bananapiM2plus with dev branch -> Unable to handle kernel paging request at virtual address
BOARD: bananapim2plus
BRANCH: dev
RELEASE: stretch
did only boot one time through to the login, mostly get stuck at booting.
I assume it must be something with memory config or dts setup
tried already 3 sdcards, 2boards so looks like not a hardware issue
old armbian (5.21 works fine)
Did not see a "memory section" in the dts file? Is it mandatoy?
where is the memory size defined or how does linux know it?
Here the boot log ( adjust boot params with earlyprintk), maybe someone has an idea?
U-Boot SPL 2018.05-armbian (Sep 20 2018 - 05:54:54 -0400)
DRAM: 1024 MiB
Trying to boot from MMC1
U-Boot 2018.05-armbian (Sep 20 2018 - 05:54:54 -0400) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Banana Pi BPI-M2-Plus
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
Loading Environment from EXT4... ** File not found /boot/boot.env **
** Unable to read "/boot/boot.env" from mmc0:1 **
Failed (-5)
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
230454 bytes read in 20 ms (11 MiB/s)
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3788 bytes read in 12 ms (307.6 KiB/s)
U-boot loaded from SD
Boot script loaded from mmc
187 bytes read in 10 ms (17.6 KiB/s)
4851864 bytes read in 248 ms (18.7 MiB/s)
6805400 bytes read in 341 ms (19 MiB/s)
Found mainline kernel configuration ~_~
BOOTARGS: root=UUID=471bb094-2b84-4e18-afe9-cfc7bbd74f95 rootwait rootfstype=ext4  console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=a26f82f5-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   earlyprintk=ttyS0,115200,keep initcall_debug sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
27898 bytes read in 45 ms (604.5 KiB/s)
4155 bytes read in 85 ms (46.9 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 44000000
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Data Size:    4851800 Bytes = 4.6 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
   Loading Ramdisk to 49b5f000, end 49fff858 ... OK
   reserving fdt memory region: addr=43000000 size=6d000
   Loading Device Tree to 49aef000, end 49b5efff ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Loading, please wait...
starting version 232
done.
Begin: Will now check root file system ... fsck from util-linux 2.29.2
[/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1
/dev/mmcblk0p1: recovering journal
/dev/mmcblk0p1: clean, 58986/1877040 files, 371075/7735992 blocks
done.
done.
Welcome to \0x1b[1mDebian GNU/Linux 9 (stretch)\0x1b[0m!
[\0x1b[0;32m  OK  \0x1b[0m] Listening on Journal Socket (/dev/log).
[\0x1b[0;32m  OK  \0x1b[0m] Set up automount Arbitrary Executab\0xe2\0x80\0xa6rmats File System Automount Point.
[\0x1b[0;32m  OK  \0x1b[0m] Reached target Swap.
[\0x1b[0;32m  OK  \0x1b[0m] Listening on udev Kernel Socket.
[\0x1b[0;32m  OK  \0x1b[0m] Started Forward Password Requests to Wall Directory Watch.
[\0x1b[0;32m  OK  \0x1b[0m] Listening on /dev/initctl Compatibility Named Pipe.
[\0x1b[0;32m  OK  \0x1b[0m] Listening on udev Control Socket.
[\0x1b[0;32m  OK  \0x1b[0m] Listening on Journal Audit Socket.
[\0x1b[0;32m  OK  \0x1b[0m] Created slice System Slice.
[\0x1b[0;32m  OK  \0x1b[0m] Listening on Syslog Socket.
[\0x1b[0;32m  OK  \0x1b[0m] Started Dispatch Password Requests to Console Directory Watch.
[\0x1b[0;32m  OK  \0x1b[0m] Reached target Paths.
[\0x1b[0;32m  OK  \0x1b[0m] Listening on Journal Socket.
         Starting Create list of required st\0xe2\0x80\0xa6ce nodes for the current kernel...
         Starting Journal Service...
         Starting Set the console keyboard layout...
         Starting Load Kernel Modules...
[\0x1b[0;32m  OK  \0x1b[0m] Listening on fsck to fsckd communication Socket.
         Starting Nameserver information manager...
         Starting Restore / save the current clock...
[\0x1b[0;32m  OK  \0x1b[0m] Reached target Remote File Systems.
         Mounting Debug File System...
[\0x1b[0;32m  OK  \0x1b[0m] Created slice system-serial\x2dgetty.slice.
         Starting Remount Root and Kernel File Systems...
[\0x1b[0;32m  OK  \0x1b[0m] Created slice User and Session Slice.
[\0x1b[0;32m  OK  \0x1b[0m] Reached target Slices.
[\0x1b[0;32m  OK  \0x1b[0m] Reached target Encrypted Volumes.
         Mounting POSIX Message Queue File System...
[\0x1b[0;32m  OK  \0x1b[0m] Mounted Debug File System.
[\0x1b[0;32m  OK  \0x1b[0m] Mounted POSIX Message Queue File System.
[\0x1b[0;32m  OK  \0x1b[0m] Started Journal Service.
[\0x1b[0;32m  OK  \0x1b[0m] Started Create list of required sta\0xe2\0x80\0xa6vice nodes for the current kernel.
[\0x1b[0;32m  OK  \0x1b[0m] Started Set the console keyboard layout.
[\0x1b[0;32m  OK  \0x1b[0m] Started Load Kernel Modules.
[\0x1b[0;32m  OK  \0x1b[0m] Started Restore / save the current clock.
[\0x1b[0;32m  OK  \0x1b[0m] Started Remount Root and Kernel File Systems.
[\0x1b[0;32m  OK  \0x1b[0m] Started Nameserver information manager.
         Starting Load/Save Random Seed...
         Starting udev Coldplug all Devices...
         Starting Apply Kernel Variables...
         Mounting Configuration File System...
         Starting Create Static Device Nodes in /dev...
