febotory Posted September 21, 2018 Posted September 21, 2018 I customized my Armbian install with 2 operating systems on two partitions. In armbianEnv.txt I use rootdev to specify the default partition. I would like to set it so that if booting from the default rootdev fails (triggering panic or root-wait, etc.), it will instead try to boot with rootdev/root set to the other partition. Is that possible?
Igor Posted September 21, 2018 Posted September 21, 2018 44 minutes ago, febotory said: Is that possible? If you develop this feature.
