU: Allwinner H5 (SUN50I) Model: FriendlyARM NanoPi NEO 2 DRAM: 512 MiB MMC: SUNXI SD/MMC: 0 Loading Environment from FAT... Unable to use mmc 0:1... In: serial Out: serial Err: serial Net: phy interface7 eth0: ethernet@1c30000 starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 => setenv serverip 192.168.188.1 => dhcp BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 DHCP client bound to address 192.168.188.50 (1003 ms) Using ethernet@1c30000 device TFTP from server 192.168.188.1; our IP address is 192.168.188.50 Filename '/nfsshares/tftp/npi/boot/boot.scr'. Load address: 0x42000000 Loading: T TFTP error: 'File not found' (1) Not retrying... => Is there anyone who has experience booting Armbian from the network that can point me in the right direction / perhaps share a working solution?
martinayotte Posted September 10, 2018 Posted September 10, 2018 Did you tried a tftp client from another machine ?
Rolf Bakker Posted September 11, 2018 Author Posted September 11, 2018 ok, I tested from a different machine and it appears that the DHCP server shouldn't provide the fullpath of the filename, but just the path within the tftp folder. After I changed the setting in my DHCP server the file could be loaded. U-Boot 2018.09-rc3-00026-g4cdeda511f-dirty (Sep 10 2018 - 16:37:11 +0200) Allwinner Technology CPU: Allwinner H5 (SUN50I) Model: FriendlyARM NanoPi NEO 2 DRAM: 512 MiB MMC: SUNXI SD/MMC: 0 Loading Environment from FAT... Unable to use mmc 0:1... In: serial Out: serial Err: serial Net: phy interface7 eth0: ethernet@1c30000 starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 => setenv serverip 192.168.188.1 => dhcp BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 DHCP client bound to address 192.168.188.50 (1003 ms) Using ethernet@1c30000 device TFTP from server 192.168.188.1; our IP address is 192.168.188.50 Filename '/boot/boot.scr'. Load address: 0x42000000 Loading: # 1.5 MiB/s done Bytes transferred = 3090 (c12 hex) => One step closer to booting the NanoPi Neo 2 from the network. I think my brain got a bit numb yesterday, by the end of the day Does any one have a u-boot script in combination with Armbian to make this work with NFS?