         Starting Flush Journal to Persistent Storage...
[\0x1b[0;32m  OK  \0x1b[0m] Mounted Configuration File System.
[\0x1b[0;32m  OK  \0x1b[0m] Started Load/Save Random Seed.
[\0x1b[0;32m  OK  \0x1b[0m] Started Apply Kernel Variables.
[\0x1b[0;32m  OK  \0x1b[0m] Started Create Static Device Nodes in /dev.
         Starting udev Kernel Device Manager...
[\0x1b[0;32m  OK  \0x1b[0m] Reached target Local File Systems (Pre).
         Mounting /tmp...
[\0x1b[0;32m  OK  \0x1b[0m] Mounted /tmp.
[\0x1b[0;32m  OK  \0x1b[0m] Started udev Kernel Device Manager.
[\0x1b[0;32m  OK  \0x1b[0m] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[\0x1b[0;32m  OK  \0x1b[0m] Reached target Local File Systems.
         Starting Set console font and keymap...
         Starting Armbian ZRAM config...
         Starting Raise network interfaces...
[\0x1b[0;32m  OK  \0x1b[0m] Started Flush Journal to Persistent Storage.
[\0x1b[0;32m  OK  \0x1b[0m] Started Set console font and keymap.
[\0x1b[0;32m  OK  \0x1b[0m] Started udev Coldplug all Devices.
         Starting Load/Save RF Kill Switch Status...
         Starting Create Volatile Files and Directories...
[\0x1b[0;32m  OK  \0x1b[0m] Started Load/Save RF Kill Switch Status.
[\0x1b[0;32m  OK  \0x1b[0m] Started Create Volatile Files and Directories.
[\0x1b[0;32m  OK  \0x1b[0m] Found device /dev/ttyS0.
         Starting Update UTMP about System Boot/Shutdown...
[\0x1b[0;32m  OK  \0x1b[0m] Reached target System Time Synchronized.
[\0x1b[0;32m  OK  \0x1b[0m] Started Entropy daemon using the HAVEGE algorithm.
[\0x1b[0;32m  OK  \0x1b[0m] Started Update UTMP about System Boot/Shutdown.
[\0x1b[0;32m  OK  \0x1b[0m] Started Armbian ZRAM config.
[\0x1b[0;32m  OK  \0x1b[0m] Started Raise network interfaces.
         Starting Armbian memory supported logging...
[\0x1b[0;32m  OK  \0x1b[0m] Started Armbian memory supported logging.
[\0x1b[0;32m  OK  \0x1b[0m] Reached target System Initialization.
         Starting Armbian hardware optimization...
         Starting Armbian hardware monitoring...
[\0x1b[0;32m  OK  \0x1b[0m] Started Daily apt download activities.
[\0x1b[0;32m  OK  \0x1b[0m] Started Daily apt upgrade and clean activities.
[\0x1b[0;32m  OK  \0x1b[0m] Listening on D-Bus System Message Bus Socket.
[\0x1b[0;32m  OK  \0x1b[0m] Reached target Sockets.
[\0x1b[0;32m  OK  \0x1b[0m] Started Daily Cleanup of Temporary Directories.
[\0x1b[0;32m  OK  \0x1b[0m] Reached target Timers.
[\0x1b[0;32m  OK  \0x1b[0m] Started Armbian hardware optimization.
[\0x1b[0;32m  OK  \0x1b[0m] Started Armbian hardware monitoring.
[\0x1b[0;32m  OK  \0x1b[0m] Reached target Basic System.
         Starting Login Service...
[\0x1b[0;32m  OK  \0x1b[0m] Started Armbian first run tasks.
         Starting System Logging Service...
         Starting LSB: Start/stop sysstat's sadc...
[\0x1b[0;32m  OK  \0x1b[0m] Started Regular background program processing daemon.
[\0x1b[0;32m  OK  \0x1b[0m] Started D-Bus System Message Bus.
         Starting Network Manager...
         Starting LSB: Load kernel modules needed to enable cpufreq scaling...
[\0x1b[0;32m  OK  \0x1b[0m] Started System Logging Service.
[\0x1b[0;32m  OK  \0x1b[0m] Started LSB: Start/stop sysstat's sadc.
[\0x1b[0;32m  OK  \0x1b[0m] Started Login Service.
[\0x1b[0;32m  OK  \0x1b[0m] Started LSB: Load kernel modules needed to enable cpufreq scaling.
         Starting LSB: set CPUFreq kernel parameters...
[\0x1b[0;32m  OK  \0x1b[0m] Started LSB: set CPUFreq kernel parameters.
         Starting LSB: Set sysfs variables from /etc/sysfs.conf...
[\0x1b[0;32m  OK  \0x1b[0m] Started LSB: Set sysfs variables from /etc/sysfs.conf.
[\0x1b[0;32m  OK  \0x1b[0m] Started Network Manager.
         Starting Network Manager Script Dispatcher Service...
[\0x1b[0;32m  OK  \0x1b[0m] Reached target Network.
[\0x1b[0;32m  OK  \0x1b[0m] Started Unattended Upgrades Shutdown.
         Starting OpenBSD Secure Shell server...
         Starting Permit User Sessions...
         Starting Network Manager Wait Online...
[\0x1b[0;32m  OK  \0x1b[0m] Started Permit User Sessions.
[\0x1b[0;32m  OK  \0x1b[0m] Started Network Manager Script Dispatcher Service.
         Starting Hostname Service...
[\0x1b[0;32m  OK  \0x1b[0m] Started OpenBSD Secure Shell server.
[\0x1b[0;32m  OK  \0x1b[0m] Started Hostname Service.
