/etc/default/nodm and lightDM seem to be misbehaving...
Hey All,
First, a big thank you to Igor and all who work hard to get armbian out to the masses :)
Second, setting
NODM_ENABLED=false
NODM_USER=some_user
in /etc/default/nodm as per the instructions here:
http://www.armbian.com/documentation/   - section 'How to login?'
doesn't seem to work for me on my cubox i4pro.
I turns out that /etc/default/nodm gets overwritten with the default root values on each boot. This causes lightDM to misbehave and bugger up the Xserver. I see Xcursor drawing artefacts and the LightDM UI widgets poke through into the root autologin desktop.
Even without lightDM installed and /etc/default/nodm set as follows:
NODM_ENABLED=true
NODM_USER=some_user
I can't autoboot into some_user's account. Yes, I've created /home/some_user :)
What obvious thing am I missing?
J
I would say you have to uninstall one display manager. nodm is in conflict with lightdm and vice versa. AFAIK.
Thanks!  :P
Ah, yes of course. Like I said, it had to be something 'obvious' :)
Removed the nodm package and things are working a treat now.
Thanks!
