midix Posted September 23, 2018 Posted September 23, 2018 I don't want to torture my SD card with full OS image rewrites or compilation on the device itself, so I would like to cross-compile. I just set up a ubuntu/bionic64 VirtualBox through Vagrant using https://github.com/armbian/build Currently, I don't want to build entire image or kernel from scratch but I noticed that compile.sh and related scripts contain many convenience functions and tools. I already started compile.sh once to let it prepare the virtual machine for cross-compile tasks and it successfully installed all the dependencies. I got especially interested in extras-buildpkgs folder. As I understand, I can put my own package descriptions there and Armbian tools will find it and offer to create packages for it? Is there any simple way to leverage Armbian tools to create a deb package of a single third party program (ZynAddSubFx, to be more exact - I already have it compiled once directly on an ARM device, so I know it's doable) without compiling the kernel or OS? Ideally, I would like to get the "make install" results of the software to be collected into a deb package, so I can just install it on the target machine (NanoPi Neo2, to be specific).
Igor Posted September 24, 2018 Posted September 24, 2018 9 hours ago, midix said: I got especially interested in extras-buildpkgs folder. As I understand, I can put my own package descriptions there and Armbian tools will find it and offer to create packages for it? This part was not designed for end-user based packages. Absolutely agree that it's nice to have but would require some RFC, while our resources are ATM too low for such changes. Currently, you need to make use of chroot compilation with your own script, this way:https://docs.armbian.com/Developer-Guide_User-Configurations/#user-provided-image-customization-script
lrrr Posted September 25, 2018 Posted September 25, 2018 It would be nice if the SDK could easily build deb packages, similar to openwrt's SDK. I checked into chroot-buildpackages.sh but didn't mess with distcc setup. Larger projects will need distcc or much patience. This is sort of what I do to "cross-compile" deb packages. You still need to build an image but you don't have to use it. You can just copy your deb packages over to target os. To get make install results into deb package, you need to use some sort of debian package builder. Many options, guides, and tutorials are available online. The example below uses dpkg-deb. After you build initial image, you can speed up image building by setting clean level: ./compile CLEAN_LEVEL="" Needs a small patch to SDK, as we need a way to get out the debs (or use another method, like network). diff --git a/lib/image-helpers.sh b/lib/image-helpers.sh index a99163e..bea81fc 100644 --- a/lib/image-helpers.sh +++ b/lib/image-helpers.sh @@ -110,7 +110,7 @@ customize_image() chmod +x $SDCARD/tmp/customize-image.sh mkdir -p $SDCARD/tmp/overlay # util-linux >= 2.27 required - mount -o bind,ro $SRC/userpatches/overlay $SDCARD/tmp/overlay + mount -o bind $SRC/userpatches/overlay $SDCARD/tmp/overlay display_alert "Calling image customization script" "customize-image.sh" "info" chroot $SDCARD /bin/bash -c "/tmp/customize-image.sh $RELEASE $LINUXFAMILY $BOARD $BUILD_DESKTOP" umount $SDCARD/tmp/overlay In userpatches/customize-image.sh, drop your compile code. Or for multiple packages, do something like: for FN in /tmp/overlay/packages/*; do source $FN done Add your compile script. Here is a hello world example, copy to userpatches/overlay/packages/helloworld: #!/bin/sh -e # example based on https://ubuntuforums.org/showthread.php?t=910717 PACKAGE="helloworld" VERSION="1.0-1" BDIR="${PACKAGE}_${VERSION}" ARCH="armhf" MAINTAINER="lrrr <lrrr@armbian.com>" cat <<-EOF > /tmp/hw.c #include <stdio.h> int main(void){ printf("Hello world!\n"); return 0; } EOF mkdir -p ${BDIR}/usr/local/bin gcc -Wall /tmp/hw.c -o ${BDIR}/usr/local/bin/$PACKAGE mkdir -p ${BDIR}/DEBIAN cat <<-EOF > ${BDIR}/DEBIAN/control Package: $PACKAGE Version: $VERSION Section: base Priority: optional Architecture: $ARCH Maintainer: $MAINTAINER Description: Hello World When you need some sunshine, just run this small program! EOF dpkg-deb --build $BDIR # requires armbian SDK mod for /tmp/overlay (rw) mv -v ${BDIR}.deb /tmp/overlay rm -fr ${BDIR} hw.c
midix Posted September 26, 2018 Author Posted September 26, 2018 Thanks for the helpful hints. For now, I managed to create something hacky using the following approach: In debootstrap-ng.sh I commented out the line # rm -rf $SDCARD So now I had left valid rootfs and I could do armccrootpath=/home/vagrant/armbian/.tmp/rootfs-next-nanopineo2-bionic-no mount -t proc chproc $armccrootpath/proc mount -t sysfs chsys $armccrootpath/sys mount -t devtmpfs chdev $armccrootpath/dev || mount --bind /dev $armccrootpath/dev mount -t devpts chpts $armccrootpath/dev/pts cp /usr/bin/qemu-aarch64-static $armccrootpath/usr/bin/ chroot $armccrootpath From there, I continued as usual and was able to compile ZynAddSubFx. I tried to create a deb using checkinstall tool, but unfortunately it failed during tar process and complained about many missing Voice files. So I gave up, zipped entire zynaddsubfx folder with build results and just copied it over to nanopineo2 and ran `make install` there. It worked just fine at the end.
lrrr Posted September 26, 2018 Posted September 26, 2018 I usually use the cached rootfs in cache/rootfs. Extract, then mount pseudo-filesystems and copy over static qemu like you posted. Quick hacks are good if they get the job done. Another easy way to get chroot with customize-image.sh and do things manually: #!/bin/sh echo "Entering chroot for $1 $2 $3" bash Before you exit chroot, copy your debs/files with another shell, network, etc.
gogol Posted August 22, 2019 Posted August 22, 2019 On 9/26/2018 at 7:50 PM, midix said: chroot $armccrootpath From there, I continued as usual ... When I try to do the same, chrooting fails with: chroot: failed to run command ‘/bin/bash’: No such file or directory So I wonder, how that chroot should work anyhow, as in /bin and /usr/bin are now ARM-binaries, while the compiling host needs amd64 binaries.