[   17.436509] Unable to handle kernel paging request at virtual address 9837f050
[   17.436513] Unable to handle kernel paging request at virtual address 9837f050
[   17.436527] pgd = 79e56ad9
[   17.443735] pgd = 79e56ad9
[   17.450942] [9837f050] *pgd=00000000
[   17.453642] [9837f050] *pgd=00000000
[   17.463476] Internal error: Oops: 5 [#1] SMP THUMB2
[   17.468347] Modules linked in: evdev zstd zram sun8i_codec_analog snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer snd soundcore sunxi_cir sun4i_gpadc_iio industrialio nvmem_sunxi_sid gpio_keys uio_pdrv_genirq cpufreq_dt uio thermal_sys usb_f_acm u_serial g_serial libcomposite brcmfmac brcmutil cfg80211 rfkill ip_tables x_tables pwrseq_simple realtek
[   17.499389] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.18.9-sunxi #4
[   17.505819] Hardware name: Allwinner sun8i Family
[   17.510528] PC is at check_preempt_curr+0x6a/0x84
[   17.515228] LR is at ttwu_do_wakeup+0x19/0x150
[   17.519666] pc : [<c013a722>]    lr : [<c013a755>]    psr: 200f01b3
[   17.525923] sp : ef123d58  ip : ef6dc370  fp : 2ea2e000
[   17.531139] r10: ef6dc2c0  r9 : 00000000  r8 : ef6dc2c0
[   17.536356] r7 : ef123d58  r6 : c0901e90  r5 : ef0f0680  r4 : c0901f70
[   17.542874] r3 : 9837f050  r2 : 00000000  r1 : ee8d3a80  r0 : ef6dc2c0
[   17.549393] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA Thumb  Segment none
[   17.556777] Control: 50c5387d  Table: 6cc5806a  DAC: 00000051
[   17.562515] Process swapper/3 (pid: 0, stack limit = 0xc420989f)
[   17.568513] Stack: (0xef123d58 to 0xef124000)
[   17.572865] 3d40:                                                       ef6dc2c0 ee8d3a80
[   17.581033] 3d60: ef123db4 ef123d70 ee8d3f08 c013a755 ef123d88 ef123db4 00000000 ee8d3a80
[   17.589202] 3d80: c0d04d48 c0cae2c0 ef123da0 ee8d3f08 00000000 ef6dc2c0 2ea2e000 c013b4bb
[   17.597370] 3da0: c0d04d48 c0d04e2c c0cae2c0 600f0193 ffffe000 c013c443 00000000 78b51995
[   17.605539] 3dc0: c0a64b78 edb2061c 00000001 00000000 c013b729 edb20628 00000000 00000003
[   17.613707] 3de0: 00000000 c015077f 0ee8b180 00000001 0e501b00 00000000 edb20620 800f0113
[   17.621875] 3e00: c0d04d70 ffffe000 c0dccf98 2ea2e000 4000001f c01508b3 00000000 00000000
[   17.630043] 3e20: edb20624 c01511e3 edb2060c edb20400 bf8d56c1 bf8d56d9 ef122000 edb2060c
[   17.638212] 3e40: 00000100 c016eb9b 00000000 0ee8b180 00000004 edb2060c ef6d7480 ef123e8c
[   17.646380] 3e60: c0d04d70 c016ed23 ef123e88 ef6d7480 c0d03d00 c0d04d48 ef123e88 c0ca9480
[   17.654548] 3e80: 2ea2e000 c016ee07 00000000 00000000 7fffffff ef6d8580 ef6d8580 00000001
[   17.662717] 3ea0: 00000003 c0170ee3 000f0193 78b51995 c0d03084 00000001 00000082 ffffe000
[   17.670885] 3ec0: 00000100 00000002 c0d03080 c0102255 0dd77b22 ef03af00 ef039600 c0ca5350
[   17.679054] 3ee0: c0d03080 c0cade80 0000000a ffff91a0 c0d03d00 00200042 c06e7895 c0cade4c
[   17.687222] 3f00: 00000000 00000013 00000000 00000001 ef02c400 c0cad530 00000000 c01203c3
[   17.695390] 3f20: 00000095 c015ee15 ef123f60 c0d05524 f080200c f0802000 ef123f60 f0803000
[   17.703559] 3f40: ef122000 c0512e71 c0107b28 400f0033 ffffffff ef123f94 00000000 c0101a65
[   17.711727] 3f60: 00000000 00004304 ef6d7430 c0116ae1 ffffe000 c0d04d70 c0d04dc0 00000008
[   17.719895] 3f80: 00000000 c0d04d48 c0cad530 00000000 c0d03d00 ef123fb0 c0107b27 c0107b28
[   17.728063] 3fa0: 400f0033 ffffffff 00000051 00000000 00000000 c013ed8b c0dcc62f c0ddf7c0
[   17.736232] 3fc0: 4000406a 78b51995 00000000 00000085 00000051 10c0387d c0ddf7c0 4000406a
[   17.744400] 3fe0: 410fc075 00000000 00000000 c013f00d c0102479 40102491 00000000 00000000
[   17.752580] [<c013a722>] (check_preempt_curr) from [<c013a755>] (ttwu_do_wakeup+0x19/0x150)
[   17.760925] [<c013a755>] (ttwu_do_wakeup) from [<c013b4bb>] (try_to_wake_up+0x15b/0x340)
[   17.769011] [<c013b4bb>] (try_to_wake_up) from [<c015077f>] (__wake_up_common+0x53/0xc8)
[   17.777094] [<c015077f>] (__wake_up_common) from [<c01508b3>] (__wake_up_locked+0x17/0x1c)
