OK, OK, OK, OK No problems! :-)
Just experience. Mine. My XU4 is connected to VU7 Plus, nice. charming.
The startscreen when starting from a very beginning: The letters are really very small.
The VU7 is adjusted to 1200x720 but it is 1024x768
Adjusting the size of the letters one should have some experience in doing that.
Also in setting the keyboard.
I don't have good experience without DHCP on XU4.
Also not with IPv6 for the server doesn't support IPv6. (ADSL-Modem :->)
https://wiki.odroid.com/accessory/emmc/recovery_xu4  is very good
No problems.
Working with Configuration utility one can get lost without reading the "book" simultanously.
And here is some warning in "stretch' making stress: Copy&paste using vim in CLI is bad.
One has always be prepared for "systemctl restart gpm" or vim.basic will block XU4!
I always have a CLI with TOP to stop vim.basic.
People at debian don't repaire it I don't get out why not.
Is there anyone having experience with XU6 and Linphone?
That's for the moment and all the best for the work on armbian!
Well, things are going on. This time IPV6 <-> IPV4 and DHCP.
As I mentioned my ADSL-modem is crap (ALCATEL). So switching to fixed address is not at all recommended. Here.
Coming back to DHCP doesn't, work. No  IP no route, no relay (as the gateway should be called).
Also IPv6-address disappeared. No SSH possible of course.
And! eth0 is dead, enp4s1 ist dead, long live enx001234567890 where 1234567890 is the MAC
My IPv4 looks like 10.0.0.x\24  thr gx is 10.0.0.138.
Log in as root.
Eine Zeile ist Memory usage:  9 % of 1996MB     IP:            nitchewo, null, niente
you can put rthe following in a "script" without '#' and make it chmod "script" 755
#ip link set dev enx001234567890 down
#ip addr add dev enx001234567890 local 10.0.0.x/24 broadcast 10.0.0.255
#ip link set dev enx001234567890 up
#route add default dev enx001234567890 gw 10.0.0.138
Then try ping 10.0.0.138  and ping or telnet 194.183.128.159 25  afterwards
X you have to start with startx, also as root it works
BEWARE: Don't try vim, gitfm, gpm,  please, that's crap from Debian!
You only can use nano <wääähh> mc :-(  gpm is OK then
Questions?
As mentioned I still use a memorycard with D9,5 , but did get e repaired eMMS with android from hardkernel.
Now I made a look what's on to work with (file attached)
Most annoying c&p using Debian stretch vim and gpm, please use nano  or D8 which is very old but works fine. Why old? Networkcard is still called eth. in D9 it is now end4s6 for instance an now en00(MAC) which is too long for many programs as sinfod.
And one again, never try IPv6. going back to IPv4 because of sone problems, nothing will work, no net, no armbian-config so please adopt that for your needs:
/etc/networking/interfaces
nano /etc/network/interfaces
# armbian-config created
##source /etc/network/interfaces.d/*
# Local loopback
auto lo
iface lo inet loopback
# Interface enx001e06322b8e
auto enx001e06322b8e
allow-auto enx001e06322b8e
allow-hotplug enx001e06322b8e
iface enx001e06322b8e inet static
        address 10.0.0.1
        netmask 255.255.255.0
        network 10.0.0.0
        gateway 10.0.0.138
        hardware ether  00:1e:06:32:2b:8e
        dns-nameserver 127.0.0.1 194.183.128.35 194.183.128.36
        dns-search at
enx001e06322b8e I'm sure it is not yours
Kernels reads this in the very beginning.
to make changes use "ip". ip is strange but genious for it can be used for everything concerning nets.
So get accustomed to it now.
But just for the beginning:
ip link set dev  enx001e06322b8e down
ip addr del 10.0.0.7/24 dev enx001e06322b8e
ip addr add dev enx001e06322b8e local 10.0.0.1/24 broadcast 10.0.0.255
ip link set dev enx001e06322b8e up
now as enx001e06322b8e is up now ask route -n and you might need:
route add default dev enp4s0 gw 10.0.0.138 but that is ugly so use
ip route add default dev enx001e06322b8e src 10.0.0.3/24 via 10.0.0.138
I don's not what to repair but IPv6 is completly distroyed.
1
something useful:
Howto get these mmcblk-crap
root@2b8e:/mnt# ls -lisa /dev/disk/by-uuid
total 0
12297 0 drwxr-xr-x 2 root root 160 Sep 27 20:58 .
 9262 0 drwxr-xr-x 7 root root 140 Jan  1  2000 ..
13331 0 lrwxrwxrwx 1 root root  15 Sep 27 20:58 0000-3333 -> ../../mmcblk0p1
12298 0 lrwxrwxrwx 1 root root  15 Sep 27 20:58 1334d04d-7ea0-44b3-9dba-fbc34e9e9ccd -> ../../mmcblk0p3
11330 0 lrwxrwxrwx 1 root root  15 Sep 27 20:58 57f8f4bc-abf4-655f-bf67-946fc0f9f25b -> ../../mmcblk0p2
14781 0 lrwxrwxrwx 1 root root  10 Sep 27 20:58 6afd7d22-8f78-4e09-9214-7df7421b7c06 -> ../../sdb1
 9291 0 lrwxrwxrwx 1 root root  15 Sep 27 20:58 7d408db8-5e88-4654-aaee-3e0d621c4fa1 -> ../../mmcblk1p1
14750 0 lrwxrwxrwx 1 root root  10 Sep 27 20:58 D303-6887 -> ../../sda1
don't forget:   mmcblk0p1 differs from mmcblk1p1
and:
find / .name mmcblk0p3 :-D  OKOK
find / -name mmcblk0p2
/sys/devices/platform/soc/12200000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p2
/sys/class/block/mmcblk0p2
Support isn't useful at all
well, some annoying behaviors, extremly annoying, really
do
and then
ip addr show
ip link is up again !!!!!!!!!!
WHY? >8-0
Well try that, open a file, insert
ip --force link set dev  enx001e06322b8e down
ip -force link set dev enx001e06322b8e up
close it and make chown "file" 755  and now it is better
This is new in stretch ans idiotic.
BUT! did you change  /etc/network/interfaces? I'm afraid it has to be changed too
a don't want to reboot now.....
