I followed instruction of adding overlay at http://linux-sunxi.org/1-Wire
Linux kernel 4.14
You don't have to edit the fex-file, but the /boot/armbianEnv.txt and add the lines:
overlays=w1-gpio
param_w1_pin=PB10 # desired pin
param_w1_pin_int_pullup=1 # internal pullup-resistor: 1=on, 0=off
This resulted in an error during boot and non functional 1-wire:
## Executing script at 44000000
tmp_bank=A             # desired pin
tmp_pin=10             # desired pin
Sorry, I could not convert "A             # desired pin 10             # desired pin 0>"
Removing "#" comments from armbianEnv.txt resolved the issue
Can you please confirm if comments are allowed in armbianEnv.txt?
Thanks