[   17.785350] [<c01508b3>] (__wake_up_locked) from [<c01511e3>] (complete+0x2b/0x38)
[   17.792989] [<c01511e3>] (complete) from [<bf8d56d9>] (brcmf_sdio_watchdog+0x18/0x34 [brcmfmac])
[   17.801809] [<bf8d56d9>] (brcmf_sdio_watchdog [brcmfmac]) from [<c016eb9b>] (call_timer_fn+0x23/0x118)
[   17.811108] [<c016eb9b>] (call_timer_fn) from [<c016ed23>] (expire_timers+0x93/0xdc)
[   17.818845] [<c016ed23>] (expire_timers) from [<c016ee07>] (run_timer_softirq+0x9b/0x138)
[   17.827016] [<c016ee07>] (run_timer_softirq) from [<c0102255>] (__do_softirq+0xbd/0x25c)
[   17.835100] [<c0102255>] (__do_softirq) from [<c01203c3>] (irq_exit+0x8f/0xc0)
[   17.842320] [<c01203c3>] (irq_exit) from [<c015ee15>] (__handle_domain_irq+0x49/0x84)
[   17.850148] [<c015ee15>] (__handle_domain_irq) from [<c0512e71>] (gic_handle_irq+0x39/0x68)
[   17.858493] [<c0512e71>] (gic_handle_irq) from [<c0101a65>] (__irq_svc+0x65/0x94)
[   17.865963] Exception stack(0xef123f60 to 0xef123fa8)
[   17.871011] 3f60: 00000000 00004304 ef6d7430 c0116ae1 ffffe000 c0d04d70 c0d04dc0 00000008
[   17.879179] 3f80: 00000000 c0d04d48 c0cad530 00000000 c0d03d00 ef123fb0 c0107b27 c0107b28
[   17.887343] 3fa0: 400f0033 ffffffff
[   17.890833] [<c0101a65>] (__irq_svc) from [<c0107b28>] (arch_cpu_idle+0x28/0x2c)
[   17.898226] [<c0107b28>] (arch_cpu_idle) from [<c013ed8b>] (do_idle+0x14b/0x1d8)
[   17.905615] [<c013ed8b>] (do_idle) from [<c013f00d>] (cpu_startup_entry+0x19/0x1c)
[   17.913178] [<c013f00d>] (cpu_startup_entry) from [<40102491>] (0x40102491)
[   17.920134] Code: f242 03c0 f2cc 0390 (681b) 2b00
[   17.924921] ---[ end trace 3e6eba88382b42c8 ]---
[   17.924924] Internal error: Oops: 5 [#2] SMP THUMB2
[   17.924928] Modules linked in:
[   17.929536] Kernel panic - not syncing: Fatal exception in interrupt
[   17.934401]  evdev
[   17.937452] CPU2: stopping
[   17.943789]  zstd
[   17.945800] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G      D           4.18.9-sunxi #4
[   17.948495]  zram
[   17.950417] Hardware name: Allwinner sun8i Family
[   17.958228]  sun8i_codec_analog
[   17.960161] [<c010de49>] (unwind_backtrace) from [<c010aaf9>] (show_stack+0x11/0x14)
[   17.964842]  snd_soc_core
[   17.967984] [<c010aaf9>] (show_stack) from [<c082b3a1>] (dump_stack+0x69/0x78)
[   17.975701]  snd_pcm_dmaengine
[   17.978322] [<c082b3a1>] (dump_stack) from [<c010cf1b>] (handle_IPI+0x213/0x22c)
[   17.985521]  snd_pcm
[   17.988575] [<c010cf1b>] (handle_IPI) from [<c0512e9f>] (gic_handle_irq+0x67/0x68)
[   17.995947]  snd_timer
[   17.998134] [<c0512e9f>] (gic_handle_irq) from [<c0101a65>] (__irq_svc+0x65/0x94)
[   18.005679]  snd
[   18.008035] Exception stack(0xef121f60 to 0xef121fa8)
[   18.015499]  soundcore
[   18.017337] 1f60: 00000000 00004e54 ef6c6430 c0116ae1 ffffe000 c0d04d70 c0d04dc0 00000004
[   18.022372]  sunxi_cir
[   18.024730] 1f80: 00000000 c0d04d48 c0cad530 00000000 c0d03d00 ef121fb0 c0107b27 c0107b28
[   18.032885]  sun4i_gpadc_iio
[   18.035239] 1fa0: 40070033 ffffffff
[   18.043397]  industrialio
[   18.046278] [<c0101a65>] (__irq_svc) from [<c0107b28>] (arch_cpu_idle+0x28/0x2c)
[   18.049749]  nvmem_sunxi_sid
[   18.052370] [<c0107b28>] (arch_cpu_idle) from [<c013ed8b>] (do_idle+0x14b/0x1d8)
[   18.059742]  gpio_keys
[   18.062622] [<c013ed8b>] (do_idle) from [<c013f00d>] (cpu_startup_entry+0x19/0x1c)
[   18.069995]  uio_pdrv_genirq
[   18.072354] [<c013f00d>] (cpu_startup_entry) from [<40102491>] (0x40102491)
[   18.079902]  cpufreq_dt uio thermal_sys usb_f_acm u_serial g_serial libcomposite brcmfmac brcmutil cfg80211 rfkill ip_tables x_tables pwrseq_simple realtek
[   18.103633] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G      D           4.18.9-sunxi #4
[   18.111449] Hardware name: Allwinner sun8i Family
[   18.116149] PC is at check_preempt_curr+0x6a/0x84
[   18.120849] LR is at ttwu_do_wakeup+0x19/0x150
[   18.125285] pc : [<c013a722>]    lr : [<c013a755>]    psr: 200f01b3
[   18.131541] sp : ef11fdb8  ip : ef6ba370  fp : 2ea0c000
