junnikokuki Posted October 13, 2018 Posted October 13, 2018 Recently I tested armbian stretch for orange pi lite2. If there is not other task except system, there work fine. But if there are some high cpu tasks, such as unzip, the system load will go high, and not go to lower level when task done. When the system load is higher than 4, the response of the system is laggy, when go higher, the system will go no response. I use uptime to test the system load, when boot, the 1min load will be at 3.xx and go down slowly. When no task, the load will lower than 0.5.
