What do these explicitly do?
Which ones can be disabled?
Which ones can interfere with other system mods?
sudo systemctl list-unit-files | grep armb*
armbian-firstrun-config.service            enabled
armbian-firstrun.service                   disabled
armbian-hardware-monitor.service           enabled
armbian-hardware-optimize.service          enabled
armbian-ramlog.service                     enabled
armbian-resize-filesystem.service          disabled
armbian-zram-config.service                enabled
I've notices that ramlog can be disabled two ways - in the config, or disable the service, others related to if zram-config is installed or not - HW monitor actually doesn't seem to impact things on 5.60+ when running local, other than we see less /var/log stuff (which is ok) - the zram-config-service can get in the way of testing, but generally harmless otherwise.
Just curious as to why?
For brief info on the services:
head -n3 /lib/systemd/system/armbian*
I've found them not to be necessary but YMMV.
Have a look at the commented scripts in '/usr/lib/armbian' to see which services you might want (or need).