[   18.136757] r10: ef6ba2c0  r9 : 00000000  r8 : ef6ba2c0
[   18.141974] r7 : ef11fdb8  r6 : c0901e90  r5 : ef0f1380  r4 : c0901f70
[   18.148492] r3 : 9837f050  r2 : 00000000  r1 : ef0f1a00  r0 : ef6ba2c0
[   18.155010] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA Thumb  Segment none
[   18.162395] Control: 50c5387d  Table: 6d30006a  DAC: 00000051
[   18.168132] Process swapper/1 (pid: 0, stack limit = 0xd72867c4)
[   18.174128] Stack: (0xef11fdb8 to 0xef120000)
[   18.178480] fda0:                                                       ef6ba2c0 ef0f1a00
[   18.186648] fdc0: ef11fe14 ef11fdd0 ef0f1e88 c013a755 ef11fde8 ef11fe14 00000000 ef0f1a00
[   18.194817] fde0: c0d04d48 c0cae2c0 ef11fe00 ef0f1e88 00000000 ef6ba2c0 2ea0c000 c013b4bb
[   18.202985] fe00: 00000000 00989680 c0cae2c0 000f0113 00000004 ffffe000 00000000 78b51995
[   18.211153] fe20: ef6b6898 ef119f0c 00000100 c016eb6d c0d04d70 ffffe000 c0dccf98 2ea0c000
[   18.219321] fe40: 4000001f c016eb9b 00000000 0ee8b180 00000004 ef119f0c ef6b5480 ef11fe8c
[   18.227490] fe60: c0d04d70 c016ed23 ef11fe88 ef6b5480 c0d03d00 c0d04d48 ef11fe88 c0ca9480
[   18.235658] fe80: 2ea0c000 c016ee07 00000000 00000000 7fffffff ef6b6580 ef6b6580 00000001
[   18.243826] fea0: 00000003 c0170ee3 000f0193 78b51995 c0d03084 00000001 00000082 ffffe000
[   18.251995] fec0: 00000100 00000002 c0d03080 c0102255 0db7bcd5 ef03af00 ef039600 c0ca5350
[   18.260163] fee0: c0d03080 c0cade80 0000000a ffff91a0 c0d03d00 00200042 c06e7895 c0cade4c
[   18.268331] ff00: 00000000 00000013 00000000 00000001 ef02c400 c0cad530 00000000 c01203c3
[   18.276500] ff20: 00000095 c015ee15 ef11ff60 c0d05524 f080200c f0802000 ef11ff60 f0803000
[   18.284668] ff40: ef11e000 c0512e71 c0107b28 400f0033 ffffffff ef11ff94 00000000 c0101a65
[   18.292836] ff60: 00000000 000050c8 ef6b5430 c0116ae1 ffffe000 c0d04d70 c0d04dc0 00000002
[   18.301005] ff80: 00000000 c0d04d48 c0cad530 00000000 c0d03d00 ef11ffb0 c0107b27 c0107b28
[   18.309173] ffa0: 400f0033 ffffffff 00000051 00000000 00000000 c013ed8b c0dcc62f 4000406a
[   18.317341] ffc0: 410fc075 78b51995 00000000 00000085 00000051 10c0387d c0ddf7c0 4000406a
[   18.325509] ffe0: 410fc075 00000000 00000000 c013f00d c0102479 40102491 00000000 00000000
[   18.333681] [<c013a722>] (check_preempt_curr) from [<c013a755>] (ttwu_do_wakeup+0x19/0x150)
[   18.342025] [<c013a755>] (ttwu_do_wakeup) from [<c013b4bb>] (try_to_wake_up+0x15b/0x340)
[   18.350110] [<c013b4bb>] (try_to_wake_up) from [<c016eb9b>] (call_timer_fn+0x23/0x118)
[   18.358020] [<c016eb9b>] (call_timer_fn) from [<c016ed23>] (expire_timers+0x93/0xdc)
[   18.365757] [<c016ed23>] (expire_timers) from [<c016ee07>] (run_timer_softirq+0x9b/0x138)
[   18.373926] [<c016ee07>] (run_timer_softirq) from [<c0102255>] (__do_softirq+0xbd/0x25c)
[   18.382008] [<c0102255>] (__do_softirq) from [<c01203c3>] (irq_exit+0x8f/0xc0)
[   18.389225] [<c01203c3>] (irq_exit) from [<c015ee15>] (__handle_domain_irq+0x49/0x84)
[   18.397049] [<c015ee15>] (__handle_domain_irq) from [<c0512e71>] (gic_handle_irq+0x39/0x68)
[   18.405392] [<c0512e71>] (gic_handle_irq) from [<c0101a65>] (__irq_svc+0x65/0x94)
[   18.412863] Exception stack(0xef11ff60 to 0xef11ffa8)
[   18.417911] ff60: 00000000 000050c8 ef6b5430 c0116ae1 ffffe000 c0d04d70 c0d04dc0 00000002
[   18.426079] ff80: 00000000 c0d04d48 c0cad530 00000000 c0d03d00 ef11ffb0 c0107b27 c0107b28
[   18.434243] ffa0: 400f0033 ffffffff
[   18.437733] [<c0101a65>] (__irq_svc) from [<c0107b28>] (arch_cpu_idle+0x28/0x2c)
[   18.445123] [<c0107b28>] (arch_cpu_idle) from [<c013ed8b>] (do_idle+0x14b/0x1d8)
[   18.452512] [<c013ed8b>] (do_idle) from [<c013f00d>] (cpu_startup_entry+0x19/0x1c)
[   18.460073] [<c013f00d>] (cpu_startup_entry) from [<40102491>] (0x40102491)
[   18.467027] Code: f242 03c0 f2cc 0390 (681b) 2b00
[   18.471812] ---[ end trace 3e6eba88382b42c9 ]---
[   18.979114] SMP: failed to stop secondary CPUs
[   18.983559] Rebooting in 10 seconds..
