Volkan Ugur Posted March 18, 2016 Posted March 18, 2016 Hi , my op one board is installed latest armbian but i couldnt see serail ports The default serial port /dev/ttyS0, used for (bootstrap) debugging and the serial console, is located at J11 - refer to the picture and instructions below. The Raspberry's "original" serial port on GPIO 14 and 15 (CON3, pins 8 and 10) can usually be accessed as /dev/ttyS2 on the Orange Pi Plus. J12 also provides another serial port on pins 4 (RX) and 6 (TX), which should map to /dev/ttyS3. only i see /dev/ttyS0 and /dev/ttyGS0--GS4 how can i fix this issue ?
