Fahrinurlaub Posted September 11, 2018 Posted September 11, 2018 Dear all, My small server based on the Cubietruck board and Armbian OS (ARMBIAN 5.38 stable Debian GNU/Linux 9 (stretch) 4.14.18-sunxi) runs flawlessly since over 2.5 years now. And I am very happy with this setup. Lately, I installed a battery (5.3 Ah 3.7 V) in order to have the server a bit portable. The battery. driven system runs approx 9 - 10 h. Since I want to prevent that the battery drains out completely I configured the following cronjob: */15 * * * * /home/ncuser/nc_batt_cap_shutdown.sh > /dev/null 2>&1 The content of the script looks as follows: #!/bin/bash ### Script idea taken from: # http://www.schulz-alex.de/cms/index.php/homeautomation-homecontrol/hardwareplattformen/cubietruck/59-akku-fuer-cubietruck LOG_NEW="" LOG_FILE=/home/ncuser/battery_cap_shutdown.log BATPARAM=`cat /sys/class/power_supply/axp20x-battery/uevent` source /sys/class/power_supply/axp20x-battery/uevent AC_POWER_SUPPLY_PRESENT=`cat /sys/class/power_supply/axp20x-ac/present` ### Execute script only if AC adapter is not plugged in if [ ${AC_POWER_SUPPLY_PRESENT} -eq 0 ]; then ### No AC adapter plugged in if [[ ${POWER_SUPPLY_PRESENT} -eq 0 || ${POWER_SUPPLY_ONLINE} -eq 0 ]]; then ### If no battery installed or battery is not discharged exit fi if [[ ${POWER_SUPPLY_ONLINE} -eq 1 && ${POWER_SUPPLY_CAPACITY} -le 10 ]]; then if [ ! -f "$LOG_FILE" ]; then ### Create log file if it is not yet there touch $LOG_FILE fi LOG_NEW+="$(date +'%d.%m.%Y %H:%M:%S')\tBattery capacity too low: ${POWER_SUPPLY_CAPACITY}\n" LOG_NEW+="$(date +'%d.%m.%Y %H:%M:%S')\tOutput server battery state:\n${BATPARAM}\n" LOG_NEW+="$(date +'%d.%m.%Y %H:%M:%S')\tShut down system\n" SUBJECT="[Server] - Shutdown - Battery capacity too low: ${POWER_SUPPLY_CAPACITY}" TO="email@domain.tld" LOG_NEW+="$(date +'%d.%m.%Y %H:%M:%S')\tSend email with battery state info to: ${TO}\n" printf "$LOG_NEW" >> "$LOG_FILE" echo -e "$LOG_NEW" | sudo -u ncuser mutt -s "$SUBJECT" "$TO" -a $LOG_FILE ### Shutdown command taken from: # http://chris.cnie.de/raspberrypi/cubietruck.html sudo shutdown -P -h +0 # sudo poweroff -h exit fi else ### AC adapter plugged in => exit, no battery support required exit fi It runs fine except that it does not shut down. Below the set value of 10 % battery capacity it keeps on sending an email every 15 minutes until the battery is sucked empty. However, logged in using SSH and initiating one of the following commands will execute as expected: sudo shutdown -P -h +0 sudo poweroff -h I searched the forum and other sources on the internet and found some hints to kernels that behaved similarly in the past but I am still not able to find a suitable solution. What am I doing wrong? How did others implemented this use scenario? I would be greatful if somebody points me into the right direction. Thanks a lot in advance. Cheers, George
chwe Posted September 11, 2018 Posted September 11, 2018 does your cronjob have root permission? e.g. sudo crontab -e vs. crontab -e... 11 minutes ago, Fahrinurlaub said: It runs fine except that it does not shut down. Below the set value of 10 % battery capacity it keeps on sending an email every 15 minutes until the battery is sucked empty. means that you get data from: 11 minutes ago, Fahrinurlaub said: cat /sys/class/power_supply/axp20x-ac/present don't have axp20x based boards here to test..
botfap Posted September 11, 2018 Posted September 11, 2018 Have you created a sudoers.d entry for the user calling the sudo command? without a nopass entry for sudo then the sudo initiated commands will never actually run, they will be denied permission to excecute or the script will be sat waiting for a password without that you will need to run the task from root’s crontab not the user crontab like Chew says
Fahrinurlaub Posted September 12, 2018 Author Posted September 12, 2018 Great! Thanks so much for the prompt reply! This is exactly what I missed. Now everything works as expected.
gas_85 Posted October 16, 2018 Posted October 16, 2018 Also try to solve this problem. I create a script that will try to send Warning Email and and shutdown the system as soon as it goes below 10%. I put it in cron hourly and script should automatically check and do loop if battery discharging and below e.g. 80%. E-Mail is needed because last time I did not know that my power supply died and I did not know why sever stopped. This version is also producing logs that could be checked after cubietruck fails. That helps for trouble shooting, e.g. to find out that power supply could not produce enough current to charge battery. Log output example: Tue Oct 16 10:01:03 CEST 2018 - Ok. Battery Full - 100% left. AC is online with current 0.222 A. Battery health is Good.
gas_85 Posted August 20, 2019 Posted August 20, 2019 (edited) On 9/12/2018 at 12:49 AM, chwe said: cat /sys/class/power_supply/axp20x-ac/present And after update to latest Armbian I noticed that it is not there. Update was done from Ubuntu 16.04... And before I can get AC Power supply status via: cat /sys/class/power_supply/ac/present Now I could not find anything AC Power supply related... Where is all this gone? ls -la /sys/class/power_supply total 0 drwxr-xr-x 2 root root 0 Aug 20 10:26 . drwxr-xr-x 61 root root 0 Aug 20 10:26 .. lrwxrwxrwx 1 root root 0 Aug 20 10:26 axp20x-battery -> ../../devices/platform/soc@1c00000/1c2ac00.i2c/i2c-1/1-0034/axp20x-battery-power-supply/power_supply/axp20x-battery lrwxrwxrwx 1 root root 0 Aug 20 10:26 axp20x-usb -> ../../devices/platform/soc@1c00000/1c2ac00.i2c/i2c-1/1-0034/axp20x-usb-power-supply/power_supply/axp20x-usb UPDATE: I found it, thanks to this tread: ls -la /sys/power/axp_pmu/ac total 0 drwxr-xr-x 2 root root 0 Aug 20 10:33 . drwxr-xr-x 17 root root 0 Aug 20 10:33 .. -r--r--r-- 1 root root 4096 Aug 20 10:43 amperage -r--r--r-- 1 root root 4096 Aug 20 10:43 connected -r--r--r-- 1 root root 4096 Aug 20 10:43 used -r--r--r-- 1 root root 4096 Aug 20 10:43 voltage Edited August 20, 2019 by gas_85 RESOLVED