[   30.029295] SMP: failed to stop secondary CPUs
[   30.033734] Unable to handle kernel paging request at virtual address c0ddf56c
[   30.040944] pgd = 1267547c
[   30.043646] [c0ddf56c] *pgd=40c1141e(bad)
[   30.047655] Internal error: Oops: 8000000d [#3] SMP THUMB2
[   30.053130] Modules linked in: evdev zstd zram sun8i_codec_analog snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer snd soundcore sunxi_cir sun4i_gpadc_iio industrialio nvmem_sunxi_sid gpio_keys uio_pdrv_genirq cpufreq_dt uio thermal_sys usb_f_acm u_serial g_serial libcomposite brcmfmac brcmutil cfg80211 rfkill ip_tables x_tables pwrseq_simple realtek
[   30.084152] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G      D           4.18.9-sunxi #4
[   30.091968] Hardware name: Allwinner sun8i Family
[   30.096665] PC is at 0xc0ddf56c
[   30.099803] LR is at machine_restart+0x2d/0x60
[   30.104240] pc : [<c0ddf56c>]    lr : [<c01091e9>]    psr: 600f0193
[   30.110497] sp : ef123ba0  ip : 0000000b  fp : ef0f0680
[   30.115714] r10: 0ccccb60  r9 : 00000000  r8 : c0b07800
[   30.120930] r7 : 00002710  r6 : 00002710  r5 : 00000000  r4 : 00000000
[   30.127447] r3 : c0d0e5d8  r2 : c0ddf56c  r1 : 00000000  r0 : 00000000
[   30.133965] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
[   30.141176] Control: 50c5387d  Table: 6cc5806a  DAC: 00000051
[   30.146913] Process swapper/3 (pid: 0, stack limit = 0xc420989f)
[   30.152909] Stack: (0xef123ba0 to 0xef124000)
[   30.157264] 3ba0: c0ddfa30 00000000 00002710 c011b9e1 ef123bc4 78b51995 bf000000 c010ad37
[   30.165433] 3bc0: c0a5e244 00000000 00000100 00000100 ef122210 0000000b c0a5fa8c 600f0193
[   30.173601] 3be0: 00000000 9837f050 ef123d08 00000005 00000000 9837f050 ef123d08 ef6dc2c0
[   30.181769] 3c00: 2ea2e000 c0111751 00000005 c01114d1 1dcd6500 00000000 00000000 ef123d60
[   30.189937] 3c20: 00000003 c0cae2c0 00000001 ef0e02d4 ef0e02c0 c0d0ad04 c0d04d48 00000005
[   30.198106] 3c40: c0111539 9837f050 ef123d08 ef6dc2c0 2ea2e000 c0111603 0000000c 00000000
[   30.206274] 3c60: 00000000 00000400 00000000 00000400 00000400 ef6dc340 ee8d3b00 c0145a31
[   30.214443] 3c80: ef6dc340 c0145a8f ef6dc340 ee8d3b00 c0d04d48 65b8f7b9 00000000 c01459ef
[   30.222611] 3ca0: 000023d3 00000400 00000000 c0146d2b ffffd820 ffffffff 1dcd6500 00000000
[   30.230779] 3cc0: ef6dc340 ef123e08 00000003 c0cae2c0 00000001 ef0e02d4 ef0e02c0 ef123e08
[   30.238948] 3ce0: ef123d08 78b51995 c0d05230 c013a722 200f01b3 ffffffff ef123d3c ef6dc2c0
[   30.247116] 3d00: ef122000 c01019d3 ef6dc2c0 ee8d3a80 00000000 9837f050 c0901f70 ef0f0680
[   30.255284] 3d20: c0901e90 ef123d58 ef6dc2c0 00000000 ef6dc2c0 2ea2e000 ef6dc370 ef123d58
[   30.263453] 3d40: c013a755 c013a722 200f01b3 ffffffff 00000051 bf000000 ef6dc2c0 ee8d3a80
[   30.271621] 3d60: ef123db4 ef123d70 ee8d3f08 c013a755 ef123d88 ef123db4 00000000 ee8d3a80
[   30.279789] 3d80: c0d04d48 c0cae2c0 ef123da0 ee8d3f08 00000000 ef6dc2c0 2ea2e000 c013b4bb
[   30.287958] 3da0: c0d04d48 c0d04e2c c0cae2c0 600f0193 ffffe000 c013c443 00000000 78b51995
[   30.296126] 3dc0: c0a64b78 edb2061c 00000001 00000000 c013b729 edb20628 00000000 00000003
[   30.304294] 3de0: 00000000 c015077f 0ee8b180 00000001 0e501b00 00000000 edb20620 800f0113
[   30.312463] 3e00: c0d04d70 ffffe000 c0dccf98 2ea2e000 4000001f c01508b3 00000000 00000000
[   30.320631] 3e20: edb20624 c01511e3 edb2060c edb20400 bf8d56c1 bf8d56d9 ef122000 edb2060c
[   30.328799] 3e40: 00000100 c016eb9b 00000000 0ee8b180 00000004 edb2060c ef6d7480 ef123e8c
[   30.336968] 3e60: c0d04d70 c016ed23 ef123e88 ef6d7480 c0d03d00 c0d04d48 ef123e88 c0ca9480
[   30.345136] 3e80: 2ea2e000 c016ee07 00000000 00000000 7fffffff ef6d8580 ef6d8580 00000001
[   30.353304] 3ea0: 00000003 c0170ee3 000f0193 78b51995 c0d03084 00000001 00000082 ffffe000
[   30.361473] 3ec0: 00000100 00000002 c0d03080 c0102255 0dd77b22 ef03af00 ef039600 c0ca5350
[   30.369641] 3ee0: c0d03080 c0cade80 0000000a ffff91a0 c0d03d00 00200042 c06e7895 c0cade4c
[   30.377809] 3f00: 00000000 00000013 00000000 00000001 ef02c400 c0cad530 00000000 c01203c3
[   30.385978] 3f20: 00000095 c015ee15 ef123f60 c0d05524 f080200c f0802000 ef123f60 f0803000
[   30.394146] 3f40: ef122000 c0512e71 c0107b28 400f0033 ffffffff ef123f94 00000000 c0101a65
[   30.402314] 3f60: 00000000 00004304 ef6d7430 c0116ae1 ffffe000 c0d04d70 c0d04dc0 00000008
[   30.410482] 3f80: 00000000 c0d04d48 c0cad530 00000000 c0d03d00 ef123fb0 c0107b27 c0107b28
[   30.418651] 3fa0: 400f0033 ffffffff 00000051 00000000 00000000 c013ed8b c0dcc62f c0ddf7c0
[   30.426819] 3fc0: 4000406a 78b51995 00000000 00000085 00000051 10c0387d c0ddf7c0 4000406a
[   30.434987] 3fe0: 410fc075 00000000 00000000 c013f00d c0102479 40102491 00000000 00000000
[   30.443159] [<c01091e9>] (machine_restart) from [<c011b9e1>] (panic+0x175/0x1c8)
[   30.450548] [<c011b9e1>] (panic) from [<c010ad37>] (die+0x23b/0x26c)
[   30.456898] [<c010ad37>] (die) from [<c0111751>] (__do_kernel_fault.part.0+0x55/0x60)
[   30.464720] [<c0111751>] (__do_kernel_fault.part.0) from [<c01114d1>] (do_bad_area+0x1/0x58)
[   30.473147] [<c01114d1>] (do_bad_area) from [<ef0e02d4>] (0xef0e02d4)
[   30.479580] Code: 00000000 00000000 00000000 0dbaeec6 (c0ddf58c)
[   30.485664] ---[ end trace 3e6eba88382b42ca ]---
[   30.490274] Kernel panic - not syncing: Fatal exception in interrupt
[   31.538284] SMP: failed to stop secondary CPUs
[   31.542725] Rebooting in 10 seconds..
[   42.588459] SMP: failed to stop secondary CPUs
[   42.592897] Unable to handle kernel paging request at virtual address c0ddf56c
[   42.600107] pgd = 1267547c
[   42.602809] [c0ddf56c] *pgd=40c1141e(bad)
[   42.606817] Internal error: Oops: 8000000d [#4] SMP THUMB2
[   42.612291] Modules linked in: evdev zstd zram sun8i_codec_analog snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer snd soundcore sunxi_cir sun4i_gpadc_iio industrialio nvmem_sunxi_sid gpio_keys uio_pdrv_genirq cpufreq_dt uio thermal_sys usb_f_acm u_serial g_serial libcomposite brcmfmac brcmutil cfg80211 rfkill ip_tables x_tables pwrseq_simple realtek
[   42.643314] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G      D           4.18.9-sunxi #4
[   42.651131] Hardware name: Allwinner sun8i Family
[   42.655827] PC is at 0xc0ddf56c
[   42.658964] LR is at machine_restart+0x2d/0x60
[   42.663401] pc : [<c0ddf56c>]    lr : [<c01091e9>]    psr: 600f0193
[   42.669657] sp : ef123a08  ip : 0000000b  fp : ef0f0680
[   42.674874] r10: 0ccccb60  r9 : 00000000  r8 : c0b07800
[   42.680090] r7 : 00002710  r6 : 00002710  r5 : 00000000  r4 : 00000000
[   42.686607] r3 : c0d0e5d8  r2 : c0ddf56c  r1 : 00000000  r0 : 00000000
[   42.693123] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
[   42.700334] Control: 50c5387d  Table: 6cc5806a  DAC: 00000051
[   42.706071] Process swapper/3 (pid: 0, stack limit = 0xc420989f)
[   42.712068] Stack: (0xef123a08 to 0xef124000)
[   42.716422] 3a00:                   c0ddfa30 00000000 00002710 c011b9e1 ef123a2c 78b51995
[   42.724590] 3a20: bf000000 c010ad37 c0a5e244 00000000 00000100 00000100 ef122210 0000000b
[   42.732758] 3a40: c0a5fa8c 600f0193 ed08ca80 c0ddf56c ef123b50 8000000d ed08ca80 8000000d
[   42.740927] 3a60: ef123b50 0ccccb60 ef0f0680 c0111751 c0ddf56c c0111529 c015bf19 c0a668e4
[   42.749095] 3a80: c0d04d48 c0d0af84 0000000d c0111529 c0ddf56c c0111535 000000d0 c01116a5
[   42.757263] 3aa0: 0001d894 78b51995 00000000 c0157f39 c0ca5420 c0d11314 ef122000 c05626dd
[   42.765432] 3ac0: 000f0193 c015cda9 00000000 c015d0c1 00000000 00000000 00000694 00000000
[   42.773600] 3ae0: 00000000 c0de2fd0 600f0193 ffffe000 c0d04d70 00000000 600f0193 c0de2ac8
[   42.781768] 3b00: 00000000 ef6d3414 2ea2e000 c015deeb 600f0193 c0de2ac8 00000000 c015df81
[   42.789936] 3b20: c0a5e970 ef123b74 600f0193 78b51995 c0d04d70 c0ddf56c 600f0193 ffffffff
[   42.798105] 3b40: ef123b84 c0b07800 ef122000 c0101bbf 00000000 00000000 c0ddf56c c0d0e5d8
[   42.806273] 3b60: 00000000 00000000 00002710 00002710 c0b07800 00000000 0ccccb60 ef0f0680
[   42.814441] 3b80: 0000000b ef123ba0 c01091e9 c0ddf56c 600f0193 ffffffff 00000051 bf000000
[   42.822610] 3ba0: c0ddfa30 00000000 00002710 c011b9e1 ef123bc4 78b51995 bf000000 c010ad37
[   42.830778] 3bc0: c0a5e244 00000000 00000100 00000100 ef122210 0000000b c0a5fa8c 600f0193
[   42.838946] 3be0: 00000000 9837f050 ef123d08 00000005 00000000 9837f050 ef123d08 ef6dc2c0
[   42.847115] 3c00: 2ea2e000 c0111751 00000005 c01114d1 1dcd6500 00000000 00000000 ef123d60
[   42.855283] 3c20: 00000003 c0cae2c0 00000001 ef0e02d4 ef0e02c0 c0d0ad04 c0d04d48 00000005
[   42.863451] 3c40: c0111539 9837f050 ef123d08 ef6dc2c0 2ea2e000 c0111603 0000000c 00000000
[   42.871619] 3c60: 00000000 00000400 00000000 00000400 00000400 ef6dc340 ee8d3b00 c0145a31
[   42.879788] 3c80: ef6dc340 c0145a8f ef6dc340 ee8d3b00 c0d04d48 65b8f7b9 00000000 c01459ef
[   42.887956] 3ca0: 000023d3 00000400 00000000 c0146d2b ffffd820 ffffffff 1dcd6500 00000000
[   42.896124] 3cc0: ef6dc340 ef123e08 00000003 c0cae2c0 00000001 ef0e02d4 ef0e02c0 ef123e08
[   42.904293] 3ce0: ef123d08 78b51995 c0d05230 c013a722 200f01b3 ffffffff ef123d3c ef6dc2c0
[   42.912461] 3d00: ef122000 c01019d3 ef6dc2c0 ee8d3a80 00000000 9837f050 c0901f70 ef0f0680
[   42.920629] 3d20: c0901e90 ef123d58 ef6dc2c0 00000000 ef6dc2c0 2ea2e000 ef6dc370 ef123d58
[   42.928798] 3d40: c013a755 c013a722 200f01b3 ffffffff 00000051 bf000000 ef6dc2c0 ee8d3a80
[   42.936966] 3d60: ef123db4 ef123d70 ee8d3f08 c013a755 ef123d88 ef123db4 00000000 ee8d3a80
[   42.945134] 3d80: c0d04d48 c0cae2c0 ef123da0 ee8d3f08 00000000 ef6dc2c0 2ea2e000 c013b4bb
[   42.953303] 3da0: c0d04d48 c0d04e2c c0cae2c0 600f0193 ffffe000 c013c443 00000000 78b51995
[   42.961471] 3dc0: c0a64b78 edb2061c 00000001 00000000 c013b729 edb20628 00000000 00000003
[   42.969639] 3de0: 00000000 c015077f 0ee8b180 00000001 0e501b00 00000000 edb20620 800f0113
[   42.977807] 3e00: c0d04d70 ffffe000 c0dccf98 2ea2e000 4000001f c01508b3 00000000 00000000
[   42.985976] 3e20: edb20624 c01511e3 edb2060c edb20400 bf8d56c1 bf8d56d9 ef122000 edb2060c
[   42.994144] 3e40: 00000100 c016eb9b 00000000 0ee8b180 00000004 edb2060c ef6d7480 ef123e8c
[   43.002313] 3e60: c0d04d70 c016ed23 ef123e88 ef6d7480 c0d03d00 c0d04d48 ef123e88 c0ca9480
[   43.010481] 3e80: 2ea2e000 c016ee07 00000000 00000000 7fffffff ef6d8580 ef6d8580 00000001
[   43.018649] 3ea0: 00000003 c0170ee3 000f0193 78b51995 c0d03084 00000001 00000082 ffffe000
[   43.026818] 3ec0: 00000100 00000002 c0d03080 c0102255 0dd77b22 ef03af00 ef039600 c0ca5350
[   43.034986] 3ee0: c0d03080 c0cade80 0000000a ffff91a0 c0d03d00 00200042 c06e7895 c0cade4c
[   43.043155] 3f00: 00000000 00000013 00000000 00000001 ef02c400 c0cad530 00000000 c01203c3
[   43.051323] 3f20: 00000095 c015ee15 ef123f60 c0d05524 f080200c f0802000 ef123f60 f0803000
[   43.059491] 3f40: ef122000 c0512e71 c0107b28 400f0033 ffffffff ef123f94 00000000 c0101a65
[   43.067660] 3f60: 00000000 00004304 ef6d7430 c0116ae1 ffffe000 c0d04d70 c0d04dc0 00000008
[   43.075828] 3f80: 00000000 c0d04d48 c0cad530 00000000 c0d03d00 ef123fb0 c0107b27 c0107b28
[   43.083996] 3fa0: 400f0033 ffffffff 00000051 00000000 00000000 c013ed8b c0dcc62f c0ddf7c0
[   43.092164] 3fc0: 4000406a 78b51995 00000000 00000085 00000051 10c0387d c0ddf7c0 4000406a
[   43.100333] 3fe0: 410fc075 00000000 00000000 c013f00d c0102479 40102491 00000000 00000000
[   43.108502] [<c01091e9>] (machine_restart) from [<c011b9e1>] (panic+0x175/0x1c8)
[   43.115892] [<c011b9e1>] (panic) from [<c010ad37>] (die+0x23b/0x26c)
[   43.122242] [<c010ad37>] (die) from [<c0111751>] (__do_kernel_fault.part.0+0x55/0x60)
[   43.130064] [<c0111751>] (__do_kernel_fault.part.0) from [<c0111529>] (do_sect_fault+0x1/0x10)
[   43.138664] [<c0111529>] (do_sect_fault) from [<c0a668e4>] (0xc0a668e4)
[   43.145270] Code: 00000000 00000000 00000000 0dbaeec6 (c0ddf58c)
[   43.151354] ---[ end trace 3e6eba88382b42cb ]---
[   43.155964] Kernel panic - not syncing: Fatal exception in interrupt
you are using next or? (4.14.51-sunxi)
would like to test camera, for that i need the 4.18 kernel (BRANCH=DEV)
sorry overseen, that this area is only for DEFAULT/NEXT, please move topic to development.
Check the whole log. It's NEXT upgraded to DEV. The one that is in a stable repository.
sorry for bothering with this issue, it was the power supply ):
found out it was only 4.5V, kernel was booting but than crashing... with 4.6V it works now fine have to find proper 5V power supply
thanks for helping
